Hey all,
New here. Is there a way to have a clip automatically play when it sees that proper timecode offset?
I would like to automate the entire show so I do not need to press clips. Or atleast just the first one
to wait for incoming code.
Currently I have offsets for 5 different songs set in order on a layer. On the autopilot tab for Action i have it set to , Play Next clip but it doesn't seem to be working.
Is there another method? Thanks!!
Timecode. Auto Play Clips
Re: Timecode. Auto Play Clips
I didn't found the solution to avoid arming the clip natively in software, I manage to do it with chaitagne
viewtopic.php?t=23889
