Resolume 6 + Gtx1070
LemmeLemme82
Post by LemmeLemme82 »
hi my name is Michele
i have this laptop: https://shop.akinformatica.it/catalogo/ ... 93016.aspx
Fps in Resolume 6 do not go further 30/40... :-(
I have to set up the gtx 1070? Or some energy saving setting?
hi try with Benchmark-Clean/noise -1080p Composition, 20 layer = fps 24-27 but it remains fluid
thanks ;-)
Re: Resolume 6 + Gtx1070
#1, do you have the falls creators update installed? If so, you're going to have some issues
#2, go into nvidia control panel and set up a 3d settings for arena (total war) and set it to dedicated high performance.
#3 (optional), go to the bottom of your 3d settings and turn v-sync off
#4, verify that your arena comp settings fps is set to auto
#5 report back with your findings :)
LemmeLemme82
hi tanks for answer!!
1- no, it's a Windows Update? excuse the ignorance....
2- ok
3- ok
4- yes
now (without clip, composition 1920x1080) the fps are 70! I do not understand if they are stable, they occasionally fall to 50-60.
This windows update updated your nvidia driver too probably.
viewtopic.php?f=12&t=15105
Could you click on the windows search bar at the bottom right of your screen and type in:
winver
and report back what version you are currently running?
Could you go into your nVidia control panel and click 'Help' and then 'System Information' and report back with what driver version you are currently running?
Do you have Afterburner, Sonic Suite, or Nahimic installed on your machine?
I have a feeling it's a windows or nVidia issue at hand.
I'm running a GTX1060 and I idle at +140fps, you should be as well.
Thanks for the information thus far.
LemmeLemme82
140!!!! :-(
win version: 1703 (build SO 150630.726)
gtx 1070 version driver 388.31
I deleted sonic suite drive (pc without sound)
thanks
Looks like you are having the same issues as others with the Windows Fall Creators Update and update nVidia drivers.
I'd head over to the link that Zoltan posted above.
Kadete
Post by Kadete »
Zoltán wrote:This windows update updated your nvidia driver too probably.
There are any news about this? Will be fixed on the next update?
LemmeLemme82
ok!
now my driver invidia is 388.43
win 10 version 1709 is in downloading
I have hope!!!!!!!!!!!!!!!
What do you mean?
We can't fix nvidia drivers.
