arena6 keyboard mapping
robthirlby
Post by robthirlby »
In Arena 6 how do I restore the arena 5 keyboard mapping defaults? Alternatively how do I setup a mapping for next/last clip using the cursor keys?
Re: arena6 keyboard mapping
The Resolume 6 Beta 3 doesn't have a default keyboard mapping yet, the next release will include a default keyboard map.
To map the next/previous clip lunch buttons first enable layer transition controls to show them.
Now go tho Shortcuts, and Edit Keyboard, click on the Layer's previous clip button which is under the Transition time slider below the transition blend selector, then push the left arrow key.
Repeat on the next clip button with the right arrow key.
Stop Keyboard mapping by pushing ESC, You're done.
robthirlby
Great thanks. That solves my problem.
pfelberg
Post by pfelberg »
I did my first GIG this weekend with Arena 6.01.
I am used to some keyboard mapping to create some (white, dark and color) strobbing effects.
So I use piano mode to play keys to send thos strobbings to the screen.
During the GIG, for several times, Arena was changing the mode while I was pressing the keys, meaning they kept going off from piano mode. So I had to re-enter keyboard mapping and set piano mode back on for several times.
