Wire ISF static
corlian
Wire ISF static
Post by corlian »
Anyone know why this ISF (and some others) have static on the image in Wire?
https://editor.isf.video/shaders/605a2b ... 0014cdc635
Re: Wire ISF static
Works for me. Are you automating the time?
corlian
Re: Wire ISF static
Post by corlian »
I am yeah. Mine looks like this regardless of the motion of time:
It looks like that in both Wire and Arena.
I am on a Mac, and I imported the shader via 'New from clipboard'
Re: Wire ISF static
My guess is that it's a Mac issue. Mine looks just like the website.
Re: Wire ISF static
Are you on an M1 mac?
corlian
Re: Wire ISF static
Post by corlian »
Zoltán wrote: Thu Dec 08, 2022 15:18 Are you on an M1 mac?
I am, and it looks like in this case (vs some of my other shader issues) I do have this problem using other programs as well. After the last comment, I tested it in Magic and got the same static.
Re: Wire ISF static
Thanks for confirming, I've made a ticket, maybe we can do something about this on our side.
Re: Wire ISF static
Code: Select all
float i,g,d=1.;
only initializes variable d in the shader code, the others are undefined, which produces weird issues on mac.
