Shark Navigator Lift-Away Reviews: Shark NV352
jamesmustain
Post by jamesmustain »
Choosing between different Shark vacuums can be the most challenging task for many homeowners. If you're looking for a versatile and durable vacuum cleaner that can clean every part of your house, including the upholstery and stairs, then a Shark Navigator Lift Away is your best bet. The Shark lift away vacuum cleaner is one of the top-rated bagless upright vacuums in the market.
There are various models in this vacuum category: NV350, NV351, NV352, NV354, and so on. In these Shark navigator lift away reviews, we will discuss the main features of the Shark NV352 model and the reasons why you should purchase this vacuum cleaner. Let's decide whether this is the right choice for you below.
Selected For You: Best Shark Navigator Lift Away - Review and buying guide
First Look
The Shark navigator lift away upright vacuum NV352 can be used as an upright and a canister vacuum. Lift-away technology allows you to remove the canister and use it to clean those hard-to-reach and above-ground areas.
If you worry about carrying a heavy upright vacuum cleaner up the stairs, the NV352 has solved the problem. Now, you can use the NV352 as a powerful upright vacuum and a detachable canister vacuum at the same time. Cleaning stairs and upholstery has never been more accessible.
Product Specifications
Product Dimensions: 14.9 x 11.4 x 45.5 inches
Vacuum Type:Upright Bagless
Weight: 12.5 lbs
Cord Length:25 feet
Air Filter: Anti Allergen Complete Seal Technology
Lift Away: Yes
Brush on/off switch: Yes
Power: 1,200 watts
Voltage: 120 volts
Swivel steering: Yes
LED Headlight: No
Wash surface: Carpeted floors, hard floors
Cleaning Path: 9.25"
Overall reach: Approx. 37 feet
Warranty: 5 years
Pros
  • Lift-away technology to clean above-flooring areas
  • HEPA filter and Anti Allergen Complete Seal technology to keep allergens from escaping outside the vacuum
  • Large dust cup capacity
  • Swivel steering for maximum maneuverability
  • Relatively lightweight for an upright vacuum
  • Features multiple helpful tools such as crevice tool, dusting brush, pet hairbrush
  • Limited five-year warranty
  • Relatively quiet compared to other cleaners
Cons
  • No LED headlights
Main Features
Suction Power
What we love most about this Shark navigator lift-away bagless upright vacuum is its powerful and reliable suction. It is essential to choose a vacuum that comes with a robust suction power to get rid of debris and particles on the floor.
The Shark NV352 upright vacuum performs well on hard floors and carpets, with a 1200 W motor. You won't have to worry about going over the same spot several times without the cleaner picking up the dirt.
The motorised brush switch lets you adjust to different surfaces without leaving scratches on your floor. The shark navigator lift-away upright vacuum can pick up all types of debris trapped underneath your carpet, which is a challenge for many other types of vacuum cleaners.
If you're looking for a machine that does an impressive job of cleaning on both hardwood floors and deep-pile carpet, the NV352 is a great option.
Appearance
The Shark navigator lift away vacuum cleaner isn't the most compact vacuum on the market. However, it is relatively lightweight compared to another upright vacuum with similar suction power. Plus, you can always detach the canister from the central unit and carry it up the stairs comfortably, thanks to Lift-Away technology.
The Shark NV352 weighs 12.5 pounds, with the detachable canister alone weighing only 7.5 pounds, which isn't too heavy for most homeowners. This model's dimensions are 15 x 11.4 x 45.5 inches, which will be the best option for large houses.
Swivel Steering
Nothing is more annoying than not being able to steer your vacuum where you want it to go. You will fall in love with this vacuum's swivel steering design once you try it. This feature lets you maneuver freely across different areas in your house.
If you have kids that tend to leave toys lying around the house, this Shark navigator lift away will swivel through any obstacles and clean every spot in no time. Cleaning around the furniture will be much easier now with swivel steering technology.
HEPA Filter
When choosing a vacuum, a filter is one of the most crucial features. The NV352 Shark lift away vacuum cleaner uses HEPA filtration, an innovative technology that wins many users' hearts. If you suffer from any allergic diseases like asthma, it is necessary to ensure the air in your living space is completely clean.
HEPA filtration system and Anti Allergen complete seal can trap 99.9% of particles and prevent them from getting outside. This seal technology is best for anyone who has a dust allergy.
Many owners stated that they were happy with the filters - the foam filter to capture the larger dust particles and the HEPA filter that keeps the finer particles from escaping back into the air.
The foam filter is washable, and you can rinse the HEPA filter under running water with ease. You should check the filters regularly and clean them with care to optimize their performance.
We highly recommend that you clean and wash them every two to three months. Please check with the manufacturer for more information on how to care for your vacuum.
One feature that we enjoy using most is the lift-away system, where you can remove the canister from the bottom unit and carry it around the house. You can clean above-ground spaces, stairs, furniture, and so on without lifting the heavy upright vacuum. Even with tight corners and narrow spaces, many helpful tools can help you clean efficiently.
Price
You can get this durable and versatile machine at a highly reasonable price. With Lift-away technology, HEPA filters, and powerful suction, this Shark navigator lift upright vacuum will provide you with all the essential cleaning needs. If you're looking to buy a product that can clean both carpets and hardwood floors with a friendly price tag, the NV352 will not disappoint.
Summary
We hope that you enjoyed reading our Shark navigator lift-away vacuum reviews. The Shark NV352 is a multi-surface powerful cleaning tool that fits every household. You can use it as an upright vac or a canister vacuum cleaner, making it a great purchase all year round. If you love our reviews, subscribe and find more amazing product reviews on our page.
About TheKingLive
TheKingLive provides one of the most detailed reviews of house equipment and more. You can trust that our reviews are honest and in your best interest. Hours of research and testing are put into each review, we wish that everyone who reads this can learn more about the product specifications, buying guides, and other useful information. If you love reading TheKingLive reviews, please subscribe and share this with your friends!
Might as well join the team
Re: Presets of controlling resolume with Beatstep Pro
It should be really easy to just click on what you want mapped and then move a fader or push a button. Shouldn't take more than 5 min to map a controller for basic setups :)
https://resolume.com/support/en/midi-shortcuts
