Any chance of adding Next or Specific COLUMN as an option as an Autopilot action?
For example, a looped background and a play once and clear clip as PIP and wanting to change both automatically as the pip clip ends.
[IMPLEMENTED in 7.22] Autopilot Play next Column?
- Bassindaniel
Re: Autopilot Play next Column?
+1
the only "solution" is to make all clips is in the same length and autopilot all layers
+1
would be very helpful, to be able to activate the Column of the composition
with a single clip's "play next" Autopilot action.
we need "Play Specific Column"
thank you for an amazing tool
