Geforce 4 overlay
Tribalism_
Post by Tribalism_ »
Is it possible to use the geforce4 overlay to have 2 outputs 1 on the control monitor and 1 on the output monitor. Or is it only with the Matrox videocards.
Wayne_
Post by Wayne_ »
I am planning to try this out tonight as I recently got a new GeForce. I will let you know 2nite!
no the GeForce can not work with an overlay like the Matrox card.
For the technical peeps: the matrox videocard support so called RGB overlay surfaces. And the Geforce card only suport YUV overlay surfaces. To use the YUV overlay we need to convert our RGB pixels to the YUV system. And this is very slow so we can get it working only at 6 frames per second ;-(
Wayne_
Post by Wayne_ »
what about using the nView technology on a GeForce 4? It has dual crt support!
tribalism_
Post by tribalism_ »
Nview works fantastic, but the main problem is dat I want 2 outputs :-) and that is not possible with the overlay feature from nvidia cards.
