Is there a location where backup saves are being generated as you work?
I'm hoping that the hours I spent creating all of these clips are not lost just because Resolume just crashed.
My understanding was it was saving in the background, but as far as I can tell it only saves upon exit or creating a new project file.
Ableton has a running backup recovery folder where it is saving instances of the project. Where is this located for Resolume?
Where are backup saves?
Re: Where are backup saves?
Resolume does not save automatically currently.
Also not on exit, but asks if you want to save on exit.
If you see crashes, please use the crash reporter dialog that pops up after the crash to submit a crash report?
That way we get lot more detailed information about what went wrong exactly.
Don't forget to fill out your email address, so we know it came from you
Should I put my email address or the company email address used for registration? Or does it not matter?
Either is good, then drop us a regular mail to mail@resolume.com so we can go look for the report.
