midi colors
Shamai
midi colors
Post by Shamai »
can someone help me with mapping the output colors on midi controller
now they just play random colors, most are the same but a few are completely different and when i went through the drop down menu that shows like 100 colors nothing changed
apc 40 mk2
arena 6
windows 10 64 bit
Daniel
Re: midi colors
Post by Daniel »
Shall we try and walk through one option?
Pick a button of the APC40MK II and we will program it the way you want. I understand that the new shortcut system could be a bit daunting.
Re: midi colors
Shamai, you need to set a different color for each of the states so make sure you've got the right state selected before you make your color choice.
For instance, if you're dealing with a clip, you'll get the following choices:
Screenshot 2017-12-04 08.16.40.png (55.86 KiB) Viewed 10672 times
so if you want to customize your mapping you'd need to choose 1 color (velocity) per state.
Shamai
Re: midi colors
Post by Shamai »
thanks oaktown, ill try it soon, just wondering
empty is when theres no clip in a box?
disconnected is if its not playing?
previewing is if its in my preview monitor?
connected is live?
connected and previewing is live and in preview monitor?
pistalgeek
Re: midi colors
Post by pistalgeek »
Iv been trying to get my colours working on my apc with the a/b cross fader, the function works but the colours don’t correspond??? Can any one help?
Re: midi colors
Are you expecting your clips to change colors?
