Hi all,
This was possible in the past. An old version of Adobe Bridge was capable of displaying DXV Thumbnails, does anyone know what version it was??? And if that version would work with Windows 11
Old version of Adobe Bridge to display Thumbnails
Alvis_Cortex
Re: Old version of Adobe Bridge to display Thumbnails
Do you have Arena or Alley installed on the machine?
Alvis_Cortex
Yep I have both. The reason for wanting to use Bridge is because I like being able to tag/label clips so I can quickly search for a specifi clip or category on the fly
Did you install Resolume before or after the Adobe apps?
If before, it might not have placed the DXV Adobe plugins.
SeanBannister
I just found this topic because I'm also having the same problem, I cannot play DXV 3 in Adobe Bridge. I may have installed Adobe Bridge before Resolume initially but I've completed Resolume upgrades since. I can export to DXV 3 in Adobe Premiere fine.
I'm tempted to uninstall Arena and do a reinstall but I'm unsure what the ramifications of this are as far as backups go.
