Wire Trigger on activation
DTBerlin
Post by DTBerlin »
please excuse the question:
Iam searching for a way to trigger my trigger and reset buttons in wire, when i activate the effect (click on it inside resolume in the layer slots)
This must be very trivial, but i cannot find any solution. Another question in this regards would be if there is a way to have an "release" trigger too.
the goal is to have a time measure starting on activation and stopping when i deactivate the clip.
Thanks you
Re: Wire Trigger on activation
Check the Transport play node.
