Hi
Try this exercice: in a project in1024*768 make a square with solid color source. set the size to 15%
make a record. you should have a new clip with the same square. compare there. there are differents aspect ratio.
Does anybody can explain me why and how can i do to obtain the same square at the output ?
thank you.
decay between original and recorded file
Re: decay between original and recorded file
pixel aspect-> square
sorry could you explain i don't understand.
- Tschoepler
I can't recreate what you say. I make a comp @ 1024x768 then create a solid @ 1024x1024, scale it to 15% and record the output. The only difference are the blurred edges of the square. But that is due to the way DXV works I guess (no vector anymore). Is that what you meant?
I tried it, record a square and it comes out out fine. Could you post your wrong video file here?
Works fine for me, see the screenshot, but perhaps I'm not 100% sure what the problem is?
- Attachments
- Screen shot 2010-09-08 at 11.31.18 AM.png (281.83 KiB) Viewed 9547 times
- Tschoepler
This obviously is not a square. Make a screenshot of the clip's parameters. To me this looks as if you don't have the clip's width and height set to the same value: (1024*0,15)x(768*0,15)= 153,6x115,2 which is about the size of the red block in your sample.
