can't relocate media
soup@liastudios.com
Post by soup@liastudios.com »
When i do relocate media it flashes the thumbnails correctly for a second; having clearly found the files; and then all thumbnails revert back to relocate and the files remain unplayable. I have of course shut down and restarted resolume and same result. any insight?
Re: can't relocate media
We have a ticket like this, where something similar happens when trying to a relocate composition on a different OS.
Like for example you go from Windows to OSX.
Are you doing this?
Have you collected the composition on the source machine or are you just copying the composition file and footage?
Yuckfou157
Post by Yuckfou157 »
+1
I never used the media manager in R6 until I needed to relocate 2 files that went from desktop to folder on desktop and same as above, flashed the thumbnails and disappeared, I added them from finder and all worked of course...
Yuckfou157 wrote: Thu Sep 13, 2018 12:32 +1
Mac or PC?
soup@liastudios.com
this would be in a project that started on a mac. has me worried though as the drive i'm using now is probably not going to be the drive for tour. worried that all my banks aren't going to transfer (which is in the not an option category).
hope ya'll got a fix in the works!
Yuckfou157
Zoltán wrote: Thu Sep 13, 2018 13:15
Mac or PC?
Late 2013 Macbook Pro, R6 latest build
