Resolume with Aja Corvid 24
justusvdh
Post by justusvdh »
i work at a tv-broadcaster where somewhat dedicated hard- and software is used for displaying images and video's on 2 HD-Screens.
The computer used for this has an Aja Corvid 24 inside with BNC-output buses.
The ouputsignals are SDI.
I'm looking for an alternative and Resolume seems fit for the job.
I installed Arena on this computer and thought i set everything up the right way; i configured 2 screens in Advanced and choose the Aja card as Device, the first screen has Aja output 1 and the second screen has Aja output 2.
Now i see there is activity, because as soon as i start up Resolume the screens turn green, nevertheless i cant get images or video's visible that i add to the layers. Can the issue be caused by outdated Aja drivers and the machine running Windows 7?
Can i even use an Aja Corvid 24 as output? How do i configure this properly?
Tnx
sleepytom
Re: Resolume with Aja Corvid 24
Post by sleepytom »
yes i have a corvid 24 here that works fine on the latest drivers and windows 10.
can you get video output via the corvid in other applications?
