Clip Fade In/Fade out time
Agent Orange
Post by Agent Orange »
It could be interesting to have fade in/fade out parameters on a per clip/layer basis.
This could help to ease transitions between clips, especially ones that don't loop nicely, without the need for completely re-rendering source material.
HerrNieDa
Re: Clip Fade In/Fade out time
Post by HerrNieDa »
for clip fade in you can use the opacity parameter from the clip... set it to timeline play once ;)
also works on the layer....
fade out does not work in this case...
a triggerstyle option or a checkbox at the clip/layer would be nice for the next versions :roll:
Amid
Post by Amid »
when it will add to the program? :D
You know, there is a slider for that in each layer
transition time
transition time
transition time.jpg (35.72 KiB) Viewed 31390 times
go to view: show clip transition controls if you don't see it
Amid
Post by Amid »
oh sorry, I meant to say about the Fade in / Out on the clip. (Looping footage)
do you mean adjustable crossfade from end to start of a clip when looping?
that would be useful
+1
i do this function usig 2 instances of the same clip automated to play next and play previous to eachoter
edit:
i just noticed the original post was from 2011...
Amid
Post by Amid »
ravensc wrote:do you mean adjustable crossfade from end to start of a clip when looping?
+1
absolutely exactly )
Sadler
Post by Sadler »
I prefer to wrap clips on a beat in an editor. Frame accurate and no fuss later.
