Voronoi Generator FFGL plugin
tekt
Post by tekt » Mon May 14, 2018 02:25
I've created a Vornoi pattern generator plugin, based on this from ShaderToy:
https://www.shadertoy.com/view/ldl3W8
Mac version available at:
https://github.com/t3kt/ffgl/releases/t ... gen-v1.0.0
The Windows build is broken for some reason, but the mac version works.
cvanhoose
Re: Voronoi Generator FFGL plugin
Post by cvanhoose » Wed May 16, 2018 13:49
Thank you, it is working well on my Mac.
rafaeldk
Post by rafaeldk » Fri May 25, 2018 05:02
a little help to install it?!
I'm droping the .bundle file into vfx folder inside App/Resolume.../Plugins/vfx
isn't it?!
tekt
Post by tekt » Sat Jun 02, 2018 20:14
isn't it?!
That should work. Alternatively you can change your resolume preferences to add a separate plugin directory. That's probably a better option since the Resolume installer may wipe out anything in the app directory when you update.
cvanhoose
Post by cvanhoose » Thu Aug 02, 2018 03:33
Have you figured a fix for the Windows build. Mac version works well.
