Midi sequencer running Resolume...
				fdumouchel@s2i.com_
This is a tricky one I hope... I'm running resolume with my MPC4000 to sync the beat with the visual... But the problem is... all the sequence are running on the first layer... when I trid to put and other visual on the second layer... the animation goes to it... but I have to be really fast and clic again on the first layer... otherwise all the sequnce continu in the second layer... can I assign my visual in the layer I want?
				komart_
well, i did it with a mc 50 and i had no problem like yours,be sure to well assign the layer notes and it may be ok : when you want a sequence on L2,make it begin with L2 note...you should can have the 3 layers with differnts animations in ( i did it so why won't you can do it as i'm newbie with sequencer )ah,i forgot to tell you that i play my sequence live and  record then as i don't programm my mc ( too boring )
hope it may help you !
