Dedicated GPU and Mobo Outputs
bonuslazer
Post by bonuslazer »
Building a form factor itx machine for shows requiring 4 outputs. Additionally I would like to run a monitor out of the motherboard. I know Resolume doesn't do well with iGPU, but would it be able to be used just for monitor output, and have the other 4 feed coming out of my 2080ti? Listing the relavent hardware in my build below...
ASUS ROG Strix X570-I Gaming, X570 mini-ITX
Specification GeForce RTX 2080 Ti SEA HAWK
AMD Ryzen 5 5600G 6-Core 12-Thread Unlocked Desktop Processor with Radeon Graphics
Thoughts?
Han
Re: Dedicated GPU and Mobo Outputs
Post by Han »
Did this last year with an Intel Cpu and Nvidia A4000.
The iGPU was connected to the GUI and A4000 to 3x Projectors and 1x LED Screen.
It works without any Problems.
But I will mention that there was 4x 1080p Video Output. No FX, No fancy generative sources and so on.
Might as well join the team
Whatever monitor/GPU that has your UI window on it will be your rendering GPU. What resolution will your outputs be? Maybe having your rendering GPU and UI window attached to your 2080 and then have a AJA corvid-88 card in your enclosure for (8) 3G outputs or a corvid4K for (4) 4K outputs? The corvid line is also hardware sync'd so it's like having a Quadro card, but the rendering still needs to be on a descent GPU. 2080 should be fine.
