Composition regularly turns off for 5 sec
Vjjoly
Post by Vjjoly »
Hi ! In one of compositions, the video uses to be turned offf for 5 seconds without any reason. I created a new one with the same clip but the playing clips are still turning off every 1 or 5 minutes. My screen just turns black and then my clips appear again. Do you know what's going on ? The problem is that in another différent composition it doesn't hppen.
Thanks!!
Re: Composition regularly turns off for 5 sec
What kind of clips are you using?
Drivers up to date?
Vjjoly
Post by Vjjoly »
They are clips in .mov, between 10sec and 1 minute, that I convert in Alley with the standard settings. Do you think that it could be a problem with a format of a clip ? Have you already faced that ?
I am not sure that is a software problem but more a composition problem. At total, I have 4 compositions and just one has this problem.
Thanks !
DXV should be good.
How about the GPU driver versions?
Vjjoly
Post by Vjjoly »
I have a Macbook with 2,2 GHz Intel Core i7. I always have done my gigs with it before, and it never fails. This problem just happened suddenly. The weight of my composition with this problem is 1,6 Mo.
Is the whole built in display going black or only the composition preview?
Which GPU do you have in your macbook?
Vjjoly
Post by Vjjoly »
My GPU is Intel Iris Pro Graphics 6200 1536 Mb.
It's my whole Output Monitor which turns black, I can see it on the screen inside Resolume (the one on the bottom left, above the preview monitor) and the screen projected. Well, there are the same "output monitor". But I can still click on the loop, see the panels, as if I was still playing.
It's like I am putting a black video for five seconds and then come back to my previous loops, but without taking control of this "black video".
I hope I can give your clear informations :) Thanks a lot for your help !
Hmm, do you see the built in macbook display flashing too?
Maybe it's the display cables, or a bad connection, can you try different cables ?
Vjjoly
Post by Vjjoly »
No it's only inside the software Resolume. My macbook doesn't have any problem I can see. I don't think it's a cable problem because it happens also when I don't connect it to a projector.
The problem is more about the diffusion on the Output Monitor, whereas I connect my laptop or not.
What do you do right before the output goes black, and do you need to do anything to get it back, or does it come and go without you touching your machine or midi controller?
