Hi
If I add a drop shadow to a layer, and then transition between Text Animators on that layer using an Alpha layer transition, the drop shadow does not fade with the rest of the clip, but suddenly disappears once clip transition is completed.
However, if the Drop Shadow is on the Text Animator clip, then it does alpha blend smoothly along with the clip contents, as expected.
See these clips:
On layer: https://youtu.be/9nYHDGCSYVY
On clip: https://youtu.be/K5pc7Wk05x4
Richard
BUG: Drop Shadow doesn't blend smoothly as layer effect, no prob on clip
craftycurate
Re: BUG: Drop Shadow doesn't blend smoothly as layer effect, no prob on clip
Thx for reporting this. We'll take a look at what the problem could be.
