Low fps for static images
thatGuy
Post by thatGuy »
I'm doing a simple Alpha transition between two jpg files (800*640) and the fps drops to 4 ! While most other things run at around 60 .
Any thoughts ?
Re: Low fps for static images
what is your composition resolution?
file resolutions?
thatGuy
Post by thatGuy »
Composition 640x480
Images are about the same at 72dpi
This is a very small composition so you should not have any problems!
What's your hardware setup?
Also, just for the record, these days it's all about pixels so DPI is irrelevant when you have the resolution of the image.
dRead
Post by dRead »
Make a 1 frame quicktime of your image using the DXV codec. Works great for me.
_____________________
dRead
www.drvisuals.com
