Any bugs On brand new Mac Book PROS?
weezhum
Post by weezhum »
HOw does avenue work on The new mac book pros that just came out
Re: Any bugs On brand new Mac Book PROS?
It has no s-video or composite out so you can not connect it to a video mixer that has only s-video or composite.
viewtopic.php?f=7&t=4082
weezhum
What is a guy to do ???????
Post by weezhum »
Wont run on my cheap laptop.
Cant buy new one with vista.
Cant buy a new mac because no svideo out!!!!!
I wanna cry!!!!1
What is the solution? :x
lo-res
Post by lo-res »
is it not possible to get a DVI to video adaptor?
pipoca
Post by pipoca »
You can get a DVI to s-video/composit adaptor.
Take I look at the Apple online store
I have a mac book and I use one of those to connect to a Edirol V4 with no problems what so ever.
And they are not expensive.
Pipoca.
pipoca wrote:You can get a DVI to s-video/composit adaptor.
Yes this works on the old MacBook but the new one does not have a DVI connection but a MINI-DisplayPort.
All this info is on the Apple website:
http://www.apple.com/macbook/specs.html
weezhum
Post by weezhum »
So that begs the question,
what laptop to buy
Cant go vista
cant go new mac book pro.
im sad, i just want to use it!
NLS6XX
Post by NLS6XX »
The old Macbook Pro's are still on sale (at least in Belgium) and they are significantly cheaper than they used to be. Don't forget that these are still very powerfull machines. Also since the 17" hasn't been renewed, but has been upgraded to standard 4gigs ram, you might check out if they updated the video connections as well or if they stayed the same as with the old models.
My 2cts...
noplacia
PROBLEM ON MY MCBOOK PRO
Post by noplacia »
I tried resolume avenue beta on my 2.6 GHz intel core 2 duo, 4 Gb memory, using my footages (Mov, photo-jpeg compression), i use a TV for output, using a dvi converter..
after about 5 minutes, resolume avenue sudenly shut off, and it's going again and again after I restart the program or the computer..
please someone help me..
Bart.. help me
noplacia wrote:after about 5 minutes, resolume avenue sudenly shut off, and it's going again and again after I restart the program or the computer..
Try deleting the files in this directory:
~/Documents/Resolume Avenue 3/preferences/
