Switching a composition from PC to Mac
AaronJ
Post by AaronJ »
Hi I'm trying to switch from pc to mac and keep all of my compostions settings. Is that possible? I seem to lose clip sizing info.
Thanks,
Aaron
Re: Switching a composition from PC to Mac
AaronJ wrote: Sat Sep 08, 2018 20:03 I seem to lose clip sizing info.
Clip sizing in the transform effect, or did you set the Video track sizes in the clips manually?
AaronJ
Post by AaronJ »
We sized the clips manually in the clip panel.
Thanks.
AaronJ wrote: Sat Sep 15, 2018 14:18 We sized the clips manually in the clip panel.
Yes, but are you using the Width/Height or the Scale in the Transform?
Both are retained for me when going from mac to windows.
Which Resolume version are you using?
