Reading the forumtopics, it seems that this problem is occuring with a lot of people.
I already reported this problem in de "Graphics Card" topic but as the output to multiple screens is (imho) the most important feature in Resolume, I started a new topic to keep it a bit clear!
The problem: No output on 2nd monitor/beamer/screen.
Only when running the interface and the outputscreen on the same monitor it works.
Also... if you move a WINDOWED outputbox a littlebit to the 1st screen so that 99% is on the 2nd screen it also works... but hey.. that isn't normal isn't it?
PC specs: AMD athlon 64 X2
OS: Windows XP pro
Graphics: NVidia 7600 GT --> tried it with original Nvidia drivers and also the Omega drivers.. Same result.. No output on 2nd screen!
Before installing Resolume 3 nothing was changed to my PC config... When running Resolume 2.41 it works like normal...
No output on 2nd screen !
Re: No output on 2nd screen !
I've noticed this seems to be mainly nvidia cards -has anyone with an ATI had the same issue?
I updated my drivers to 179.12 last night using laptop2go.com and am still getting this issue, but it sounds like people are getting this issue on nvidia under omega, and regular nvidia drivers.
Yes it seems to be mainly a NVIDIA problem.
So let us know which model you have and we might be able to track down the problem.
like you say edwin, look like a nvidia problem
still trying all kind of thinks but dont found the issue...
this is my confguration :
xp pro
intel pentium 4cpu 3ghz 2,00gb
nvidia geforce 6800gt with last omega 2.169.21 driver
xp pro
Vj NoWig
The Visual Brothers,amsterdam
Graphics: NVidia 7600 GT --> tried it with original Nvidia drivers and also the Omega drivers.. Same result.. (see first post)
[edit] just came across the Nvidia site.. i see there was an update on september 25th... trying that now...
[edit2]
again same result...
[edit2]
Are all of these problematic Nvidia devices mobile (laptop) chips?
On the other side of the coin, after testing last night, my BFG 9800GTX 512 OC card worked fine on either 2nd dvi/vga or svideo/composite out. *knock on wooden wuzzle*
VJ Wuzzle
Shakti Collective - Toronto, Canada
i'm working on a desktop PC.. so just a normal PCIe card.
[edit] LOGfile added!
- Attachments
- GeeEs_Resolume Avenue 3 log.zip
- My Resolume Logfile
- (1.88 KiB) Downloaded 1491 times
Same problem
nVidia GeForce 8800 GTS x2
