I am a person who purchased "Resolume Arena 7". Resolum does not start with the following configuration, so I would like to know your operating environment or recommended configuration. I would like to use Windows as the OS. Thank you.
[PC configuration]
・Processor: Intel(R) Core(TM) i7-10700T CPU @ 2.00GHz 1.99 GHz
・Memory: Installed RAM 32.0 GB (31.7 GB usable)
・Graphics: NVIDIA Quadro P620
・OS: Windows 11 Pro 64bit
Could you please tell us about your hardware configuration?
Re: Could you please tell us about your hardware configuration?
What do you mean it dont start?
It deffenitly should start... the performance is a total different topic but starting should be possible....
~Berlin~
~Berlin~
It should run it.
Your graphics card should get upgraded sooner than later, and I would make sure you have a quality nVme with adequate storage installed as well.
Mr. Heneg, Mr. Alvor.
Thanks for the replies.
I installed the latest "Resolume_Arena_7_18_2_rev_29742_Installer",
When I start "Resolume Arena", I get a Crash report screen and it does not start.
I will try updating the graphics driver.
Does frame dropping occur when playing 4 1920x1080 mp4 files at the same time on GTX-1060?
If frame dropping does not occur, I would like to purchase it.
- Attachments
- resolume_error.png (21.35 KiB) Viewed 34885 times
Please fill out the form and send it, don't forget to add your email to it so we know it came from you.
Mr. Zoltán Thank you for contacting us.
We have just sent you a crash report via dialog.
Could you please tell me the best PC configuration for the following requirements?
Resolution: 4K 1 output
Video files: 4 simultaneous 2k 60fps video files.
Capture: 4 simultaneous 2k 60fps captures.
There is no upper limit to the price of a PC, so we would like to have a configuration that does not cause frame drops or delays even when played back simultaneously. Thank you in advance.
What are the sources you will be capturing? Will your (1) 4K output have different things playing in each quadrant?
Mr. Arvol.
The source to be captured is HDMI (4K). I would also like to display the four input HDMIs separately on the output.
If you want to future proof yourself, Here's a pretty descent prebuild that will get you going strong out of the gate, you would just need to buy the input card.
https://www.bestbuy.com/site/cyberpower ... Id=6553010
