Blend Mode is not working
Till123
Post by Till123 »
Hallo,
Im using Arena 6 and wanted to try the Blend Mode but it is not working. I chose one of the effects in the Blend Mode but nothing happens. Can somebody help me please?
Re: Blend Mode is not working
Which blend mode menu are you using?
To use layer blend modes you need to play at least 2 layers, so your top layer has something to blend with.
Most blend modes are working at 50% layer opacity best.
https://resolume.com/support/en/layers# ... ompositing
Till123
Post by Till123 »
Im using the blend Mode directly in the effect, on the visual.
shudder_inc
Post by shudder_inc »
If you change the opacity level of the effect you're using you should start to see some differences depending on the blend mode.
Similar to layer blend modes, around 50% usually achieves the desired result.
Till123
Post by Till123 »
Thank you! Now it works.
bnvisuals
Post by bnvisuals »
Hi, Im having problems with the blend modes to. Difference to be exact. Its not behaving like its supposed to. Compared to Photoshop or VDMX the result of blending is totaly off. Is there any way around this?
bnvisuals wrote: Tue Feb 25, 2020 17:52 Difference to be exact. Its not behaving like its supposed to. Compared to Photoshop or VDMX the result of blending is totaly off. Is there any way around this?
Should be fixed in the next release.
