Advanced FFT Audio Input [Freq. Range]
HI5
Post by HI5 »
Hey,
i love using FFT audio input to animate stuff like FX values and scaling to the sound.
1:
I would love to be able to use more than one FFT input.
If i want to represent a DJs Deck A & B i now have to split stereo to mono and use y-adapters in the mixers line outputs.
So one channel will mono represent DeckA and the other channel represents mono DeckB
This way i can reach my goal but this setup fails when it comes to stereo effects in audio signal.
2:
Would be a big thing for me if i would have the chance to let things react to different frequencys representing the Low, Mid and HI audio frequencys for example. Using EQ range as a gate would be a nice thing. Things would react to a baseline or hihats for example.
So i mainly ask for a FQ input Range setting next to Gain and Fall settings.
Have a good day.
Jan
Re: Advanced FFT Audio Input [Freq. Range]
you mean like this? https://resolume.com/manual/en/r5/contr ... o_analysis
HI5
Post by HI5 »
Yeah! :oops: :shock: :D
So youre telling me its already implemented. WOW
Now i wanna stop my regular work and give it a try.
THX a lot for the hint.
