Resolume 3.0.1 Released
We have just released Resolume 3.0.1. This micro update fixes bugs, improves stability and handles corrupt video files better. Recording is fixed once and for all and it now records both audio and video! In the preferences you can enable and disable audio and video recording. We've had a lot of fun creating AV samples with the new recording and we hope you'll enjoy it too.
This is a free update as usual so go ahead and download Resolume 3.0.1.
Unfortunately we learned the hard way that Mac PowerPC support is not possible for Avenue so if you bought a license with the intent to use it on a G4 or G5 and you have no chance to run it on an Intel Mac then please contact us on mail@resolume.com.
Fixed Bugs
#540 [fixed] Record 0 bytes
#537 [fixed] Some audio files are distorted when playing backwards
#560 [fixed] Decks in wrong order
#566 [fixed] Crash when switching decks on heavy load
#551 [fixed] PC: Keystone and AddSubtract missing
#578 [fixed] HardLight mixer does not work
#543 [fixed] Wipe Down does not wipe all the way
#580 [fixed] OSX: Live input does not always work
#559 [fixed] Compositions list does not show the last item
#561 [fixed] Continue playback is not working with Audio clips
#557 [fixed] White txt on layer blend mode buttons
#562 [fixed] Audio Input channels are not saved correctly
#534 [fixed] BPM 120.50 not possible
#550 [fixed] Some Application Key Map "Deck" Keystrokes not working
#542 [fixed] Beatloopr doesn't work until switched to bpm or beats mode (aarrghh)
#545 [fixed] Speed of videoclip isn't saved
#581 [fixed] Can't change directory for ffgl & vst directories
giorgiomartini
Re: Resolume 3.0.1 Released
Post by giorgiomartini »
What ? you created a brand new program from scratch for mac and pc and now you say it doesnt work in power pc ?
uhm...
ok
I understand your disappointment if you use an old PowerPC Mac so please email us if you bought your license to be used on a G4 or G5.
mfo
Post by mfo »
On the download page still v3.0.0 is linked...
Refresh/Reload the download page if you still see the old 3.0.0 links.
rabosavj
Post by rabosavj »
bart wrote:Refresh/Reload the download page if you still see the old 3.0.0 links.
could you please recheck the web code?
Code: Select all
<h1>Download Resolume Avenue 3</h1>
		<ul>
							<li><h3><a href="download.php?file=Resolume_Avenue_3_0_0_Installer.exe">Resolume_Avenue_3_0_1_Installer.exe</a> (63 MB)</h3></li>
				<li style="color:#999">Windows XP & Vista</li>
				<li>&nbsp;</li>
				<li><h3><a href="download.php?file=Resolume_Avenue_3_0_0_Installer.dmg">Resolume_Avenue_3_0_1_Installer.dmg</a> (85 MB)</h3></li>
				<li style="color:#999">Mac OSX 10.4.11 or higher</li>
				<li>&nbsp;</li>
						<li>&#8226; <a href="http://www.resolume.com/forum/viewtopic.php?t=4582">Release notes</a> and comments on the forum.</li>
			<li>&#8226; No limitations, no time trial, watermarked output.</li>
			<li>&#8226; Includes demo footage.</li>
		</ul>
i think Resolume_Avenue_3_0_0_Installer.exe and Resolume_Avenue_3_0_0_Installer.dmg should be replace for Resolume_Avenue_3_0_1_Installer.exe and Resolume_Avenue_3_0_1_Installer.dmg
Aah yes sorry, now I see the problem, it was showing different links when visiting on a mac or a pc, fixed.
multisca
Re: Resolume 3.0.1 Released (issue 542)
Post by multisca »
When i change in R3.01 from BPM to beats, the number of beats is wrong : 8 or 12 (or not 16)
"auto" is wrong too.
Regards
:ugeek:
VJair
Post by VJair »
nicely done guys, cheers for the update :)
pfelberg
Post by pfelberg »
Bart, please.... do you guys have any expactations about when are you going to release the flash capable update?
We were told that it would be your top priority since 3.0.0 release.
thank you!
ps. good job fixing the minor bugs.
