Capture Card don't work on Avenue (Vista x64)
djdiego71
Post by djdiego71 »
Now, in my new system, i have three different capture cards (Pinnacle Studio 500-PCI, Osprey-100 PCI & Pinnacle MovieBox 510-USB).
No image in any of this sources, but works in other programs like Amcap or Studio 10.
Any suggestion?
Any capture card to recomend thats works fine on Vista x64 y Avenue? Not DV source needed because my cam haven't DV or Firewire output. Only composite video.
HerrNieDa
Re: Capture Card don't work on Avenue (Vista x64)
Post by HerrNieDa »
i have an internal and an external pinnacle video capture device...
they both work for me on win7
the only thing is i have to start pinnacle studio first, otherwise they won't work in resolume
seems i have to "acticate" it before starting resolume!
hope this works for you!
djdiego71
Post by djdiego71 »
Thanks. I buyed a cheap external usb capture dongle and works fine.
mandawah
Post by mandawah »
Hi DjDiego71,
Could you please tell me what exactly is the "cheap external usb capture dongle" that worked fine for you?
I am looking for exactly this, but reading the forum it seems that not all hardware on the market is working fine with Resolume.
djdiego71
Post by djdiego71 »
I'm from Argentina, and my cheap usb capture dongle is a Kworld DVD Maker USB 2.0
http://www.kworld-global.com/main/prod_ ... 104&flag=1
mandawah
Post by mandawah »
Thanks for the hint!
