64 videos made into "Thriller" masterpiece
xdj
Post by xdj »
http://www.youtube.com/watch?v=pFAVxaEc ... half-month
NOW PLEASE HELP ME OUT
I have a few 100 video clips, all the same format, same size
wondering if its possible to have reolume run by its self in a automatic mode, I have tried the chaos mode, but its to erratic, I have to dj and don't have the time to vj
basically is it possible to load 50 videos, apply the effects to those clips, then have the videos transition and react to the music bpm
thanks for any input, I am using 2.41, my spare laptop does not have the power to run the new resolume
serik
Re: 64 videos made into "Thriller" masterpiece
Post by serik »
if you know how to patch or are willing to learn it you could probably use puredata or max/msp to analyse the sound to detect the bpms and then send random midi notes to a virtual midi device. in resolume you just have to define the right midi notes to your clips.
in a simple version there would be only hard cuts but i think its possible to enhance it to make transitions. also deck switching would be a little bit more complicated if you want to use a few 100 clips i guess you would have to do that ... but it think its doable. but here you could also assigne a key to switch decks and after every song you just push the button manually.
