Choosing osc to send instead of all or none
cat
Post by cat »
Is it possible to send some osc messages, not all of them? I can't see a way of deslecting some, eg I don't want timelines, but pretty much everything else, is this possible?
Re: Choosing osc to send instead of all or none
you can create custom OSC presets to send specific items only
https://resolume.com/support/en/osc?#osc-output
cat
Post by cat »
Its more like excluding them, I don't want to send transports, they get sent every frame and clutter up messaging, so you can never do a learn in another program, or just have a backup laptop playing the same cues (they don't need to be frame sync'd) An enable button would let you turn off the spam, rather than creating custom messages for every layer clip deck and slider. Turn on your osc monitor while playing a couple of layer and try and debug some messages, just as an example... Yes its sending, but did send or catch my custom command...
