Hy,
I working n a APC40 MKII midi mapping.
I've map a whole bunch of button to "selected layer, clip x , connect", I've also assigned a few different color for each of the 5 states. when I click to launch the layer, it change to the right color state. But when I click to select an other layer , the colors are not following.
It works for the rotating button that I've assigned to different effect, they following the layer, but not for the clip buttons.
I don't know if it's a bug or if I miss something, I precise that when I click "edit midi" it auto update the state and the colors are so following
Here is the xml file: https://www.dropbox.com/s/ozqtny3jt668w ... 0.xml?dl=0
for those who's interested, I'll make a post with the final one and a Explaining PDF during the holiday's
thank's for your feedback
MIDI Velocity not following
Re: MIDI Velocity not following
Hey Flaket,
We've looked into the issue and yes; it is not working while you expect it to work. I've made a ticket and we are going to look into it. Thx for letting us know.
Thank's for the ticket.Daniel wrote:Hey Flaket,
As you can see, there a lot of button doing the same thing; to map the velocity out to each I edited the XML file, is there an other way into Resolume to copy/paste the velocity from one button to an other?
Up and new question :
Is there a way to map a combination of button?
Id' like to have a button to launch a clip and have the ability to have the same button + shift to preview this clip.
I don't find the option in Resolume, but should be possible in the XML file I guest (Or else there no sense to have "shift" button on midi controller)
thank's
thank's
Sadly not possible right now.Flaket wrote:Up and new question :
thank's
All right, I'll be patient. And what about the copy/paste velocity state?Daniel wrote:Sadly not possible right now.Flaket wrote:Up and new question :
thank's
