Bug: Persistent clips are removed from original deck
docoptic
Post by docoptic »
Using R6 Arena (Mac). Found a bug with persistent clips where if you switch decks and disable Persistent, they get moved to the deck where you deselected Persistent mode.
Steps:
1. Select a row of clips from any deck
2. Right-click on them and select Persistent
3. Switch to a new deck that has existing clips in the same position as the Persistent ones
4. Select the Persistent clips in that new deck
5. Right-click and disable Persistent mode on those clips
Result:
The Persistent clips are cut and pasted to the new deck in alternating clip slots. They're removed from the deck they were originally sourced from.
Re: Bug: Persistent clips are removed from original deck
Making a clip persistent removes it from the decks. and making the clip unpersistent places them in the current deck.
This is expected behavior and necessary to handle the clips that may be in the same clip slot in a deck where the persistent clip is.
docoptic
Post by docoptic »
Zoltán wrote:Making a clip persistent removes it from the decks. and making the clip unpersistent places them in the current deck.
Got it, thanks.
