Send thumbnails via OSC
david@skyslc.com
Post by david@skyslc.com »
I've been working on an Arduino based OSC VJ mixer. So far it works great! I'd really love to be able to add thumbnails from Resolume Arena 5.04 to a touchscreen connected to said Arduino.
Question: Is there a location where Resolume stores thumbnails for the videos being used in the composition? If so then what format are they in and is it possible/necessary to convert them to a web ready format like jpg/png/gif?
Online
Re: Send thumbnails via OSC
here is some info : viewtopic.php?f=14&t=12331
fola
Post by fola »
I am currently also working in a similar situation. I want to generate a PNG image inside Processing based on the XML files containing the encoded base64 png stream. So I started testing the image text in this online tool: http://www.askapache.com/online-tools/b ... converter/
But so far I have not been able to generate a working PNG image if I just copy the code from the resolume XML thumbnail file. Am I missing something?
I am copying the code between <image data=" and "/>
for instance:
Code: Select all
12618.IBkSG0fBZn....PCIgDQRA....J....dHX....Pchl+a....DLmPIQEBHf.B7g.YHB..f.PRDEDU3wY68tGjbcceemeNm6se28L87..CFRPBP.RJRBJQJXYIYKKSYIaUQVx1xQTIRw1k7i7XKsIQtrrS1XYCH6j33rUbVmDuaJGWqsryV1lbq3pbbh0VwxjxVQOohdXRJRPQBPPhAClGX5d5W2Wmyu8ON2d5dlo6Y5d.3Csa+spFX5aeOm64dt+t+N+98676ALASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvX.QlF4pkekdXru3RRApUa1WoGFSvMRHRQBBtSdLIyqzCk8ExC4QP8aGQl9U5gxDbi.h3SPvqgq9s.b+5BQxQPvcgH4dkdnLAWunSmaCQNzqzCiwFhLMAA2Ahnekdn7RI9+SeyQylGEIuAkZ0a38sH9HRADoHh3eCu+Up5XLMoSma9FdeOAuL.4ZSiH24MbNHhjgqbkRoDe9HhW5eWBQxBh5F30RQmNmBQl+FVeNAuLfye9bDH2Mhj+FR+IhBQxkRjkefD0hn4BWHOhTJ8+uwP3KRFD4tPjh2P5uI3kXHhlf52I0pMyMj9pG2sbHi.2MAEhjEQJwkkhHh20833pWsLat4c8RxR8SvMXHxsfH2z0Ye3mJaWIj8vzMNBzgyo6wjLHWoj6y0IwiHGBoyIut5iI3kXHx7HxsORbpFDd7TNWihhEtkk8PDMmceVtUDOtrTjqd0xobGOXiOQNNhbzCTamfWhgyXy28dxwZvsSkJyV4zka2eY2bDe599tdzVdVzoxPVdnxRtesOPdMSLR8q1fHdDH2EqtZkwnMckuq7HKemqcpAR3LpDg85iroW6wSNQQxSX383z3dBd0A5z4jHxQFoy0IeWItpTlG+wGuGh6lymZaDcm8rZN6YGWtZYbimqVdj4dKxLNSLMlWqI3k.zr4QQjSrumWONNGbEB5pzwi8XY37mOGm+74PjrbdIWJgz3S.1qu8Pjhr5pUFINxhbyzVt0Cz0ZBtAAQlJcOSG7RXNNT4QjJb4KW7.aaNo1rzoyInd84F5RlxC4TznlLChbqHxgOPWqyJZjKUf0VapTQDFLgnHJjfamM27aoMR825ZWImLPGib4dNTJyN9MEMZLGfGPadhmHj64dL7nnQdDMOJvC7.B7vvCC7fOnLnq..rxJkfJ+NjUeBxl8+LFySiH0QjX.CIIJ.MIjgiXJCdmD3cAXQjePftaC3tIjd3GVwCB39GfGM8bNVDyQBPNfCQiFP4xqgRY2psJkfHWjbp6.QZiR0dbmBmfqGDDb2TWlaWG2sTVoTNHY1RNscJu1nhD4m.QrHhfHMQLeVLx+FjjyhH+NHxuOhbNLxuFFyihQpkdtBQxGCY.Dd6E143UDeVUpjJ9vtYXHREBCu2C7R+SvA.wwuKBCes653hjkqHk1Zo1w8g+t6u6.i7LaQP06SDhYYDoi6ukqfHAC37VAQdiWWigtbNEQgb4hLHWzR5baHxO7XoM8qRv258Vib4h36eZz542xTDNNEE.zbTUqsVpRgbf35Aj5+f+Ln4TC3Wy.5i.j282r.tkK2INDX+4QpM6AZb3ZiST.kRPcSsSOdws5OQ7H1adLw2CMZb8u8iSv9.2VssHsaeKDFduHxgQVsBO9dXWrw8guHYIN98gwLHtZi2GiwRRxGN0X2i93XuNWmojJylaNOggmN0LTGBQFzKKSvMLHhGAA2Ic2BrVsVj332NsaerQnsipQhyhH2FFyW45l3q2mmGQtOFUiGOJi0q1bA5z46k1xslNenvsMjS7h5WxvladH55nAWUJmZVDOZ29Voc6acekAZ+ssVlTkW9WcCj3q6m+untL29RDt+iQEsZcyzoyIcN6fTEQlxQ.13vz55zQLlfg.QTotndksVxUDEOTJQmHyk57lE129YvGOCxkJPb76Awr4HRTcMDY0Q6bMwHxOANa6MXhv8m3ywctYyER+tlsqobwz8J9a4TF4U+PjpD05LHxTaQz4NtdKuPVjhoDg6sv367AsHY3RWp.hbaHxmcDHnhQju.F4WAi7KgQ9z3zHdejGTdZBCec3LNd18bLs6wbEjNmh0jo15XOzC0ad3rhFQJSXyWGi51RNAiHDQSb7CLP+gy4.n8zl+QDe2xwsVbOen1SKxLNtRaTEi4WYj3lkXdZLxuIh7KgH+RXL+FXjuF8rW3doTxuMxlGZabB2OaTJxgoSmSrMh1yNDmePjiRr7NYb8JnIXHvow2wPj2zdbN69gQiFGI8g1PdPr01z473433efzkT2KNXMHQdXBC+PDImwoPTvsSX38QRx6m.42lj8cI4NjD9SfHU3RWpPJm2gIVfGhbLZsyWlFhG4r0OG95Q5bJjwzYKlfcfd9N2IX+BsxA6hTURWVc2wDrivdZDY5T2a5ubWKyZjqfX1.w7hXLMvX92hD95okrXJQwr37LkihHKPivSSn4iiwrIhbYDoFFyRHR3N3B9jDE8FYMYJ1Xip6Z4X23qPZHkVcjtW29u2MjNKib4WUGKIu5bufcusWjkVRXwEC.xBbs8qUHhBkp295pTMPj.fEQjBaEdlh3yxKmiEVHl5AKPor+8.dK.fkHv94QqeJzbDr5YQrsvSeQhieXzYuBEQfhI.NCdu4lQL0TYfnUQo9SAuBX40i1pPSBXeNr5aC36DMkPquKr7Ofx7KStpu.fOhHnTw.PMYVBXZxmeITpfcM2bt8cFbSfi.DCKpReAr811K4WkfabgP3MJ31uyBvSDh5zQr4lGBOurTpzkGg1pG3jryzEKftTV1fUYQzr7xBEJjibk+.jw6eNJtFZdJfGCi4p.fm2owZ0n0qSb7+YxjoNsYCJhg50iX5o8flZnbDzLKn7HrzLnoHYruafE.qOn95fWBFyrX8NCF6qgL5aEO9UoYy+8zrbSV.Efg1LGNdVKMj6kAeOtqyayCAdYPUZoslSeBB4zpn8ssuLhWcsUbhjm0Vq.PKTmNBQTjIyzTr3ZiZOLv3yPoDJW9JTfHNLuUB3HL8zySkJ+CIu2uJvEA6mDL+QX3ah38Mvs5PNzx2jD9bjIyRDFFSQ7nNwL8zBzNG3kmZ0.JGCJM4HgLrJI1OGneJPCFuJjvSAdW.w7m.5+TfuNV6GihE+EXAVDXVRRd.zAYPodwg9hT2slaeQkMHLoLh3gRk.zjCQVt7qtVR9UGDfhnR26UEG5PM5axuB4IAkJbj5GkRF5xSh3wFazFedZxv6mBE9sQq+EAxivWBXCvSiM9IfjYPodqX3qhw6BXidNZ0p6XvvzX.rPw7PghTspM86IPnhVshvXtHI7BXjuHJ6YvmaACOIdXHOcPwW.sNBs9Ci096g092Ai4hDjeCFtCytcQL164hDL9sApt0byQTMYwHapSu9phm8uxOHDwm0oBqtZDJUms8aAAyA4Web6wcM459dIlYFCIba.+H.uszesIZ6Jn0OBIbUxnNJZ8OFh70vK4oQRVirY2.kRgMW.saCrQZSCyQTTdXC0VGqSt.TJEFSS74J348hn0eZfO.5jShjrIvif1bEbxpAZ8aD3GCub2El0s.E4QdjsSDNVb+RQwhqQPv1sIp5DAL+7c.JOPkedYFuxR.510hBLGM4zmd6xlHWHO4wCn4X0mc4B1yNeZfJTutGv6Cs82EOt69ZQKD4oINtIff0+ifkUwZ++AHC9Iu.fPwhVmBJESkadCEQJeTJeXFfYDZglBDQwhFJVTHH3JjjnA9Bf8qgV+ygxOGwwsIQNOVa8sFEZ8wvmeKpV8mBZjk669bKe5tITLNb+5MWD.XPjJ633I.M.xxqvYbgWYH.O6Y0tHXaIEJUiAJuS6COGju1XOoCvGWYAbF2sVsonMUnxz+b.+6QqWL8rDfMwZ+TnTuNz5uK746GMk.6eLYxLMwxJz11g1n.hoDFncJA3LfRkEmF5tiUBENMiS.f74Cw5eYRRlmD6+Mz5ln79gPm4Mh1+6.MeZvtNc0lFlAOu+WgJ+ynZ04nd8ob1Bbqw63i74WGB1si6pTBJUSbdtcEjG5Ujsu6keyv3LLbAdhmHfCc5AqQ1i7H934UBX4qiqjlVslmrYOF44iglef99sHfkwx4wZ++FCfx+eLJtazl+knTySjIfrYdFRRzXZFAkE.CEKZwolp.jCkpOuOoMolmQvQDlEavFn8OAJ0QI17eBOu+In3tPyuBXWEzK.bu.GEm+EpA96f0dWTr3u.z5ogRWC0AV60FDpNBhjafxRqTAHRB7fkPjfqiqyABu7xATjhr95EfArja+3LmYFLlV6JVOFKzZdJk+cSwh+tai3yRCfK.77n4Iw2+Rn8qixFf19MAuHTp6AOuY.JQgBBkKm.0Ap2kKT2kDygO4odcs6XEcWA2BqNEUxmuHJ+oPotWbwNxSAjPRxlDYuJVdbvdIrbAvVitb5z5uKx386gI+GjNrvdtUc6ETJgbQ0f16lKXuyo2RxuLmHOe4g.zsUYKP854Xt4ZMvkb6ctJpToJqrx3p7Qe8QmiiI+eWrp+U.ultGEXMzbAfqBrAFy2jvvNHligVWkX42AiYMD4IwimERNLQTEBlAlNOLsNsez.Z7oHI9EQq8f5ZGGvM0LM4ffpDwLP7gPRVEQ9hHl1f4+HBFT9mjrYiPjmA3Zn4p.WDqcE1ZIY8wvy6eN4r+zDFdmG34C9xa.E6SlxA.mnNs4vGVSqV2zdnI9MT7xDGv0JADjZJito4LWNXwsWnYS2ZLMNI5ENwIB169bHPj6Cx+uDOueQz5tdNh3VtydIvdMbusuNdxyStb9j06sgx97n7dFLFe77dVhhdAh7uJYoFjOjffB3LowT3X0kEip.JximWNZmo.TrBAYqR.Eg7wt1lYMr9WDOuKhmmEs2UPY+p3waGn.h2KB5UciI80.8kvI5Q2WRygV+QHStecjn25AZNQ81RnSmPfCkxLvGQxlN2WLM4IUBHOKQBECaxFaT5.csFS7ROA3EtPdX9XTpZbS2jK7AUpV3XWDvwNVBtkzxx5qWljj6CB0zKsUjqOhy8Fwx6A32CWbN1+42AzKA5ZftIPMRrqQrrJIbTf2JZ8eAljhnytFgbEDwfMnCAA4.ZQ9f0A1fNcB.J.LOVtI7LGEe+CiVWjffXhxWi7rNPCBBxBDPVR.VCwaITLEZ8mAq80AbRrQWCq8pXoFPKbll4JXo01T6Py2G1LeBD4GcemG5Rj4BbdW5GoPAARdsTu9zr7x4.Tr4lFfPXA2yDkpM2jpMpYqyLyzg8y2JuAfWZYy5Xi6kRvsc3X4Kz6McWIJnLKiu+ykdDc5mb.dHBrwFJLFKyOuEv.Oi.yjEl+uEvuJNNTcQRpf9wfMFzs.6ljPCT5kwW2D3ch0ZvZeV7HCR7yiMoCEJXvM+nnM4onzBVOgBy0.WfHU.sGXLZxJsg7aBXI+5wvb.T.xqH.C4IhN.dbUzT.XSz5qhk2AYy9uCi4JH14PqAMVWey0vI34gwooMn43.+GHI4Vwy6eGPW6l5AnYiM7XlY5R1Z31u8z4HhAdQBMEX5oMTs5tedr6mOQo42vruTpXxKcb.EQmtsZid.SeLlkbrBJUR5mHTpfz2N2DkZSlYlF77Oe.PBKurGb6EIdlOBv+V1NwG.IfdSfqBZCXa59tdSvbEHNOVdKf9+NNB7WjLYpSgBQ.A.g.wnHCnSkepdO9RRxKB7bzyDIceYRSmN4PHl7DAzAaqXxRSrQWjjjB.eZfy.LGddWFMahi6WCW+XWI86w63dJGdd+xX4WllMqxJqjgKhEHjYlowVySt4rNoygInTVxk6JNi6Oh3lTswYqvWxLQyKkb.Kx7y2YjsimH9DtYIxM0da5EmBLcePGRsZ4nxz+vL36k7.mDmmzzBzc.pglPrxJPl6FnBZdRr9QjoyUfLIos0j9IKEPn8z4IbiVLis601GeYYhkXLJehZpHIwR04bW2BErPqDnTD0AltjPaZSwrcHI3PXTWDTFPd8Da+Rn0cvZqfVeHvtHVcQf4Pyf8mQM+PTt7uFUpb0QZ90gFjmCOTSxLXzl0VqDhz7.YS18AuzvAzI6Pbp58iFZzXFx42brM8xzk+oPy8sGmgOtkwNAX+NA62CZ6IA+ovxa2sTmI.edAnPGb1HreDgiKjlYlICXbu.DFlkP6ZXLqP1rdTFgpU6trsuqMIQPcgoQ.TTjHZzHDi5RfWHJ8UAuuKTpifRcLz5uafuKPeanYggR74vMi09ObrLOiRIPbcRkQXDaik4mOfTaLciF234.JRVVdYMG8nc1+Sdq1nffog7uvXdstOv9+T2uw95dY5r.2IvMil6BmOyk5oMc1.JXADZ0BJknXCqIUlJqyG.ICLui.Uo7HaRM1LIj74mBJCquth74yQoRQPsH1PDlYFg53gOJJgkJBz1z.ehPyhf8lv2+jX4VvYAfQ5NO894CRRxeBve1H1NfJWivvSl5kLi1K6JULh3yEj7bB0Ay5DCA2XI.cxJjiEVX71+VnBLFd8B.xkJfM4mAse2XBdSf0wsiB6m1akPy8m92KBd+TPtaB3yA7LTR2lFSmvLoaoFqKvbQ3HvyQCDxgFJ1ho5ii4bYyBkbxigQ1hbZZzzoSFnPYRJdJxodCn3uFvY.sFXwQbsnHrrDZpfa444QzeTD4+AJ094vtNnTFDoENSJM51ZUo5fbUW9oYbVY6kM3BrlJGHAV6z4DrpL5Y2T.RR9PzMjHMlPLxWBi7GhQ9yPLMX+BNnAGyGcPj+JLleehh9YIJ5MiH2LxFUScgoonor.RqEITtebwiaYjv6Co0MiHKfbsoSCQxoQjEIJ5aijj+mQjOAh7kQjlGnwlHcPL+EHl+.D4yfHsRGyahj7QGq4NQx6hYjwb2UN6Y0rlL0MxDi4MxhpRIbx8MdprKRdH3lQk+YgQTH2.4NHm8+HnOCBZT7Lf8qC5UvIy1sA7cyt0JdbFWfRdRv9Uvn9Z3483DF97jyTiPuxjK2Q.dZZfkJbmP3FPtZ.kAtUf6Fq804jOUeub8sZSGr7eGreC.OPOGZtGf6FPA1mhXyONYy9EF8dryIHe90PoZLViDQ7Ys0JvgNz30tgfaLKAeAIOfb.sWzbPbMnvnpsbVr1eZPeO.ZDtFJ9lf9ZjXCPqaA7UvYir2EZNH6so37+O0sfVmEO6sik2BYx77Xzmmb5qhwLMsZ8jDGGio5I.+iALMpj6Ds93fdAzLGnOLt44QPF0AAaHveFZ8WEKJb1HrNNy+LGvQwxIwy6ihH+jnTaNRca9Vqm19wiPRoRvEWzEuQjSBu9I.cFaNyX+lD.xi3SXXIxUYL75Ey6Es58hSqrDz7r.qhk.z1Pz5.LlVf2WDOR.dur+xDZwIeUHZZC1.P6kZatK.5KivEPrOM1nKRPoUv1HlolpF7vP8G7+B9sxQlLyQ1ru.vcf0dJbJ6zBXdbZRmGqsHZcNbFWduEWwRBZ8mDi4yhmIDgRnTZr3il0AdVrLaZ+81A9wA90Gs4w4ZP3lC2KY1K37flx2HLR802RvmUzbNJCz7.EwUat4gnRkLnTKMRmuH2FV9CANCZTf8xf9KBrLVaSf1H5F3QKvDhAe77d.f2OC6kMKahl0.aCmApsWCzKiwrDvEw38UIfKyTTaaZM1uVjOj3w6ea+lFXJBYQ7ids34cRv6nXsKhVOKXmBzNEIFtluBveBv+UvD.d4.JhwLEJUQfxn4PX0ean4Dty29MAyG.U1u7HNeNOP1Qd9e6sUATgGlVa6deLw0aBbrBPvVgS330VEgadJxM0kFo2.kGKC16+2.z+j.BZhwsT6SQhsN9zDzMwPK7nMPKRRBQ4WDOde33DtCXeQP+MwZeZDyygj47X4YIKWFn1930N8H.c+syDNC6d0IO5h.2FFyc3HJ4NvxsilagcZSVq8QPjOAdd0vXxAdkvRQxPIRrUPSwTms3Tf8M.Z21UB+w.+HoNa59LmJdDFdRxk6YOPt9lHdv5kf4ZbPMR8AeIXQJxRX3lN.De.v5UHWo3Ql8u49de3o+QvRDZZB1DPeURrcPS.FcHdD.lHLDhmW.99AjjzDi5O.OuiB3xtBVZA7GgH+I3wyRS8EXJ8F6hfywISFwI2gQ70MLJqm94a.x+U1fooHmfrbbfuWf+F.yl1pugi3StLfFQ.e7.iO34gu1Gq0CmbtqBrNVJilb.uaLl+1.+q22QbWSxzfYXK6gNFv09PfRLtgNQJNXDft5qgG2zAPtusPo4Xsli1MsHm.q8eJNtDWFKEPyJ.WCstIhoCXZggN3QKR7ZBIMAoC9YZSTzUwieerpXz5mBw73348afxevu0KnPgjR3L3UI9xeYMhzaueEwN.B0gDGGJgYnFNN3eEf+HRjOCd78.1aCi7owX9p3kE5JqqSNUEFCoiIuTkRpgVeEzbbrbMzbTTpedhh9KIa1GaDlcWmJA2LHqOxVgXa2JpPm2Jcg7nFeWn6fVyxlhCpbet16L8B4e18k6hH9X42FMuOfmALalJO0W.s7Mvvpf20P3ZHw0HSl53darM81FMgnnSCjfW16EO9rnTWpuqgadPofcxIq+rsv1saV23ssqhX8Hl6+7248W+8Q++lHyB7tHL7KiVWjLY9qfG0BOfOaPNlgBPPYH+TjjTEXVTpYAlGOuSg09VScp0hf9TXsedz526HsT7A0jLa+dpBvXuT73yAzESGlCLwmCyQi3ZL0dX5EQTbQxgw72DO0w.8uIl3mAuLMvXxgm2eAv53sbaXgv8z57hTEIaD4XILl6kK5sx.NqtATztOtHNhysSvz+XW1wuo1Qa6Ocg3BazycNW65hyctZ7w9XADGuNYxX.ph5ssBNteA.8hfN20vCmlzkfvYPm6SiSFvL.mBs9LDa96gH+uCr2NER97qm5kLGLBP28Tb53Y7zndrQ2si4.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.2cayfHuABCu+zUYlNs95Mtk3hxGXB38oiyx3FjJOh3mlY6cNVoK+MOdKg6H.c43t1sO1Hyh+rhljjeJhhdqtLeexGHUNGceDfpzGTiuG7rcB0Chxb5AP7qoYyiRR3GBo1LDF95IQ9GLxq53JcE2DWKsfVuQ5b2nhKbg7okAityK6eV8e2igbHR9wpMiXGWlwtBeiZK42jKWjffaej470651k.r.ggmdDaSE5j72mD4q5RWsxLHx6cnDJ6T1uAUhu5dr9WBtGwbOBo8q885igWgOiie2zp0hTStMhkOGF4WFY.0EuAgffdUT8wk.DHMsF6ZurQ0w+YtnFmBG9n04tIKYrM8hBgom1fH4IbwalbMV9.ZrSAvirYqwdk7sEQiDbG.uIzrIh8SAjPTzI.VdnlpwsMT8lK5Uhu5Sq0y10VgcM4R2sdy828NNaSNut+uZGAY4v15KkRv2+hjo3IPgGX+THlqRPvYnQ38tO2+djK2laMt2cx8c+Q97Wgvvi53hUkw+YtRHJxrmiy9vnQ.tzR4X2wJwnhDZ290gocKTGHeHK8M3MyArJqwfYu2PNBwwuYHmF3OmrdK6h1srMAuy.cVZe3FX2EmrsFAJA0GezePrUspaG1FbKMlO2da+SXYzb2jOJK95+bfMHe9+aTNaah4Mxv0VMOv5zngeJG2AaBo8drGPtbqQmN2OCa6E2Or3hgrLizR26OAnHJVbQ8AxgCbXFxl8PiTJ1c3igLvTts8IYY61d6RjhDFd+jK9XjIyWCk5oPoLXLKPT7R.MIq5lgmbosteFjc3bDKNNg83lMZO.d384260eZ3LVTmS1thN8MVN24TnTqAlCgHI.WBOlNsOdVxviQTz7DIeaH8UyPDwiUPgRERkJFPxP85Gz7IyZjISQbwLyAo8FVft6k90IbBUdvL8hH4Irw8RqV27ARPeWeLKNWeuqQV8vYp.McjSRTzahlMO5tZWRxGAW4c3dII4CfH8WcgFr89586ixKl8qDxnb958TtOQ71VUeJN3uNRz2IhTkjjeNdrcrjlHySTz2dpLe9z0ld.b4KWzk88qM6AhHvMdNZZwf7fY22tUdp8AixfymCxxuhnIL7Xjs7EoXwMfQik7tPCzzrYAbaGk6sqnniC78Qd7HSluDkKekcbsKAThFMBHI4j348YnSmL3bfRaetQ0tIBU8kaAuQgtxSNH495pbhRY38qLHOhOc5TB+b+Ef5nvFtnw6NaN61ZmiK0WBQhHI4sQb66dqUoVbw.78yAdGTiBmg0WuEYy9LD13fknhTpX3XCtX5zG1u5MgOcEvd7whjjzHcCtif8LFWGNpzNOkK6kFZfEQj6AkZZBCu.J04ScInsaus1LCddIHUrzMsTTnvJzrYOiX2cYwASD5VJdjHBUvCuGxYIn3QezAGBjNkS1trhMNSUJTX83tr4q...D0mDQAQETpUIgMgYJfGaP1rGZW2mJkPgBOGIIOCjIOh75XUoxVxfF3ePik2rL2btrRQnrJAA6e0Hcvvv97be+nryvAg6WsZyRPPVJW9ESORB0q60mrViNh7ODYYEjNGGm+xcExj4Iod8p3rKYWNi852PYNLrFSwBfb0zeKDWrLTdadHRWhvcNtbD1dzuWtLHnP1aIEEMOv.5iAcMkKU.pvVwZgu+kHN9VHSlUHq27CToF2ynFnTeFDYdlJ5THRSf5DyQ.d98b7OX3S2TpxzSuNR6hznwQFyrv.3ncJvdPCsGk6oTK4OtdJqH4Ie9CQ99BxbkxYNlw06aDYF77NCIIuIhzSC7MPobK29U9JMX80yrcyejhrbT7RVmjjaAxbw99kZzp0tySdC1cq.mlwCS10tIN28f62VluZ2dJy.cSqiMEPssN1xK+BnrKPBa.r8cDYq66UxxS7DMv40MqR1rOAggY.dif4L3pl6iNjGxiZrCyuT3xjIiKDTGGnTVVZI4fI+uS4iw0J3ZD4TCzPjcqIaiV+jEQNLggudhieaDIukgbd8D7d6G+GGQ99Qh+A2EQ0UtRI1by42iq8N8TD81pNm8ebQToEKwg866La8uWDqU2lVscQb7eMD4cPh72e.swCYHF8MRNCwx6fnnuMZ1L0tdi.bkGsc+bxc76XrkGTDetzv2As8RFvz7axXfNctIZ0p4PhYz8WNPQzHaTkFMlh1s8Ia1mEe+ySlgVltBfAXWPioJQloHVVYWbZN5QaAn3RCQCscuTrkGjwyjBtyUsMtHxdjk6cdXdNTCve778uDln4ASoAvPHOL+f8BYSPc744XiLOEkJ4JSEhLCxPbcrtXiMFrMecYb+0HH3V1y1u61kPlkGp7zCdRUjBrVp8vFUTq1rTP4S4xCNDKUJC0Y3lrPjRznwrP0PhhhHNN.kpNtk5FrSNpTFXEgcZWPnDdTkLY9lCrcUprAG6XSsuJYzuFpfJ0AC10Isi6CECZmNT6gjh2ysVEn1P1knKhW1R34kGZ1auMDwCVa31mMe9.BvUbZbNZpAtXG3Allg4v.hnXlYzzMK+uSnTWi74iYbqGwVqfKtQ1EFLwP854IeyQWCptx8seIWnooqWy1eayQsZyxZnYpoVCPQl4xP0pNtdsaqgf8PNzC2g94B5z.dNbbuGbLm31RtNPso2ywqSAidDgm6b8+lbuGfOZeaY2ix9q3R+PjxT2L77hiK4d1.qcVnb+ULzBCk6G.zxr0rR2fUesxYPoVG2aMyLfkkGEqdbYBCmZb1uWVbw7Ljrq0fI.md5XJWtIiRQLoq89xk6x6oaw6PDafyn1Oxi3yFaTkMHOSOccNjpAxExSiFEYZUujlSwhtr+41MAQWiI6mdOjcqkmJxgvZOFhbg8YhrATM2.kgrercNWFFTvj+.a8Wd7.igYqDwCZUlomt1dddQQmGQVjjjE1pcMHOOwSzyad1tG9nSY3z6dSopQlLNG.1QTWi0IaprmcOu8eKWcI5xWfJUVbjjGzQjGRur451vd0AsAxy9G472DIIMHe9QIr7RXFpPylEADZznAKPHNBroHHXN5jeYDo.KsjBeeMwwGiL4AWsvxkxYWYEWF+iC2c6x5POtN2BPU78+q1yQhy7K0vEX3CJFQFVar8Mwq.D9xz0krri4l2WkkazfiVduay0t1yvgOrFOuSA7o.DpPKtm6wkBgWYEU57AoooWOhhV.scdDYI543DAjK2QQjMApwbzFdgLz7XyfzziN3SAtxPGG8lGBnVsUQjaAWJBYvPjLrLdbTUKFqcTo+SdubyZQlkNctsQuiAhR9YRcM9xoZFW.Qpj5qfSwi+3Y66sZOjfWS5uMDYv113o.F4O.Q9sF4wia6pFOyK3FetLAlbVcZ1vZ7LztHEXyM26hvc+vHebLxmBWzysW8aWtfKRX380adT7SmaKQ8faGQpllk7cVmHJ5LDk7KLVZ41t8w1la+u8wQWuxNU7jqNhNppavWZaeeUoxtRIWhz04EG8ArqBf+UIN9sus9eSY9csWmauM27Vm6vG2GAi4WGi4yPPvnWSM55Dmh3mZRk9WlWyC8Pd88Pz8f7QDeD4voO7xhHKfySZ72w45sU+b1crD43VKNZ17nXjOIFym.YOdoumyMLOAA28PNGMat47zu4ijv6Ew70QhdCi7XRDcpS9VYGGOklo+9+JkXjrGnaRqzNNl+13R376ta+.v43WBW9w6WruGFyxd4rCNteKt0M1f62SSr7ul33OAQQmYf2SO1ikgGWbxJd9ymKsDFjiKbg7HxQIPtizikI0U46mXR2W7erSGKUuiuuS4TcDsxikIkHMKhbBZ29Voq2C20lq89jYfDmc5bJhi9svH+FHQeGCYtvM9pKyQnbOCcd0cMlaqwuH+cwHafH+eNZbp1pebLh5mAxUjcaxncFrY6QG5BVkce7baEvIhbKLtph2VtELxyiQtFh7GR612B0pMy.uV8i.41Qjdd6xtMT76f33eED4eDhr6GJhnbdFhjeKBrsK3dWtSGE4kgh4rHY2x6f1oBU8HPykNl2sHGh7ZII4eDFy+Lhk22ttW6wAbFjv6ceFK4RIBmCw7ahHKgH0HL70Ol2SyPmNmDfsVVevWqQvqp1Ke52sl9IQjSMVCP.RjedbYzyWDi4SSRzOOCxx+65ZFbmz0UpbigtSvZjjeTRR9YII78Sb76Xn8wEj7rexn4H.NxX81+AAtkt26GDCiIPue+aGI4ChHeXRR9va0e8O1qUaFBC2qj2d29p.IQeXDyeNh7btmQl+OF64AGSo6XnOScuXsK5pAIT+vxP..HjjbmLtUwx1suUT7AALnIFsbR7x752iqSODlykg81ZzoDbxb7QvXDr1OKhtEYxL7D08wIjknWr6dEoDqs1TbdI2VbY5Zav50OHNx9nAmsy5YyutgFpSdo9kiZucBDk5KRhrDvSgm2KhgeVZz3vay7OSOskrizNoFix6dwpuSbZJGgV+d.dci081S7DKSR3IY36101C6gTLHBPMO5.HL5ZuuVs97Tq1nU5r5hrE9fn4j3rv9zfWDX2fH1eNopHMkn+My+DXs+iA9J3k8KgUMO99ex8tOTBKhYKYPVfXxOWItcxgqxg61n8kVJgb4pNzU.tdfHYn77GBHLMCELEtz4aNlmxzcaOEwiW3EXW6jxNQlLOJIId.WBKeRJV7mlvcrjab7nnjys.DglMwxrXw.1E.9Pb1Q7YrHJtm6o.MZ+YIL7HCY0lAlgXGvEXYEOv.H.6z4lIW7FTs50nZ0Vr95ilBHhb7z7yWV15Ma62.KsIK24HPH2SyoH4LX4mDs9gnc6mljj6lb9exQzich1puTpHtHqSsZZbaSUCfPVbQPDCDeuHR0z3h0erWNxce20HwE3ZWaZZ05dg.MKuLb3CGgK4NkF.QWbiz8ZEt3EyvwN1n4Bb99eJRBWjLTCs9+.99OHwwus9Ni8WqyDdMfNA3oPaaBjCzdX46myMhbAWYEWwnb1YqSPvxPvwXmQ+3PrO5.d3qGTFcZNTJOTo9ClREybyEgLBQAuw7A.tC.EVB.6SC5qllJcOJolTdnHa1B.YHN9G.s4chl+2nEWkrY+Nv2+SsOFIuG5FiGcyiKmVEwpU6.TAWhGJFkpMEKdIHykXS7HJxBobIWc0JooQj7CQ4.cpF0EwYcfx31hPgYlAJU5pTnv2jidzV3JeV1TOYIdqzZVOwAF052gA+b+YjjbZB.z5eUT92GIxOJMIOF0dqTkHSiJkCH10A8SgN0gHzbyX4GaeYPHWp.G9vxVOGpV8ZfMBY.wSxJqrKOMe.tKzV6tP2iUfvv42l+84t4CfETtpg4PPG41vS8WG29BIo0pWWfBAw344SL6mgrONI1OJhbB7790.BHez2KQ0+bLpIj6dHhie7dKKcGpPbNp5NsR+pLEY43GOBWMWqAyOeKVXgDb6dTQjUqjZtghrpTg0nTZeaAZiR0.kpIJU.snHtZTbeWgUq.QFTpdaQ0y7LY33Ge7b.XkJjl9OJZyaAZTj+S7uAvih1+IjQcW68rQzwAJ.1jzj14x3x6zFf7n4cQb7v0HVjLvwxvtJFkEWhvvJHqscERN7g2U9VbmxHnX49zu3gdHOH7l2i84sEG+3UPjjA9644CB5WCNteqilKhUuIVaDZcLZRPkrHCOiqqnS76frdUwJ+tPzcBY+gQx9kPUTiKXs6i0dcfocu.s95ByMW5VPsLvBtiO2bkR0Zri62v4oKhbXb0TttaaUSb4v4UciDUZAngtJPnXA7.TL+dj9ypIyRIB.Lz0MsZzXVWjqQmT4kT3J.N4AZgHvxKqXgEftgV4FanYlY1dXVVuthoUtp4oVtDIk9H7829OlNE+R3YeyjU+8gH+VLnDItHYHI4XXwRFIBqJDKMQykv4DqKBbq348gPjuxt3JKhlZ0JQ0p6lIfRYQjKQHGGQ5rkG6rzRvhmW2+yrcxdUk55LN7te22DjqNCKIG5lzaA0JOfcJ4Nvk1YKgS62Khqx7DhOgnIDCInTEvUci1MBjSgR++fX8+KjM6ygw6dIN9OEe9jTnvZvSzvc8oMuvKDvRsBwIqWBFSurWJK3C0xR85EPWICALOMZLETuBMZTEHGDcDhhNMsZcXZ17P.EnSmBHOTeVyuukObdjbR5R2CJ2.596ooHsZky0mMmG3tHWtiAjAZTEWhcrB0CNDUHK0qmGHKKrfOqutGqslhUVQXlYRb2aKEBuP.PaVYkVvTMXctF99eFrI+Ajq3ooLWkqE+OESx+EhiesCbtsc6CiRUgLDigHWeaCwsm6WLcdLGneO.e66p80pMEUqN7jTpRERtfU.N1VyIKtngm3PaiNY6BJ93RVJcQMm3DAH0mi.6TTXlKLvKP+vY067asjnHJv9u.zeT.cZoG8Kfkk.cCv1BsdSbDOMHN9RjIymismE5KPRxahV9eMlFCv8SbmPxV7ywYOqlyctQM2MOnwaFN24L7w2Qvlu1ZSgLm37LmcDyFCxU5EIOKsjlEWrGGvAedpTyGUjZ0xxLyraue45ojGz+0LL70R1rKRM97HHTI49oUquFUqtw1N+33yPlLmBLSgwqDdlJXUNYW0bDf2.ncAij096gV+StEmrUWsByOe7VJNsWvYzcCkKekT5Dc+sa6bstGTzpkE4REHL2bju5nU7.cSbI8RMWg2EV48A1MAqKwba0WFXCDScDoNPCW87HoMJUFpWumu4IhhnnaGe+mloYCR3MPRRFxV7yA.e7OtSk9Cdcr0vC9f61DEyO+lXWQPtTgARbqTBOzC4w0t1zznwgg5EYwEyAbHbt0j2Pamb9br959Cg3KCO7X3CgausNw.5dcyk6qCw0nbx2MyPK78+qX5oussMWsBkHSlBjjzA7ZBlFX7Retn2.q9J.eCfM.aMP+8B7lcWuKUf4mWFIhO.JVbI77JkJmsgW3E1CY.u3EUbO2SBvhja8kQkezKJcJUaDwYDWi9sgGuHvmGKGF3yhXVC7ZiGAjjD.DfHgfDfPPZj32006mlrYiQoVhVsVjb4lCO++n9tZcCoR8.43r+iUKt5u1t03+HGoYpcA6UtY6+7dmOXULajP4xqSu3KViygKmCXE1Yj10sHNN+.TZp63ebq0Fca24NmrKN4mKyWjyE9CPn41He9ym9bwM1.3vTDmrlVRRZBjGRxgRUHMS6W.jkwhAMah1NGv2Ch7WR854opZCFU3lqeQB3lHOWji48R6NMMASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvDLASvD7++D++Bnx4Ky99vKy+.....jTQNQjqBAlf
So basically my question is: How to create an image based on this code?
fola
Post by fola »
I hope I don't ask unsolvable questions ;) Did anybody ever try to generate a working PNG image based on the resolume XML files? At this point it doesnt matter for me in which programming language or which tools to use. Just want to create an image from the XML file. Any help/ideas are very welcome!
edwin
Post by edwin »
The image is indeed a PNG Base64 encoded.
But the thing is though that you can encode Base64 in several ways, we use the JUCE c++ framework and that uses the following Base64 table, and it turns out that's actually different than what most other libraries use.
static const char base64EncodingTable[] = ".ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+";
So only if table this converter uses is different than the conversion will fail.
edwin
Post by edwin »
But JUCE is a nice cross platform library so if you want to start using it i can also send you a code snippet to show you how you can decode our thumbnail files.
Online
edwin wrote: So only if table this converter uses is different than the conversion will fail.
according to the method source, the encoder algorithm also stores the length of the source string at the start of the encoded string followed by a '.'
now I just have to write a decoder for this in java.
