Stuck save composition .need help
vjhugo
Post by vjhugo »
I always get stuck trying to save
I also use other people's synthesis occasionally
I've uploaded videos and log files
There is no such problem with the version of res6.
After upgrading to res7, there will be such a troublesome problem. How can I solve it?
vjhugo
Re: Stuck save composition .need help
Post by vjhugo »
Unable to add attachment, I will copy the log file
Code: Select all
[2020-06-20T21:09:03.773+08:00]   INFO: Prepare for shutdown
[2020-06-20T21:09:03.773+08:00]   INFO: Force Stop Recording
[2020-06-20T21:09:03.773+08:00]   INFO: Composition Prepare for Shutdown
[2020-06-20T21:09:03.775+08:00]   INFO: ***
[2020-06-20T21:09:03.776+08:00]   INFO: Shutdown sequence started
[2020-06-20T21:09:03.777+08:00]   INFO: Auto-save layout
[2020-06-20T21:09:03.777+08:00]   INFO: Auto-saving layout
[2020-06-20T21:09:03.779+08:00]   INFO: Clear menu delegates
[2020-06-20T21:09:03.779+08:00]   INFO: Detach Composition Inspector
[2020-06-20T21:09:03.872+08:00]   INFO: Composition Shutdown
[2020-06-20T21:09:05.257+08:00]   INFO: Stop renderer
[2020-06-20T21:09:05.260+08:00]   INFO: Stop Server if running
[2020-06-20T21:09:06.799+08:00]   INFO: Clean up renderer
[2020-06-20T21:09:06.799+08:00]   INFO: Save Application and VideoEngine settings
[2020-06-20T21:09:06.799+08:00]   INFO: Serialize application model
[2020-06-20T21:09:06.800+08:00]   INFO: Serialize video engine
[2020-06-20T21:09:06.800+08:00]   INFO: Serialize audio engine
[2020-06-20T21:09:06.800+08:00]   INFO: Serialize smpte settings
[2020-06-20T21:09:06.800+08:00]   INFO: Create preferences file (config.xml)
[2020-06-20T21:09:06.801+08:00]   INFO: Write preferences XML (config.xml)
[2020-06-20T21:09:06.802+08:00]   INFO: Save animation presets
[2020-06-20T21:09:06.813+08:00]   INFO: Save DMX preferences
[2020-06-20T21:09:06.813+08:00]   INFO: Saving OSC preferences
[2020-06-20T21:09:06.814+08:00]   INFO: Save MIDI preferences
[2020-06-20T21:09:06.815+08:00]   INFO: Clean up UI
[2020-06-20T21:09:06.816+08:00]   INFO: Context will be deleted: monitor
[2020-06-20T21:09:07.462+08:00]   INFO: Save Video Effect Presets
[2020-06-20T21:09:07.471+08:00]   INFO: Save Source Presets
[2020-06-20T21:09:07.501+08:00]   INFO: Locate preferences directory
[2020-06-20T21:09:07.502+08:00]   INFO: Save Screen Setup Simple Settings
[2020-06-20T21:09:07.503+08:00]   INFO: Close screensetup
[2020-06-20T21:09:07.516+08:00]   INFO: Save shortcuts and presets
[2020-06-20T21:09:07.532+08:00]   INFO: Stop output shortcut managers
[2020-06-20T21:09:07.581+08:00]   INFO: Clean up LookAndFeel
[2020-06-20T21:09:07.581+08:00]   INFO: Clean up HelpController
[2020-06-20T21:09:07.582+08:00]   INFO: Clean up DmxController
[2020-06-20T21:09:07.589+08:00]   INFO: Clean up MIDIController
[2020-06-20T21:09:07.592+08:00]   INFO: Clean up Compositon
[2020-06-20T21:09:07.592+08:00]   INFO: Clean the UI Factory
[2020-06-20T21:09:07.602+08:00]   INFO: Clean the Composition Object
[2020-06-20T21:09:07.604+08:00]   INFO: Destroying ClipController
[2020-06-20T21:09:07.604+08:00]   INFO: Done destroying ClipController
[2020-06-20T21:09:07.610+08:00]   INFO: Deinitialize AudioEngine
[2020-06-20T21:09:07.610+08:00]   INFO: Clean up Audio Engine
[2020-06-20T21:09:08.237+08:00]   INFO: Clean up Video Engine
[2020-06-20T21:09:08.237+08:00]   INFO: Save shortcuts and presets
[2020-06-20T21:09:08.238+08:00]   INFO: Clean up LookAndFeel
[2020-06-20T21:09:08.238+08:00]   INFO: Clean up HelpController
[2020-06-20T21:09:08.238+08:00]   INFO: Clean up RecordingController
[2020-06-20T21:09:08.238+08:00]   INFO: Clean up ApplicationController
Resolume Arena 7.0.5 67117 built 28 November 2019
Log started: 20 Jun 2020 9:09:09pm
[2020-06-20T21:09:09.257+08:00]   INFO: Logging has started
[2020-06-20T21:09:09.261+08:00]   INFO: Ensuring Nvidia profile correctness
[2020-06-20T21:09:09.439+08:00]   INFO:     Failed adding application Resolume Arena/Arena.exe to custom nvidia profile, it's probably already present
[2020-06-20T21:09:09.439+08:00]   INFO: Nvidia profile setup finished successfully
[2020-06-20T21:09:09.442+08:00]   INFO: ***
[2020-06-20T21:09:09.442+08:00]   INFO: Shutdown sequence started
[2020-06-20T21:09:09.442+08:00]   INFO: Shutdown sequence triggered because another instance is already running or OpenGL 4.1 is not supported
[2020-06-20T21:09:10.026+08:00]   INFO: Clean up FixtureSelection
[2020-06-20T21:09:10.026+08:00]   INFO: Clean up Application Object
[2020-06-20T21:09:10.079+08:00]   INFO: Shutdown JuceResapiApp
[2020-06-20T21:09:10.080+08:00]   INFO: Release ResApi
[2020-06-20T21:09:10.092+08:00]   INFO: Shutdown ResApi
[2020-06-20T21:09:11.511+08:00]   INFO: Deleting myself
Log started: 20 Jun 2020 9:09:13pm
[2020-06-20T21:09:13.684+08:00]   INFO: Logging has started
[2020-06-20T21:09:13.689+08:00]   INFO: Ensuring Nvidia profile correctness
[2020-06-20T21:09:13.877+08:00]   INFO:     Failed adding application Resolume Arena/Arena.exe to custom nvidia profile, it's probably already present
[2020-06-20T21:09:13.877+08:00]   INFO: Nvidia profile setup finished successfully
[2020-06-20T21:09:13.917+08:00]   INFO: Initializing application. Command Line: "G:\hugo-new-comp.avc"
[2020-06-20T21:09:13.918+08:00]   INFO:     Initialise JuceResapiApp
[2020-06-20T21:09:13.918+08:00]   INFO:     Initialise ResApi
[2020-06-20T21:09:13.918+08:00]   INFO:     Initializing Resapi
[2020-06-20T21:09:13.918+08:00]   INFO:         Created ParamCollection
[2020-06-20T21:09:13.919+08:00]   INFO:         Created TaskManager with 10 threads.
[2020-06-20T21:09:13.919+08:00]   INFO:         Created InputController
[2020-06-20T21:09:13.920+08:00]   INFO:         Created DeviceChangeDetector
[2020-06-20T21:09:13.921+08:00]   INFO:         Creating VideoFormatManager
[2020-06-20T21:09:13.921+08:00]   INFO:             Registering basic formats
[2020-06-20T21:09:13.923+08:00]   INFO:             Registered 4 formats
[2020-06-20T21:09:13.923+08:00]   INFO:         Created VideoFormatManager
[2020-06-20T21:09:13.938+08:00]   INFO:         Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
[2020-06-20T21:09:13.943+08:00]   INFO:         Trying to create DirectShow capture input device for: HD Webcam (DirectShow_\\?\usb#vid_04f2&pid_b68b&mi_00#6&37874e19&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global_HD Webcam)
[2020-06-20T21:09:14.133+08:00]   INFO:         Creating DisplayCollection
[2020-06-20T21:09:14.137+08:00]   INFO:         Created DisplayCollection
[2020-06-20T21:09:14.137+08:00]   INFO:         First time OpenGL usage, initializing extensions.
[2020-06-20T21:09:14.137+08:00]   INFO:         Registering window class.
[2020-06-20T21:09:14.138+08:00]   INFO:         Successfully registered window class.
[2020-06-20T21:09:14.677+08:00]   INFO:         Successfully initialized extensions.
[2020-06-20T21:09:14.677+08:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 431.62
[2020-06-20T21:09:14.678+08:00]   INFO:         ---Info main OpenGL renderer---
[2020-06-20T21:09:14.679+08:00]   INFO:         Driver Vendor : NVIDIA Corporation
[2020-06-20T21:09:14.679+08:00]   INFO:         Renderer Name: GeForce RTX 2060/PCIe/SSE2
[2020-06-20T21:09:14.679+08:00]   INFO:         Driver Version: 4.1.0 NVIDIA 431.62
[2020-06-20T21:09:14.679+08:00]   INFO:         OpenGL shader language version: 4.10 NVIDIA via Cg compiler
[2020-06-20T21:09:14.680+08:00]   INFO:         Maximum Supported OpenGL version: 4.1
[2020-06-20T21:09:14.680+08:00]   INFO:         -------------------------------
[2020-06-20T21:09:14.680+08:00]   INFO:         Initializing GPUMonitor
[2020-06-20T21:09:14.680+08:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:09:14.683+08:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:09:14.683+08:00]   INFO:         Initializing renderer.
[2020-06-20T21:09:14.684+08:00]   INFO:             Loading shaders...
[2020-06-20T21:09:14.691+08:00]   INFO:             Successfully loaded shaders.
[2020-06-20T21:09:14.700+08:00]   INFO:         Successfully initialized renderer.
[2020-06-20T21:09:14.722+08:00]   INFO:         Successfully initialized extensions.
[2020-06-20T21:09:14.723+08:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 431.62
[2020-06-20T21:09:14.723+08:00]   INFO:         Initializing GPUMonitor
[2020-06-20T21:09:14.723+08:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:09:14.725+08:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:09:14.725+08:00]   INFO:         Initializing renderer.
[2020-06-20T21:09:14.726+08:00]   INFO:             Loading shaders...
[2020-06-20T21:09:14.730+08:00]   INFO:             Successfully loaded shaders.
[2020-06-20T21:09:14.738+08:00]   INFO:         Successfully initialized renderer.
[2020-06-20T21:09:14.762+08:00]   INFO:         Successfully initialized extensions.
[2020-06-20T21:09:14.762+08:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 431.62
[2020-06-20T21:09:14.762+08:00]   INFO:         Initializing GPUMonitor
[2020-06-20T21:09:14.763+08:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:09:14.764+08:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:09:14.764+08:00]   INFO:         Initializing renderer.
[2020-06-20T21:09:14.765+08:00]   INFO:             Loading shaders...
[2020-06-20T21:09:14.770+08:00]   INFO:             Successfully loaded shaders.
[2020-06-20T21:09:14.778+08:00]   INFO:         Successfully initialized renderer.
[2020-06-20T21:09:14.779+08:00]   INFO:         Initializing Resapi graphics
[2020-06-20T21:09:14.779+08:00]   INFO:             Initializing GPUMonitor
[2020-06-20T21:09:14.779+08:00]   INFO:                 Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:09:14.781+08:00]   INFO:             Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:09:14.781+08:00]   INFO:             Initializing TextureUploader
[2020-06-20T21:09:14.782+08:00]   INFO:                 Determining AutoDetect setting
[2020-06-20T21:09:14.782+08:00]   INFO:                     Immutable Buffers supported: true
[2020-06-20T21:09:14.782+08:00]   INFO:                     GPU Monitoring supported: true
[2020-06-20T21:09:14.782+08:00]   INFO:                 AutoDetect would use DMA transfers
[2020-06-20T21:09:14.783+08:00]   INFO:             Successfully initialized TextureUploader
[2020-06-20T21:09:14.783+08:00]   INFO:         Successfully initialized Resapi graphics.
[2020-06-20T21:09:14.783+08:00]   INFO:     Successfully initialized Resapi.
[2020-06-20T21:09:14.784+08:00]   INFO:     Install default PathParser
[2020-06-20T21:09:14.784+08:00]   INFO:     Enumerate fonts
[2020-06-20T21:09:14.828+08:00]   INFO:     Find default fonts
[2020-06-20T21:09:14.829+08:00]   INFO:     Create Application Object
[2020-06-20T21:09:14.829+08:00]   INFO:     Setting up default composition settings.
[2020-06-20T21:09:14.830+08:00]   INFO:     Resapi: setCurrentApplication
[2020-06-20T21:09:14.831+08:00]   INFO:     Init Colour scheme for user interface
[2020-06-20T21:09:14.831+08:00]   INFO:     Create LookAndFeel
[2020-06-20T21:09:14.833+08:00]   INFO:     Set LookAndFeel
[2020-06-20T21:09:14.833+08:00]   INFO:     Disable screen saver
[2020-06-20T21:09:14.834+08:00]   INFO:     Print version info
[2020-06-20T21:09:14.834+08:00]   INFO:     Major Version: 7
[2020-06-20T21:09:14.834+08:00]   INFO:     Minor Version: 0
[2020-06-20T21:09:14.834+08:00]   INFO:     Micro Version: 5
[2020-06-20T21:09:14.835+08:00]   INFO:     Revision: 67117
[2020-06-20T21:09:14.835+08:00]   INFO:     Id: 1
[2020-06-20T21:09:14.835+08:00]   INFO:     Revision string: rev67117
[2020-06-20T21:09:14.835+08:00]   INFO:     Version string with revision: 7.0.5 67117
[2020-06-20T21:09:14.835+08:00]   INFO:     Version string without revision: 7.0.5
[2020-06-20T21:09:14.836+08:00]   INFO:     Print application paths
[2020-06-20T21:09:14.836+08:00]   INFO:     Executable Path: C:\Program Files\Resolume Arena
[2020-06-20T21:09:14.836+08:00]   INFO:     User Documents Path: C:\Users\VJ Hugo\Documents\Resolume Arena
[2020-06-20T21:09:14.836+08:00]   INFO:     Default Data Path: C:\Program Files\Resolume Arena\default
[2020-06-20T21:09:14.837+08:00]   INFO:     Common Data Path: C:\ProgramData\Resolume Arena
[2020-06-20T21:09:14.837+08:00]   INFO:     Common Documents Path: C:\Users\Public\Documents\Resolume Arena
[2020-06-20T21:09:14.838+08:00]   INFO:     Preferences Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Preferences
[2020-06-20T21:09:14.838+08:00]   INFO:     Media Path: C:\Program Files\Resolume Arena\media
[2020-06-20T21:09:14.838+08:00]   INFO:     Compositions Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Compositions
[2020-06-20T21:09:14.839+08:00]   INFO:     Default Presets Path:
[2020-06-20T21:09:14.839+08:00]   INFO:     User Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets
[2020-06-20T21:09:14.839+08:00]   INFO:     Video Effects Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Video Effects
[2020-06-20T21:09:14.839+08:00]   INFO:     Audio Effects Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Audio Effects
[2020-06-20T21:09:14.840+08:00]   INFO:     Video Sources Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Sources
[2020-06-20T21:09:14.840+08:00]   INFO:     Audio Plugins Path: C:\Program Files\Resolume Arena\plugins\afx
[2020-06-20T21:09:14.840+08:00]   INFO:     Video Plugins Path: C:\Program Files\Resolume Arena\plugins\vfx
[2020-06-20T21:09:14.841+08:00]   INFO:     Previews Path: C:\Users\VJ Hugo\AppData\Local\Resolume Arena\previews
[2020-06-20T21:09:14.841+08:00]   INFO:     Layout Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Interface
[2020-06-20T21:09:14.841+08:00]   INFO:     Print system info
[2020-06-20T21:09:14.842+08:00]   INFO:     Operating system: Windows 10
[2020-06-20T21:09:14.842+08:00]   INFO:     OS 64 bit: Yes
[2020-06-20T21:09:14.842+08:00]   INFO:     CPU vendor: GenuineIntel
[2020-06-20T21:09:14.923+08:00]   INFO:     CPU speed: 2192MHz
[2020-06-20T21:09:14.923+08:00]   INFO:     Number of CPUs: 12
[2020-06-20T21:09:14.923+08:00]   INFO:     Memory size: 32625MB
[2020-06-20T21:09:14.924+08:00]   INFO:     System language is: zh
[2020-06-20T21:09:14.924+08:00]   INFO:     Locate preferences directory
[2020-06-20T21:09:14.924+08:00]   INFO:     Locate settings file
[2020-06-20T21:09:14.925+08:00]   INFO:     Load Application settings
[2020-06-20T21:09:14.925+08:00]   INFO:     Install languages
[2020-06-20T21:09:14.929+08:00]   INFO:     Set fonts
[2020-06-20T21:09:14.929+08:00]   INFO:     Looking for unicode font
[2020-06-20T21:09:14.929+08:00]   INFO:     Unicode font found is: Lucida Sans Unicode
[2020-06-20T21:09:14.930+08:00]   INFO:     Language file font setting: FontToRenderThisLanguageInWin
[2020-06-20T21:09:14.930+08:00]   INFO:     Language file font base height setting: 0.00
[2020-06-20T21:09:14.930+08:00]   INFO:     Create ApplicationController
[2020-06-20T21:09:14.932+08:00]   INFO:     Creating NDIVideoServerManager
[2020-06-20T21:09:14.932+08:00]   INFO:         Initializing NDI library
[2020-06-20T21:09:14.935+08:00]   INFO:         Successfully initialized NDI library
[2020-06-20T21:09:14.941+08:00]   INFO:     Created NDIVideoServerManager
[2020-06-20T21:09:14.956+08:00]   INFO:     Update Composition List
[2020-06-20T21:09:19.264+08:00]   INFO:     Enumerating Compositions took: 4.30770 seconds
[2020-06-20T21:09:19.264+08:00]   INFO:     Initializing OSC
[2020-06-20T21:09:19.326+08:00]   INFO:     Install Source Preset preprocessor
[2020-06-20T21:09:19.326+08:00]   INFO:     Install Effect Preset preprocessor
[2020-06-20T21:09:19.327+08:00]   INFO:     Install Animation Preset preprocessor
[2020-06-20T21:09:19.327+08:00]   INFO:     Loading Animation presets
[2020-06-20T21:09:19.332+08:00]   INFO:     Create AudioEngine
[2020-06-20T21:09:19.402+08:00]   INFO:     Load AudioEngine settings
[2020-06-20T21:09:19.402+08:00]   INFO:     Load SMPTE settings
[2020-06-20T21:09:19.402+08:00]   INFO:     Setup Effect presets directory
[2020-06-20T21:09:19.403+08:00]   INFO:     Enabling NDI support
[2020-06-20T21:09:19.403+08:00]   INFO:     Setup Source presets directory
[2020-06-20T21:09:19.403+08:00]   INFO:     Creating VideoSourceManager
[2020-06-20T21:09:19.404+08:00]   INFO:     Created VideoSourceManager
[2020-06-20T21:09:19.404+08:00]   INFO:     Create VideoEngine
[2020-06-20T21:09:19.405+08:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Program Files\Resolume Arena\plugins\vfx'
[2020-06-20T21:09:19.405+08:00]   INFO:     Done scanning directory, loaded 0 plugin(s) from it.
[2020-06-20T21:09:19.405+08:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects'
[2020-06-20T21:09:19.406+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLBumper.dll'
[2020-06-20T21:09:19.408+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.408+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLBumper.dll'
[2020-06-20T21:09:19.409+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLChaser.dll'
[2020-06-20T21:09:19.411+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.411+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLChaser.dll'
[2020-06-20T21:09:19.412+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLOutliner.dll'
[2020-06-20T21:09:19.415+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.415+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLOutliner.dll'
[2020-06-20T21:09:19.416+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLRandom.dll'
[2020-06-20T21:09:19.417+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.418+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLRandom.dll'
[2020-06-20T21:09:19.418+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.419+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLStageFlow.dll'
[2020-06-20T21:09:19.420+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.420+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLStageFlow.dll'
[2020-06-20T21:09:19.421+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.422+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLTiler.dll'
[2020-06-20T21:09:19.424+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.425+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLTiler.dll'
[2020-06-20T21:09:19.426+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.428+08:00]   INFO:     Done scanning directory, loaded 6 plugin(s) from it.
[2020-06-20T21:09:19.429+08:00]   INFO:     Load VideoEngine settings
[2020-06-20T21:09:19.429+08:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64'
[2020-06-20T21:09:19.430+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\ColourLoop_FFGL21.dll'
[2020-06-20T21:09:19.434+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.434+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\ColourLoop_FFGL21.dll'
[2020-06-20T21:09:19.435+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.435+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\Mapper2_FFGL21.dll'
[2020-06-20T21:09:19.467+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.467+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\Mapper2_FFGL21.dll'
[2020-06-20T21:09:19.492+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.518+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\Velocity_FFGL21.dll'
[2020-06-20T21:09:19.522+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.522+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\Velocity_FFGL21.dll'
[2020-06-20T21:09:19.524+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:09:19.526+08:00]   INFO:     Done scanning directory, loaded 3 plugin(s) from it.
[2020-06-20T21:09:19.532+08:00]   INFO:     Pass Application name to spout
[2020-06-20T21:09:19.532+08:00]   INFO:     Set thumbnail for capture device sources
[2020-06-20T21:09:19.533+08:00]   INFO:     Initialize video engine
[2020-06-20T21:09:19.534+08:00]   INFO:     Register internal renderpasses
[2020-06-20T21:09:19.765+08:00]   INFO:     Initialize AudioEngine
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Bitcrusher.dll
Creating VST instance: Bitcrusher
Initialising VST: Bitcrusher (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Distortion.dll
Creating VST instance: Distortion
Initialising VST: Distortion (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\EQ-3.dll
Creating VST instance: EQ-3
Initialising VST: EQ-3 (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Flanger.dll
Creating VST instance: Flanger
Initialising VST: Flanger (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\HighPass.dll
Creating VST instance: HighPass
Initialising VST: HighPass (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\LowPass.dll
Creating VST instance: LowPass
Initialising VST: LowPass (V1.0.0)
Attempting to load VST: C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLBumper.dll
Attempting to load VST: C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLChaser.dll
Attempting to load VST: C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLOutliner.dll
Attempting to load VST: C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLRandom.dll
Attempting to load VST: C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLStageFlow.dll
Attempting to load VST: C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLTiler.dll
[2020-06-20T21:09:20.098+08:00]   INFO:     Create ShortcutManagers
[2020-06-20T21:09:20.098+08:00]   INFO:     Create ShortcutPresetManager
[2020-06-20T21:09:20.099+08:00]   INFO:     Install Shortcut Preset preprocessor
[2020-06-20T21:09:20.157+08:00]   INFO:     Create Composition
[2020-06-20T21:09:20.194+08:00]   INFO:     Register Composition with controllers
[2020-06-20T21:09:20.195+08:00]   INFO:     Create DmxController And Load Settings
[2020-06-20T21:09:20.196+08:00]   INFO:     Initializing ArtNet on adapter ethernet_32772.
[2020-06-20T21:09:20.198+08:00]   INFO:     ArtNet initialization succeeded.
[2020-06-20T21:09:20.198+08:00]   INFO:     Load Fixture Presets
[2020-06-20T21:09:20.199+08:00]   INFO:     Register application specific renderpasses and sources
[2020-06-20T21:09:20.213+08:00]   INFO:     Load video effect presets
[2020-06-20T21:09:20.262+08:00]   INFO:     Load video source presets
[2020-06-20T21:09:20.263+08:00]   INFO:     Load audio effect presets
[2020-06-20T21:09:20.264+08:00]   INFO:     Create MainWindow
[2020-06-20T21:09:20.320+08:00]   INFO:     Create MainComponent
[2020-06-20T21:09:20.321+08:00]   INFO:     Install KeyListener
[2020-06-20T21:09:20.321+08:00]   INFO:     Install MouseListener
[2020-06-20T21:09:20.321+08:00]   INFO:     Create Monitor Panel
[2020-06-20T21:09:20.322+08:00]   INFO:     Create Layer Properties Panel
[2020-06-20T21:09:20.322+08:00]   INFO:     Create Clip Properties Panel
[2020-06-20T21:09:20.323+08:00]   INFO:     Create Composition Properties Panel
[2020-06-20T21:09:20.326+08:00]   INFO:     Create Toolbar Panel
[2020-06-20T21:09:20.327+08:00]   INFO:     Create Shortcuts Panel
[2020-06-20T21:09:20.329+08:00]   INFO:     Create File Browser Panel
[2020-06-20T21:09:20.331+08:00]   INFO:     Create Compositions Panel
[2020-06-20T21:09:20.332+08:00]   INFO:     Create Effects Panel
[2020-06-20T21:09:20.333+08:00]   INFO:     Create Sources Panel
[2020-06-20T21:09:20.334+08:00]   INFO:     Create Help Panel
[2020-06-20T21:09:20.334+08:00]   INFO:     Create Layer Group Panel
[2020-06-20T21:09:20.335+08:00]   INFO:     Create Slices Panel
[2020-06-20T21:09:20.335+08:00]   INFO:     Create UI manager
[2020-06-20T21:09:24.661+08:00]   INFO:     Enumerating Compositions took: 4.32044 seconds
[2020-06-20T21:09:24.680+08:00]   INFO:     Install Layout Preset preprocessor
[2020-06-20T21:09:24.680+08:00]   INFO:     Set sparkle update accepted callback
[2020-06-20T21:09:24.681+08:00]   INFO:     Load auto-saved layout
[2020-06-20T21:09:24.692+08:00]   INFO:     Show main window
[2020-06-20T21:09:24.703+08:00]   INFO:     Create ScreenSetupDriver
[2020-06-20T21:09:24.707+08:00]   INFO:     Set ScreenSetup Presets Directory: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Advanced Output
[2020-06-20T21:09:24.707+08:00]   INFO:     Load ScreenSetup Presets
[2020-06-20T21:09:24.720+08:00]   INFO:     Create AdvancedScreenSetupWindow
[2020-06-20T21:09:24.744+08:00]   INFO:     Set ScreenSetup Advanced Preferences file: C:\Users\VJ Hugo\Documents\Resolume Arena\Preferences\AdvancedOutput.xml
[2020-06-20T21:09:24.744+08:00]   INFO:     Enumerate displays and position MainWindow on primary device
[2020-06-20T21:09:24.745+08:00]   INFO:     Init Screen Setup
[2020-06-20T21:09:24.747+08:00]   INFO:     Load Last Screen Setup
[2020-06-20T21:09:24.747+08:00]   INFO:     Install Screen Setup Preset preprocessor
[2020-06-20T21:09:24.748+08:00]   INFO:     Attach screen setup inspector
[2020-06-20T21:09:24.748+08:00]   INFO:     Attach Undo Stack inspector
[2020-06-20T21:09:24.749+08:00]   INFO:     Attach menu to window
[2020-06-20T21:09:24.751+08:00]   INFO:     Create HelpController
[2020-06-20T21:09:24.751+08:00]   INFO:     Load HelpController file
[2020-06-20T21:09:24.752+08:00]   INFO:     Create MidiController
[2020-06-20T21:09:24.752+08:00]   INFO:     Refresh MidiController
[2020-06-20T21:09:24.753+08:00]   INFO:     Load MidiController settings
[2020-06-20T21:09:24.753+08:00]   INFO:     Start MidiController
[2020-06-20T21:09:24.754+08:00]   INFO:     Create renderer
[2020-06-20T21:09:24.754+08:00]   INFO:     Start renderer
[2020-06-20T21:09:24.755+08:00]   INFO:     Main::CompositionLoader::loadStartupComposition: Loading startup composition
[2020-06-20T21:09:24.755+08:00]   INFO:         Opening composition from command line file: "G:\hugo-new-comp.avc"
[2020-06-20T21:09:26.291+08:00]   INFO:         resolume::CompositionManager::loadComposition: Loading composition from content. File: "G:\hugo-new-comp.avc"
[2020-06-20T21:09:26.359+08:00]   INFO:             Reading composition xml data
[2020-06-20T21:09:26.434+08:00]   INFO:                 Forking composition reading
[2020-06-20T21:09:28.902+08:00]   INFO:                 Composition clearing is done
[2020-06-20T21:09:28.903+08:00]   INFO:                 Done reading params, reading shortcut presets next
[2020-06-20T21:09:28.960+08:00]   INFO:                 Done reading sync data, cleaning up
[2020-06-20T21:09:29.036+08:00]   INFO:             Successfully read composition xml
[2020-06-20T21:09:29.037+08:00]   INFO:             Reading composition state took: 2.67702 seconds
[2020-06-20T21:09:29.042+08:00]   INFO:             Setting composition high quality to: true
[2020-06-20T21:09:29.048+08:00]   INFO:             Default color format is now: RGBA16I
[2020-06-20T21:09:29.049+08:00]  ERROR:         Composition loading finished, result: true
[2020-06-20T21:09:29.051+08:00]   INFO:     Loading startup composition finished
[2020-06-20T21:09:29.054+08:00]   INFO: Application successfully initialized
[2020-06-20T21:09:29.054+08:00]   INFO: Initialise took: 15.13658 seconds
[2020-06-20T21:09:29.057+08:00]   INFO: ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLOutliner.dll'
[2020-06-20T21:09:29.060+08:00]   INFO: Plugin was successfully loaded.
[2020-06-20T21:09:29.250+08:00]   INFO: OpenGLCanvas: New context is created
[2020-06-20T21:09:29.251+08:00]   INFO: Initializing GPUMonitor
[2020-06-20T21:09:29.251+08:00]   INFO:     Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:09:29.253+08:00]   INFO: Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:09:29.253+08:00]   INFO: Initializing renderer.
[2020-06-20T21:09:29.253+08:00]   INFO:     Loading shaders...
[2020-06-20T21:09:29.258+08:00]   INFO:     Successfully loaded shaders.
[2020-06-20T21:09:29.267+08:00]   INFO: Successfully initialized renderer.
[2020-06-20T21:09:33.940+08:00]   INFO: Enumerating Compositions took: 4.46351 seconds
[2020-06-20T21:09:34.521+08:00]   INFO: ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLChaser.dll'
[2020-06-20T21:09:34.523+08:00]   INFO: Plugin was successfully loaded.
[2020-06-20T21:09:34.525+08:00]   INFO: ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLChaser.dll'
[2020-06-20T21:09:34.526+08:00]   INFO: Plugin was successfully loaded.
[2020-06-20T21:10:04.098+08:00]   INFO: Setting composition high quality to: true
[2020-06-20T21:10:04.099+08:00]   INFO: Default color format is now: RGBA16I
[2020-06-20T21:10:04.452+08:00]   INFO: Serialize application model
[2020-06-20T21:10:04.453+08:00]   INFO: Serialize video engine
[2020-06-20T21:10:04.453+08:00]   INFO: Serialize audio engine
[2020-06-20T21:10:04.453+08:00]   INFO: Serialize smpte settings
[2020-06-20T21:10:04.454+08:00]   INFO: Create preferences file (config.xml)
[2020-06-20T21:10:04.454+08:00]   INFO: Write preferences XML (config.xml)
[2020-06-20T21:10:04.455+08:00]   INFO: Save animation presets
[2020-06-20T21:10:04.469+08:00]   INFO: Save DMX preferences
[2020-06-20T21:10:04.469+08:00]   INFO: Saving OSC preferences
[2020-06-20T21:10:04.470+08:00]   INFO: Save MIDI preferences
[2020-06-20T21:10:09.083+08:00]   INFO: Enumerating Compositions took: 4.61226 seconds
[2020-06-20T21:10:15.737+08:00]   INFO: Enumerating Compositions took: 4.75492 seconds
Log started: 20 Jun 2020 9:11:05pm
[2020-06-20T21:11:05.121+08:00]   INFO: Logging has started
[2020-06-20T21:11:05.126+08:00]   INFO: Ensuring Nvidia profile correctness
[2020-06-20T21:11:05.304+08:00]   INFO:     Failed adding application Resolume Arena/Arena.exe to custom nvidia profile, it's probably already present
[2020-06-20T21:11:05.304+08:00]   INFO: Nvidia profile setup finished successfully
[2020-06-20T21:11:05.348+08:00]   INFO: Initializing application. Command Line: "G:\hugo-new-comp.avc"
[2020-06-20T21:11:05.348+08:00]   INFO:     Initialise JuceResapiApp
[2020-06-20T21:11:05.348+08:00]   INFO:     Initialise ResApi
[2020-06-20T21:11:05.348+08:00]   INFO:     Initializing Resapi
[2020-06-20T21:11:05.349+08:00]   INFO:         Created ParamCollection
[2020-06-20T21:11:05.349+08:00]   INFO:         Created TaskManager with 10 threads.
[2020-06-20T21:11:05.349+08:00]   INFO:         Created InputController
[2020-06-20T21:11:05.350+08:00]   INFO:         Created DeviceChangeDetector
[2020-06-20T21:11:05.351+08:00]   INFO:         Creating VideoFormatManager
[2020-06-20T21:11:05.351+08:00]   INFO:             Registering basic formats
[2020-06-20T21:11:05.353+08:00]   INFO:             Registered 4 formats
[2020-06-20T21:11:05.353+08:00]   INFO:         Created VideoFormatManager
[2020-06-20T21:11:05.367+08:00]   INFO:         Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
[2020-06-20T21:11:05.371+08:00]   INFO:         Trying to create DirectShow capture input device for: HD Webcam (DirectShow_\\?\usb#vid_04f2&pid_b68b&mi_00#6&37874e19&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global_HD Webcam)
[2020-06-20T21:11:05.564+08:00]   INFO:         Creating DisplayCollection
[2020-06-20T21:11:05.568+08:00]   INFO:         Created DisplayCollection
[2020-06-20T21:11:05.569+08:00]   INFO:         First time OpenGL usage, initializing extensions.
[2020-06-20T21:11:05.569+08:00]   INFO:         Registering window class.
[2020-06-20T21:11:05.569+08:00]   INFO:         Successfully registered window class.
[2020-06-20T21:11:06.035+08:00]   INFO:         Successfully initialized extensions.
[2020-06-20T21:11:06.036+08:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 431.62
[2020-06-20T21:11:06.037+08:00]   INFO:         ---Info main OpenGL renderer---
[2020-06-20T21:11:06.037+08:00]   INFO:         Driver Vendor : NVIDIA Corporation
[2020-06-20T21:11:06.037+08:00]   INFO:         Renderer Name: GeForce RTX 2060/PCIe/SSE2
[2020-06-20T21:11:06.037+08:00]   INFO:         Driver Version: 4.1.0 NVIDIA 431.62
[2020-06-20T21:11:06.038+08:00]   INFO:         OpenGL shader language version: 4.10 NVIDIA via Cg compiler
[2020-06-20T21:11:06.038+08:00]   INFO:         Maximum Supported OpenGL version: 4.1
[2020-06-20T21:11:06.038+08:00]   INFO:         -------------------------------
[2020-06-20T21:11:06.038+08:00]   INFO:         Initializing GPUMonitor
[2020-06-20T21:11:06.039+08:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:11:06.041+08:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:11:06.042+08:00]   INFO:         Initializing renderer.
[2020-06-20T21:11:06.042+08:00]   INFO:             Loading shaders...
[2020-06-20T21:11:06.050+08:00]   INFO:             Successfully loaded shaders.
[2020-06-20T21:11:06.059+08:00]   INFO:         Successfully initialized renderer.
[2020-06-20T21:11:06.083+08:00]   INFO:         Successfully initialized extensions.
[2020-06-20T21:11:06.084+08:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 431.62
[2020-06-20T21:11:06.084+08:00]   INFO:         Initializing GPUMonitor
[2020-06-20T21:11:06.084+08:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:11:06.086+08:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:11:06.086+08:00]   INFO:         Initializing renderer.
[2020-06-20T21:11:06.086+08:00]   INFO:             Loading shaders...
[2020-06-20T21:11:06.091+08:00]   INFO:             Successfully loaded shaders.
[2020-06-20T21:11:06.100+08:00]   INFO:         Successfully initialized renderer.
[2020-06-20T21:11:06.126+08:00]   INFO:         Successfully initialized extensions.
[2020-06-20T21:11:06.126+08:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 431.62
[2020-06-20T21:11:06.126+08:00]   INFO:         Initializing GPUMonitor
[2020-06-20T21:11:06.127+08:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:11:06.128+08:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:11:06.129+08:00]   INFO:         Initializing renderer.
[2020-06-20T21:11:06.129+08:00]   INFO:             Loading shaders...
[2020-06-20T21:11:06.134+08:00]   INFO:             Successfully loaded shaders.
[2020-06-20T21:11:06.143+08:00]   INFO:         Successfully initialized renderer.
[2020-06-20T21:11:06.143+08:00]   INFO:         Initializing Resapi graphics
[2020-06-20T21:11:06.144+08:00]   INFO:             Initializing GPUMonitor
[2020-06-20T21:11:06.144+08:00]   INFO:                 Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:11:06.145+08:00]   INFO:             Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:11:06.146+08:00]   INFO:             Initializing TextureUploader
[2020-06-20T21:11:06.146+08:00]   INFO:                 Determining AutoDetect setting
[2020-06-20T21:11:06.146+08:00]   INFO:                     Immutable Buffers supported: true
[2020-06-20T21:11:06.147+08:00]   INFO:                     GPU Monitoring supported: true
[2020-06-20T21:11:06.147+08:00]   INFO:                 AutoDetect would use DMA transfers
[2020-06-20T21:11:06.147+08:00]   INFO:             Successfully initialized TextureUploader
[2020-06-20T21:11:06.148+08:00]   INFO:         Successfully initialized Resapi graphics.
[2020-06-20T21:11:06.148+08:00]   INFO:     Successfully initialized Resapi.
[2020-06-20T21:11:06.148+08:00]   INFO:     Install default PathParser
[2020-06-20T21:11:06.149+08:00]   INFO:     Enumerate fonts
[2020-06-20T21:11:06.193+08:00]   INFO:     Find default fonts
[2020-06-20T21:11:06.193+08:00]   INFO:     Create Application Object
[2020-06-20T21:11:06.194+08:00]   INFO:     Setting up default composition settings.
[2020-06-20T21:11:06.195+08:00]   INFO:     Resapi: setCurrentApplication
[2020-06-20T21:11:06.196+08:00]   INFO:     Init Colour scheme for user interface
[2020-06-20T21:11:06.196+08:00]   INFO:     Create LookAndFeel
[2020-06-20T21:11:06.198+08:00]   INFO:     Set LookAndFeel
[2020-06-20T21:11:06.198+08:00]   INFO:     Disable screen saver
[2020-06-20T21:11:06.199+08:00]   INFO:     Print version info
[2020-06-20T21:11:06.199+08:00]   INFO:     Major Version: 7
[2020-06-20T21:11:06.199+08:00]   INFO:     Minor Version: 0
[2020-06-20T21:11:06.199+08:00]   INFO:     Micro Version: 5
[2020-06-20T21:11:06.200+08:00]   INFO:     Revision: 67117
[2020-06-20T21:11:06.200+08:00]   INFO:     Id: 1
[2020-06-20T21:11:06.200+08:00]   INFO:     Revision string: rev67117
[2020-06-20T21:11:06.200+08:00]   INFO:     Version string with revision: 7.0.5 67117
[2020-06-20T21:11:06.200+08:00]   INFO:     Version string without revision: 7.0.5
[2020-06-20T21:11:06.201+08:00]   INFO:     Print application paths
[2020-06-20T21:11:06.201+08:00]   INFO:     Executable Path: C:\Program Files\Resolume Arena
[2020-06-20T21:11:06.201+08:00]   INFO:     User Documents Path: C:\Users\VJ Hugo\Documents\Resolume Arena
[2020-06-20T21:11:06.201+08:00]   INFO:     Default Data Path: C:\Program Files\Resolume Arena\default
[2020-06-20T21:11:06.202+08:00]   INFO:     Common Data Path: C:\ProgramData\Resolume Arena
[2020-06-20T21:11:06.203+08:00]   INFO:     Common Documents Path: C:\Users\Public\Documents\Resolume Arena
[2020-06-20T21:11:06.203+08:00]   INFO:     Preferences Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Preferences
[2020-06-20T21:11:06.204+08:00]   INFO:     Media Path: C:\Program Files\Resolume Arena\media
[2020-06-20T21:11:06.204+08:00]   INFO:     Compositions Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Compositions
[2020-06-20T21:11:06.205+08:00]   INFO:     Default Presets Path:
[2020-06-20T21:11:06.205+08:00]   INFO:     User Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets
[2020-06-20T21:11:06.205+08:00]   INFO:     Video Effects Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Video Effects
[2020-06-20T21:11:06.206+08:00]   INFO:     Audio Effects Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Audio Effects
[2020-06-20T21:11:06.206+08:00]   INFO:     Video Sources Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Sources
[2020-06-20T21:11:06.207+08:00]   INFO:     Audio Plugins Path: C:\Program Files\Resolume Arena\plugins\afx
[2020-06-20T21:11:06.207+08:00]   INFO:     Video Plugins Path: C:\Program Files\Resolume Arena\plugins\vfx
[2020-06-20T21:11:06.207+08:00]   INFO:     Previews Path: C:\Users\VJ Hugo\AppData\Local\Resolume Arena\previews
[2020-06-20T21:11:06.208+08:00]   INFO:     Layout Presets Path: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Interface
[2020-06-20T21:11:06.208+08:00]   INFO:     Print system info
[2020-06-20T21:11:06.208+08:00]   INFO:     Operating system: Windows 10
[2020-06-20T21:11:06.208+08:00]   INFO:     OS 64 bit: Yes
[2020-06-20T21:11:06.208+08:00]   INFO:     CPU vendor: GenuineIntel
[2020-06-20T21:11:06.290+08:00]   INFO:     CPU speed: 2205MHz
[2020-06-20T21:11:06.290+08:00]   INFO:     Number of CPUs: 12
[2020-06-20T21:11:06.290+08:00]   INFO:     Memory size: 32625MB
[2020-06-20T21:11:06.291+08:00]   INFO:     System language is: zh
[2020-06-20T21:11:06.291+08:00]   INFO:     Locate preferences directory
[2020-06-20T21:11:06.291+08:00]   INFO:     Locate settings file
[2020-06-20T21:11:06.292+08:00]   INFO:     Load Application settings
[2020-06-20T21:11:06.292+08:00]   INFO:     Install languages
[2020-06-20T21:11:06.296+08:00]   INFO:     Set fonts
[2020-06-20T21:11:06.296+08:00]   INFO:     Looking for unicode font
[2020-06-20T21:11:06.296+08:00]   INFO:     Unicode font found is: Lucida Sans Unicode
[2020-06-20T21:11:06.297+08:00]   INFO:     Language file font setting: FontToRenderThisLanguageInWin
[2020-06-20T21:11:06.297+08:00]   INFO:     Language file font base height setting: 0.00
[2020-06-20T21:11:06.297+08:00]   INFO:     Create ApplicationController
[2020-06-20T21:11:06.299+08:00]   INFO:     Creating NDIVideoServerManager
[2020-06-20T21:11:06.299+08:00]   INFO:         Initializing NDI library
[2020-06-20T21:11:06.303+08:00]   INFO:         Successfully initialized NDI library
[2020-06-20T21:11:06.308+08:00]   INFO:     Created NDIVideoServerManager
[2020-06-20T21:11:06.323+08:00]   INFO:     Update Composition List
[2020-06-20T21:11:10.642+08:00]   INFO:     Enumerating Compositions took: 4.31807 seconds
[2020-06-20T21:11:10.642+08:00]   INFO:     Initializing OSC
[2020-06-20T21:11:10.705+08:00]   INFO:     Install Source Preset preprocessor
[2020-06-20T21:11:10.705+08:00]   INFO:     Install Effect Preset preprocessor
[2020-06-20T21:11:10.705+08:00]   INFO:     Install Animation Preset preprocessor
[2020-06-20T21:11:10.705+08:00]   INFO:     Loading Animation presets
[2020-06-20T21:11:10.710+08:00]   INFO:     Create AudioEngine
[2020-06-20T21:11:10.780+08:00]   INFO:     Load AudioEngine settings
[2020-06-20T21:11:10.780+08:00]   INFO:     Load SMPTE settings
[2020-06-20T21:11:10.780+08:00]   INFO:     Setup Effect presets directory
[2020-06-20T21:11:10.781+08:00]   INFO:     Enabling NDI support
[2020-06-20T21:11:10.781+08:00]   INFO:     Setup Source presets directory
[2020-06-20T21:11:10.781+08:00]   INFO:     Creating VideoSourceManager
[2020-06-20T21:11:10.782+08:00]   INFO:     Created VideoSourceManager
[2020-06-20T21:11:10.782+08:00]   INFO:     Create VideoEngine
[2020-06-20T21:11:10.783+08:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Program Files\Resolume Arena\plugins\vfx'
[2020-06-20T21:11:10.783+08:00]   INFO:     Done scanning directory, loaded 0 plugin(s) from it.
[2020-06-20T21:11:10.783+08:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects'
[2020-06-20T21:11:10.784+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLBumper.dll'
[2020-06-20T21:11:10.786+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.786+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLBumper.dll'
[2020-06-20T21:11:10.787+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLChaser.dll'
[2020-06-20T21:11:10.789+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.789+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLChaser.dll'
[2020-06-20T21:11:10.790+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLOutliner.dll'
[2020-06-20T21:11:10.793+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.793+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLOutliner.dll'
[2020-06-20T21:11:10.794+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLRandom.dll'
[2020-06-20T21:11:10.795+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.796+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLRandom.dll'
[2020-06-20T21:11:10.796+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.797+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLStageFlow.dll'
[2020-06-20T21:11:10.798+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.799+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLStageFlow.dll'
[2020-06-20T21:11:10.799+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.800+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLTiler.dll'
[2020-06-20T21:11:10.802+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.803+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLTiler.dll'
[2020-06-20T21:11:10.804+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.806+08:00]   INFO:     Done scanning directory, loaded 6 plugin(s) from it.
[2020-06-20T21:11:10.807+08:00]   INFO:     Load VideoEngine settings
[2020-06-20T21:11:10.807+08:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64'
[2020-06-20T21:11:10.808+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\ColourLoop_FFGL21.dll'
[2020-06-20T21:11:10.812+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.812+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\ColourLoop_FFGL21.dll'
[2020-06-20T21:11:10.813+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.813+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\Mapper2_FFGL21.dll'
[2020-06-20T21:11:10.844+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.845+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\Mapper2_FFGL21.dll'
[2020-06-20T21:11:10.870+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.896+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\Velocity_FFGL21.dll'
[2020-06-20T21:11:10.899+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.900+08:00]   INFO:         ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\AppData\Roaming\JuiceBar\resolume7_win64\Velocity_FFGL21.dll'
[2020-06-20T21:11:10.902+08:00]   INFO:         Plugin was successfully loaded.
[2020-06-20T21:11:10.904+08:00]   INFO:     Done scanning directory, loaded 3 plugin(s) from it.
[2020-06-20T21:11:10.910+08:00]   INFO:     Pass Application name to spout
[2020-06-20T21:11:10.910+08:00]   INFO:     Set thumbnail for capture device sources
[2020-06-20T21:11:10.911+08:00]   INFO:     Initialize video engine
[2020-06-20T21:11:10.912+08:00]   INFO:     Register internal renderpasses
[2020-06-20T21:11:11.144+08:00]   INFO:     Initialize AudioEngine
[2020-06-20T21:11:11.477+08:00]   INFO:     Create ShortcutManagers
[2020-06-20T21:11:11.477+08:00]   INFO:     Create ShortcutPresetManager
[2020-06-20T21:11:11.478+08:00]   INFO:     Install Shortcut Preset preprocessor
[2020-06-20T21:11:11.536+08:00]   INFO:     Create Composition
[2020-06-20T21:11:11.575+08:00]   INFO:     Register Composition with controllers
[2020-06-20T21:11:11.575+08:00]   INFO:     Create DmxController And Load Settings
[2020-06-20T21:11:11.576+08:00]   INFO:     Initializing ArtNet on adapter ethernet_32772.
[2020-06-20T21:11:11.578+08:00]   INFO:     ArtNet initialization succeeded.
[2020-06-20T21:11:11.579+08:00]   INFO:     Load Fixture Presets
[2020-06-20T21:11:11.580+08:00]   INFO:     Register application specific renderpasses and sources
[2020-06-20T21:11:11.593+08:00]   INFO:     Load video effect presets
[2020-06-20T21:11:11.643+08:00]   INFO:     Load video source presets
[2020-06-20T21:11:11.643+08:00]   INFO:     Load audio effect presets
[2020-06-20T21:11:11.645+08:00]   INFO:     Create MainWindow
[2020-06-20T21:11:11.660+08:00]   INFO:     Create MainComponent
[2020-06-20T21:11:11.661+08:00]   INFO:     Install KeyListener
[2020-06-20T21:11:11.661+08:00]   INFO:     Install MouseListener
[2020-06-20T21:11:11.661+08:00]   INFO:     Create Monitor Panel
[2020-06-20T21:11:11.662+08:00]   INFO:     Create Layer Properties Panel
[2020-06-20T21:11:11.662+08:00]   INFO:     Create Clip Properties Panel
[2020-06-20T21:11:11.663+08:00]   INFO:     Create Composition Properties Panel
[2020-06-20T21:11:11.665+08:00]   INFO:     Create Toolbar Panel
[2020-06-20T21:11:11.666+08:00]   INFO:     Create Shortcuts Panel
[2020-06-20T21:11:11.668+08:00]   INFO:     Create File Browser Panel
[2020-06-20T21:11:11.670+08:00]   INFO:     Create Compositions Panel
[2020-06-20T21:11:11.672+08:00]   INFO:     Create Effects Panel
[2020-06-20T21:11:11.673+08:00]   INFO:     Create Sources Panel
[2020-06-20T21:11:11.673+08:00]   INFO:     Create Help Panel
[2020-06-20T21:11:11.674+08:00]   INFO:     Create Layer Group Panel
[2020-06-20T21:11:11.674+08:00]   INFO:     Create Slices Panel
[2020-06-20T21:11:11.674+08:00]   INFO:     Create UI manager
[2020-06-20T21:11:16.011+08:00]   INFO:     Enumerating Compositions took: 4.33067 seconds
[2020-06-20T21:11:16.029+08:00]   INFO:     Install Layout Preset preprocessor
[2020-06-20T21:11:16.029+08:00]   INFO:     Set sparkle update accepted callback
[2020-06-20T21:11:16.029+08:00]   INFO:     Load auto-saved layout
[2020-06-20T21:11:16.041+08:00]   INFO:     Show main window
[2020-06-20T21:11:16.048+08:00]   INFO:     Create ScreenSetupDriver
[2020-06-20T21:11:16.052+08:00]   INFO:     Set ScreenSetup Presets Directory: C:\Users\VJ Hugo\Documents\Resolume Arena\Presets\Advanced Output
[2020-06-20T21:11:16.052+08:00]   INFO:     Load ScreenSetup Presets
[2020-06-20T21:11:16.064+08:00]   INFO:     Create AdvancedScreenSetupWindow
[2020-06-20T21:11:16.078+08:00]   INFO:     Set ScreenSetup Advanced Preferences file: C:\Users\VJ Hugo\Documents\Resolume Arena\Preferences\AdvancedOutput.xml
[2020-06-20T21:11:16.078+08:00]   INFO:     Enumerate displays and position MainWindow on primary device
[2020-06-20T21:11:16.079+08:00]   INFO:     Init Screen Setup
[2020-06-20T21:11:16.081+08:00]   INFO:     Load Last Screen Setup
[2020-06-20T21:11:16.081+08:00]   INFO:     Install Screen Setup Preset preprocessor
[2020-06-20T21:11:16.082+08:00]   INFO:     Attach screen setup inspector
[2020-06-20T21:11:16.082+08:00]   INFO:     Attach Undo Stack inspector
[2020-06-20T21:11:16.083+08:00]   INFO:     Attach menu to window
[2020-06-20T21:11:16.084+08:00]   INFO:     Create HelpController
[2020-06-20T21:11:16.085+08:00]   INFO:     Load HelpController file
[2020-06-20T21:11:16.086+08:00]   INFO:     Create MidiController
[2020-06-20T21:11:16.086+08:00]   INFO:     Refresh MidiController
[2020-06-20T21:11:16.087+08:00]   INFO:     Load MidiController settings
[2020-06-20T21:11:16.087+08:00]   INFO:     Start MidiController
[2020-06-20T21:11:16.088+08:00]   INFO:     Create renderer
[2020-06-20T21:11:16.088+08:00]   INFO:     Start renderer
[2020-06-20T21:11:16.088+08:00]   INFO:     Main::CompositionLoader::loadStartupComposition: Loading startup composition
[2020-06-20T21:11:16.089+08:00]   INFO:         Opening composition from command line file: "G:\hugo-new-comp.avc"
[2020-06-20T21:11:17.608+08:00]   INFO:         resolume::CompositionManager::loadComposition: Loading composition from content. File: "G:\hugo-new-comp.avc"
[2020-06-20T21:11:17.676+08:00]   INFO:             Reading composition xml data
[2020-06-20T21:11:17.748+08:00]   INFO:                 Forking composition reading
[2020-06-20T21:11:20.127+08:00]   INFO:                 Composition clearing is done
[2020-06-20T21:11:20.128+08:00]   INFO:                 Done reading params, reading shortcut presets next
[2020-06-20T21:11:20.185+08:00]   INFO:                 Done reading sync data, cleaning up
[2020-06-20T21:11:20.260+08:00]   INFO:             Successfully read composition xml
[2020-06-20T21:11:20.260+08:00]   INFO:             Reading composition state took: 2.58377 seconds
[2020-06-20T21:11:20.265+08:00]   INFO:             Setting composition high quality to: true
[2020-06-20T21:11:20.271+08:00]   INFO:             Default color format is now: RGBA16I
[2020-06-20T21:11:20.272+08:00]  ERROR:         Composition loading finished, result: true
[2020-06-20T21:11:20.275+08:00]   INFO:     Loading startup composition finished
[2020-06-20T21:11:20.277+08:00]   INFO: Application successfully initialized
[2020-06-20T21:11:20.278+08:00]   INFO: Initialise took: 14.92972 seconds
[2020-06-20T21:11:20.280+08:00]   INFO: ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLOutliner.dll'
[2020-06-20T21:11:20.283+08:00]   INFO: Plugin was successfully loaded.
[2020-06-20T21:11:20.477+08:00]   INFO: OpenGLCanvas: New context is created
[2020-06-20T21:11:20.478+08:00]   INFO: Initializing GPUMonitor
[2020-06-20T21:11:20.478+08:00]   INFO:     Trying to create NVApi GPUMonitorStrategy.
[2020-06-20T21:11:20.480+08:00]   INFO: Successfully initialized GPUMonitor, using NvApi strategy.
[2020-06-20T21:11:20.480+08:00]   INFO: Initializing renderer.
[2020-06-20T21:11:20.480+08:00]   INFO:     Loading shaders...
[2020-06-20T21:11:20.485+08:00]   INFO:     Successfully loaded shaders.
[2020-06-20T21:11:20.494+08:00]   INFO: Successfully initialized renderer.
[2020-06-20T21:11:25.084+08:00]   INFO: Enumerating Compositions took: 4.39243 seconds
[2020-06-20T21:11:25.646+08:00]   INFO: ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLChaser.dll'
[2020-06-20T21:11:25.648+08:00]   INFO: Plugin was successfully loaded.
[2020-06-20T21:11:25.650+08:00]   INFO: ra::WinPluginInstance::load: Loading plugin 'C:\Users\VJ Hugo\Documents\Resolume Arena\Extra Effects\FFGLChaser.dll'
[2020-06-20T21:11:25.651+08:00]   INFO: Plugin was successfully loaded.
vjhugo
Post by vjhugo »
Weird, how long does Resolume keep being stuck if you leave it?
How much free space do you have on your C: drive?
