7 stuck on splash screen
jwarren72
Re: 7 stuck on splash screen
Post by jwarren72 »
Thanks for the quick reply.
I just tried to right-click and run Arena 7 as the Administrator. The result is the same. Just hanging at the start screen.
jwarren72
Post by jwarren72 »
Below is the latest log file.
This time there is a error related to ARTNET.
Also when I renamed the Example.AVC file in ( C:\Program Files\Resolume Arena\default ), although it still hung up, I heard the sound "Resolume Arena". I did not hear that before. I do not hear it when I restore the Example.AVC file
Code: Select all
Resolume Arena 7.0.0 64956 built 2 July 2019
Log started: 9 Jul 2019 7:03:38am
INFO: Logging has started
INFO: Initialise JuceResapiApp
INFO: Initialise ResApi
INFO: Initializing Resapi
INFO:     Created ParamCollection
INFO:     Created TaskManager with 2 threads.
INFO:     Created InputController
INFO:     Created DeviceChangeDetector
INFO:     Creating VideoFormatManager
INFO:         Registering basic formats
INFO:         Registered 4 formats
INFO:     Created VideoFormatManager
INFO:     Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
INFO:     Trying to create DirectShow capture input device for: Integrated Webcam (DirectShow_\\?\usb#vid_064e&pid_920b&mi_00#6&2de64f16&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global_Integrated Webcam)
INFO:     Creating NDIVideoServerManager
INFO:         Initializing NDI library
INFO:         Successfully initialized NDI library
INFO:     Created NDIVideoServerManager
INFO:     Creating DisplayCollection
INFO:     Created DisplayCollection
INFO:     First time OpenGL usage, initializing extensions.
INFO:     Registering window class.
INFO:     Successfully registered window class.
INFO:     Successfully initialized extensions.
INFO:     This system supports OpenGL version: 4.1.13497 Core Profile Context 23.20.768.12
INFO:     ---Info main OpenGL renderer---
INFO:     Driver Vendor : ATI Technologies Inc.
INFO:     Renderer Name: AMD Radeon R5 M335
INFO:     Driver Version: 4.1.13497 Core Profile Context 23.20.768.12
INFO:     OpenGL shader language version: 4.50
INFO:     Maximum Supported OpenGL version: 4.1
INFO:     -------------------------------
INFO:     Initializing GPUMonitor
INFO:         Trying to create NVApi GPUMonitorStrategy.
INFO:             NVApi is not available, probably no Nvidia GPU installed?
ERROR:     No valid GPU Monitor Strategy could be instantiated, max/used memory will always report 1337.31415.
INFO:     Initializing renderer.
INFO:         Loading shaders...
INFO:         Successfully loaded shaders.
INFO:     Successfully initialized renderer.
INFO:     Initializing Resapi graphics
INFO:         Initializing TextureUploader
INFO:             Determining AutoDetect setting
INFO:                 Immutable Buffers supported: true
INFO:                 GPU Monitoring supported: false
INFO:             Autodetect would use inline transfers
INFO:         Successfully initialized TextureUploader
INFO:     Successfully initialized Resapi graphics.
INFO: Successfully initialized Resapi.
INFO: Install default PathParser
INFO: Enumerate fonts
INFO: Find default fonts
INFO: Create Application Object
INFO: Setting up default composition.
INFO: Resapi: setCurrentApplication
INFO: Init Colour scheme for user interface
INFO: Create LookAndFeel
INFO: Set LookAndFeel
INFO: Disable screen saver
INFO: Print version info
INFO: Major Version: 7
INFO: Minor Version: 0
INFO: Micro Version: 0
INFO: Revision: 64956
INFO: Id: 1
INFO: Revision string: rev64956
INFO: Version string with revision: 7.0.0 64956
INFO: Version string without revision: 7.0.0
INFO: Print application paths
INFO: Executable Path: C:\Program Files\Resolume Arena
INFO: User Documents Path: C:\Users\jwarr\Documents\Resolume Arena
INFO: Default Data Path: C:\Program Files\Resolume Arena\default
INFO: Common Data Path: C:\ProgramData\Resolume Arena
INFO: Common Documents Path: C:\Users\Public\Documents\Resolume Arena
INFO: Preferences Path: C:\Users\jwarr\Documents\Resolume Arena\Preferences
INFO: Media Path: C:\Program Files\Resolume Arena\media
INFO: Compositions Path: C:\Users\jwarr\Documents\Resolume Arena\Compositions
INFO: Default Presets Path:
INFO: User Presets Path: C:\Users\jwarr\Documents\Resolume Arena\Presets
INFO: Video Effects Presets Path: C:\Users\jwarr\Documents\Resolume Arena\Presets\Video Effects
INFO: Audio Effects Presets Path: C:\Users\jwarr\Documents\Resolume Arena\Presets\Audio Effects
INFO: Video Sources Presets Path: C:\Users\jwarr\Documents\Resolume Arena\Presets\Sources
INFO: Audio Plugins Path: C:\Program Files\Resolume Arena\plugins\afx
INFO: Video Plugins Path: C:\Program Files\Resolume Arena\plugins\vfx
INFO: Previews Path: C:\Users\jwarr\AppData\Local\Resolume Arena\previews
INFO: Layout Presets Path: C:\Users\jwarr\Documents\Resolume Arena\Presets\Interface
INFO: Print system info
INFO: Operating system: Windows 10
INFO: OS 64 bit: Yes
INFO: CPU vendor: GenuineIntel
INFO: CPU speed: 2579MHz
INFO: Number of CPUs: 4
INFO: Memory size: 16276MB
INFO: System language is: en
INFO: Locate preferences directory
INFO: Locate settings file
INFO: Copy Default Effect, Source, Envelope, Color Palette, Layout, Advanced Screensetup Presets
INFO: Copy Default Shortcut Presets
INFO: Copying Default fixtures
INFO: Load Application settings
INFO: Install languages
INFO: Set fonts
INFO: Looking for unicode font
INFO: Unicode font found is: Arial Unicode MS
INFO: Language file font setting: FontToRenderThisLanguageInWin
INFO: Language file font base height setting: 0.00
INFO: Create ApplicationController
INFO: Update Composition List
INFO: Enumerating Compositions0.00064 seconds
INFO: Install Source Preset preprocessor
INFO: Install Effect Preset preprocessor
INFO: Install Animation Preset preprocessor
INFO: Loading Animation presets
INFO: Create AudioEngine
INFO: Load AudioEngine settings
INFO: Load SMPTE settings
INFO: Setup Effect presets directory
INFO: Setup Source presets directory
INFO: Creating VideoSourceManager
INFO: Created VideoSourceManager
INFO: Create VideoEngine
INFO: Let VideoEngine scan for plugins
INFO: Scanning directory for plugins: C:\Program Files\Resolume Arena\plugins\vfx
INFO: Scanning directory for plugins: C:\Users\jwarr\Documents\Resolume Arena\Extra Effects
INFO: Loading plugins took: 0.00202 seconds
INFO: Pass Application name to spout
INFO: Set thumbnail for capture device sources
INFO: Initialize video engine
INFO: Register internal renderpasses
INFO: Initialize AudioEngine
INFO: Changing audio setup to:
INFO: 		Device Type:	Windows Audio
INFO: 		Output Device:	Speakers / Headphones (Realtek Audio)
INFO: 		Input  Device:	Microphone (Realtek Audio)
INFO: 		Samplerate:		48000
INFO: 		BlockSize:		480
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Bitcrusher.dll
Creating VST instance: Bitcrusher
Initialising VST: Bitcrusher (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Distortion.dll
Creating VST instance: Distortion
Initialising VST: Distortion (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\EQ-3.dll
Creating VST instance: EQ-3
Initialising VST: EQ-3 (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Flanger.dll
Creating VST instance: Flanger
Initialising VST: Flanger (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\HighPass.dll
Creating VST instance: HighPass
Initialising VST: HighPass (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\LowPass.dll
Creating VST instance: LowPass
Initialising VST: LowPass (V1.0.0)
INFO: Create Composition
INFO: Register Composition with controllers
INFO: Create ShortcutManagers
INFO: Create ShortcutPresetManager
INFO: Install Shortcut Preset preprocessor
INFO: Create DmxController And Load Settings
INFO: Load Fixture Presets
INFO: Register application specific renderpasses and sources
INFO: Load video effect presets
INFO: Load video source presets
INFO: Load audio effect presets
INFO: Create MainWindow
INFO: Create MainComponent
INFO: Install KeyListener
INFO: Install MouseListener
INFO: Create Monitor Panel
INFO: Create Layer Properties Panel
INFO: Create Clip Properties Panel
INFO: Create Composition Properties Panel
INFO: Create Toolbar Panel
INFO: Create Shortcuts Panel
INFO: Create File Browser Panel
INFO: Create Compositions Panel
INFO: Create Effects Panel
INFO: Create Sources Panel
INFO: Create Help Panel
INFO: Create Layer Group Panel
INFO: Create Slices Panel
INFO: Create UI manager
INFO: Enumerating Compositions0.00067 seconds
INFO: Install Layout Preset preprocessor
INFO: Set sparkle update accepted callback
INFO: Load auto-saved layout
INFO: Show main window
INFO: Create ScreenSetupDriver
INFO: Set ScreenSetup Presets Directory: C:\Users\jwarr\Documents\Resolume Arena\Presets\Advanced Output
INFO: Load ScreenSetup Presets
INFO: Create AdvancedScreenSetupWindow
INFO: Set ScreenSetup Advanced Preferences file: C:\Users\jwarr\Documents\Resolume Arena\Preferences\AdvancedOutput.xml
INFO: Enumerate displays and position MainWindow on primary device
INFO: Init Screen Setup
INFO: Load Last Screen Setup
INFO: Install Screen Setup Preset preprocessor
INFO: Attach screen setup inspector
INFO: Attach Undo Stack inspector
INFO: Attach menu to window
INFO: Create HelpController
INFO: Load HelpController file
INFO: Create OscController
INFO: OscController: Install Translation Strategy
INFO: Load OscController settings
INFO: Create MidiController
INFO: Refresh MidiController
INFO: Load MidiController settings
INFO: Start MidiController
INFO: Create renderer
INFO: Start renderer
INFO: Initializing ArtNet on adapter .
ERROR: ArtNet initialization failed, failed starting node.
INFO: New Composition took: 0.14483 seconds
INFO: Initialise took: 3.94562 seconds
jwarren72
Post by jwarren72 »
There was a Microsoft Update on my PC overnight. When I logged in this morning and tried Arena 7 it booted up just fine. Go figure.
jwarren72 wrote:
Wed Jul 10, 2019 14:07
Good news I guess,
Could you please send us the Resolume log file via the feedback tab in preferences?
Theatre sound engineer, photographer, programmer, aka ravensc.
VJ footage: https://goo.gl/58oHy7
mungle
Post by mungle »
Hello!
I'm really exited for the new version but… I've got the same problem. :o :( :cry:
Windows updated, all the drivers updated as well…
Here my log:
Resolume Arena log.zip
(4.54 KiB) Downloaded 59 times
Hope you can help me!
Thank you!
jwarren72
Post by jwarren72 »
Yes. It is good news. The only downside is not knowing what actually caused the problem and what actually fixed it. There is no way to debug it at this point. Here is the log you requested:
Code: Select all
Log started: 10 Jul 2019 7:44:12am
INFO:     This system supports OpenGL version: 4.1.0 - Build 23.20.16.4973
INFO:     Driver Vendor : Intel
INFO:     Renderer Name: Intel(R) HD Graphics 520
INFO:     Driver Version: 4.1.0 - Build 23.20.16.4973
INFO:     OpenGL shader language version: 4.10 - Build 23.20.16.4973
INFO:     Successfully initialized GPUMonitor, using Intel strategy.
INFO:                 GPU Monitoring supported: true
INFO:             AutoDetect would use DMA transfers
INFO: Id: 1
INFO: CPU speed: 2574MHz
INFO: Set fonts
INFO: Enumerating Compositions0.00076 seconds
INFO: Loading plugins took: 0.00260 seconds
INFO: Enumerating Compositions0.00061 seconds
INFO: New Composition took: 0.21373 seconds
INFO: Initialise took: 5.15459 seconds
INFO: OpenGLCanvas: New context is created
INFO: Auto-saving layout
INFO: Prepare for shutdown
INFO: Force Stop Recording
INFO: Composition Prepare for Shutdown
INFO: ***
INFO: Shutdown sequence started
INFO: Auto-save layout
INFO: Clear menu delegates
INFO: Detach Composition Inspector
INFO: Composition Shutdown
INFO: Stop renderer
INFO: Stop Server if running
INFO: Clean up renderer
INFO: Save Application and VideoEngine settings
INFO: Serialize application model
INFO: Serialize video engine
INFO: Serialize audio engine
INFO: Serialize smpte settings
INFO: Create preferences file (config.xml)
INFO: Write preferences XML (config.xml)
INFO: Save animation presets
INFO: Save DMX preferences
INFO: Saving OSC preferences
INFO: Save MIDI preferences
INFO: Clean up UI
INFO: Context will be deleted: monitor
INFO: Save Video Effect Presets
INFO: Save Source Presets
INFO: Save Screen Setup Simple Settings
INFO: Save shortcuts and presets
INFO: Stop output shortcut managers
INFO: Clean up LookAndFeel
INFO: Clean up HelpController
INFO: Clean up OscController
INFO: Clean up MIDIController
INFO: Clean up Compositon
INFO: Clean the UI Factory
INFO: Clean the Composition Object
INFO: Destroying ClipController
INFO: Done destroying ClipController
INFO: Deinitialize AudioEngine
INFO: Clean up Audio Engine
INFO: Clean up Video Engine
INFO: Clean up RecordingController
INFO: Clean up ApplicationController
INFO: Clean up FixtureSelection
INFO: Clean up Application Object
INFO: Shutdown JuceResapiApp
INFO: Release ResApi
INFO: Shutdown ResApi
INFO: Deleting myself
Log started: 10 Jul 2019 7:45:27am
INFO: Id: 1
INFO: CPU speed: 2580MHz
INFO: Set fonts
INFO: Load VideoEngine settings
INFO: Loading plugins took: 0.00235 seconds
INFO: Initializing ArtNet on adapter ethernet_32773.
INFO: ArtNet initialization succeeded.
INFO: Enumerating Compositions0.00062 seconds
INFO: Enumerating Compositions0.00069 seconds
INFO: Reading composition state took: 0.25234 seconds
INFO: Initialise took: 3.66518 seconds
WARNING: rj::AudioEffect::readStateDerived: Loading plugin failed.
INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_1916&SUBSYS_06B21028&REV_07\3&11583659&0&10'
INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}'
WARNING: ra::getDeviceCategory: Cannot get category, 'Display' class name is not recognised.
INFO: ra::MessageWindow::MsgProc: Device of unknown type got disconnected.
INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\DISPLAY\CMN1735\4&a0cd8b3&0&UID265988'
INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}'
INFO: ra::MessageWindow::MsgProc: Device of unknown type got connected.
Menno
Post by Menno »
I'm trying to figure out what's happening, which is kind of hard as i dont have a machine available that also has this issue. For now it looks like we're not allowed access to the OpenGL context during our startup routine.
Can you please tell me how much cpu % and how much gpu % arena is using while it's stuck?
On windows you can check this in the Task Manager. Go to Processes and write down the value shown under CPU on arena's row. The gpu utilization you can also get in the task manager on windows 10. Go to performance, select the gpu that arena should be running on. Write down the gpu utilization, start arena, wait until it freezes, write down the gpu utilization again. On non windows 10 you can do the same using a tool like GPU-Z.
mungle
Post by mungle »
Hello!
Here my task manager Screenshot.
Thank you!
screenshot
screenshot
jwarren72 wrote:
Thu Jul 11, 2019 00:54
Looks like Resolume started using the integrated Intel GPU this time. The update might have reset the AMD driver - program associations to run Resolume on the AMD GPU.
Can you check that in the ATI control panel?
mungle
Post by mungle »
Hi!
I formatted my computer, installed all the drivers, forced the use of the graphic card but nothing... arena won’t opens.
How can ai debug for you?
Yesterday I had to use the version 6...
I updated to 7 because I needed the new “loop repeat” feature but due to that problem I just figured out an alternative... but I’m still very disappointed...
Please! Need support!
