Is there any way to make a tint effect but with 3 colors.
Black to a color
White to a color
And a mid/grey to a color?
Is this possible
Tri Color Tint Effect
Re: Tri Color Tint Effect
Use the 'Colorize' effect.
If you set it's mode to 'Palette' it will map the 'luminance' of your pixels to colors in the palette.
edwin wrote: Thu Apr 18, 2019 11:23 Use the 'Colorize' effect.
Say whaaaat
~Berlin~
~Berlin~
I also did some testing yesterday and i like it. I missed that festure and just thought the pallete was just some preset place for custom colors
I remember that there were some preset pallets ...(candy colors / vintage colors etc) but i dont see / find them now. An someone tell me if they are gone or just at a different place?
~Berlin~
~Berlin~
Presets are copied over after a fresh installation. If you're missing any factory presets, you can copy them over from the Resolume folder in Applications on OSX or Program Files on Windows.
The folder you're looking for is Resolume Arena 6/Presets/Color Palettes
This folder dont exist in my system...Joris wrote: Tue Apr 23, 2019 09:25 Presets are copied over after a fresh installation. If you're missing any factory presets, you can copy them over from the Resolume folder in Applications on OSX or Program Files on Windows.
- Attachments
- presets.PNG (11.65 KiB) Viewed 18053 times
~Berlin~
~Berlin~
Yeah, so in that case you can copy them over from Program Files
Okay... i got it.... sometimes i feel like i get more help them i m offering....
~Berlin~
~Berlin~
I think your karma level is definitely in the positive
