Resolume hanging on startup
RPWILLIAM
Re: Resolume hanging on startup
Post by RPWILLIAM »
Update, it randomly launched up until the UI loading but then immediately crashed before loading anything else. Splash screen still visible. Here is the log from that particular attempt:
Code: Select all
Resolume Arena 7.22.2 42470 built 19 December 2024
Log started: 6 Jan 2025 8:39:29am
[2025-01-06T08:39:29.071Z]   INFO: Logging has started
[2025-01-06T08:39:29.073Z]   INFO: Ensuring Nvidia profile correctness
[2025-01-06T08:39:29.286Z]   INFO:     Failed adding application Resolume Arena/Arena.exe to custom nvidia profile, it's probably already present
[2025-01-06T08:39:29.286Z]   INFO: Nvidia profile setup finished successfully
[2025-01-06T08:39:29.306Z]   INFO: Initializing application. Command Line:
[2025-01-06T08:39:29.307Z]   INFO: Created TaskManager with 14 threads.
[2025-01-06T08:39:29.307Z]   INFO: Disable screen saver
[2025-01-06T08:39:29.334Z]   INFO: Initialise JuceResapiApp
[2025-01-06T08:39:29.334Z]   INFO: Initialise ResApi
[2025-01-06T08:39:29.335Z]   INFO: Initializing Resapi
[2025-01-06T08:39:29.335Z]   INFO:     Created ParamCollection
[2025-01-06T08:39:29.335Z]   INFO:     Created InputController
[2025-01-06T08:39:29.335Z]   INFO:     Created DeviceChangeDetector
[2025-01-06T08:39:29.336Z]   INFO:     Creating VideoFormatManager
[2025-01-06T08:39:29.336Z]   INFO:         Registering basic formats
[2025-01-06T08:39:29.336Z]   INFO:         Registered 4 formats
[2025-01-06T08:39:29.336Z]   INFO:     Created VideoFormatManager
[2025-01-06T08:39:29.337Z]   INFO:     Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
[2025-01-06T08:39:29.342Z]   INFO:     Creating DisplayCollection
[2025-01-06T08:39:29.343Z]   INFO:     Created DisplayCollection
[2025-01-06T08:39:29.343Z]   INFO: Successfully setup Resapi.
[2025-01-06T08:39:29.343Z]   INFO: Initializing Resapi graphics
[2025-01-06T08:39:29.343Z]   INFO:     First time OpenGL usage, initializing extensions.
[2025-01-06T08:39:29.344Z]   INFO:     Registering window class.
[2025-01-06T08:39:29.344Z]   INFO:     Successfully registered window class.
[2025-01-06T08:39:29.756Z]   INFO:     Successfully initialized extensions.
[2025-01-06T08:39:29.757Z]   INFO:     This system supports OpenGL version: 4.1.0 NVIDIA 566.36
[2025-01-06T08:39:29.760Z]   INFO:     ---Info main OpenGL renderer---
[2025-01-06T08:39:29.760Z]   INFO:     Driver Vendor : NVIDIA Corporation
[2025-01-06T08:39:29.760Z]   INFO:     Renderer Name: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2
[2025-01-06T08:39:29.760Z]   INFO:     Driver Version: 4.1.0 NVIDIA 566.36
[2025-01-06T08:39:29.760Z]   INFO:     OpenGL shader language version: 4.10 NVIDIA via Cg compiler
[2025-01-06T08:39:29.760Z]   INFO:     Maximum Supported OpenGL version: 4.1
[2025-01-06T08:39:29.760Z]   INFO:     -------------------------------
[2025-01-06T08:39:29.760Z]   INFO:     Initializing renderer.
[2025-01-06T08:39:29.761Z]   INFO:         Initializing TextureManager.
[2025-01-06T08:39:29.769Z]   INFO:         Successfully initialized texture manager.
[2025-01-06T08:39:29.769Z]   INFO:         Loading shaders...
[2025-01-06T08:39:29.792Z]   INFO:         Successfully loaded shaders.
[2025-01-06T08:39:29.816Z]   INFO:     Successfully initialized renderer.
[2025-01-06T08:39:29.828Z]   INFO:     Successfully initialized extensions.
[2025-01-06T08:39:29.828Z]   INFO:     This system supports OpenGL version: 4.1.0 NVIDIA 566.36
[2025-01-06T08:39:29.828Z]   INFO:     Initializing renderer.
[2025-01-06T08:39:29.828Z]   INFO:         Initializing TextureManager.
[2025-01-06T08:39:29.829Z]   INFO:         Successfully initialized texture manager.
[2025-01-06T08:39:29.829Z]   INFO:         Loading shaders...
[2025-01-06T08:39:29.832Z]   INFO:         Successfully loaded shaders.
[2025-01-06T08:39:29.842Z]   INFO:     Successfully initialized renderer.
[2025-01-06T08:39:29.856Z]   INFO:     Successfully initialized extensions.
[2025-01-06T08:39:29.857Z]   INFO:     This system supports OpenGL version: 4.1.0 NVIDIA 566.36
[2025-01-06T08:39:29.857Z]   INFO:     Initializing renderer.
[2025-01-06T08:39:29.857Z]   INFO:         Initializing TextureManager.
[2025-01-06T08:39:29.857Z]   INFO:         Successfully initialized texture manager.
[2025-01-06T08:39:29.857Z]   INFO:         Loading shaders...
[2025-01-06T08:39:29.860Z]   INFO:         Successfully loaded shaders.
[2025-01-06T08:39:29.871Z]   INFO:     Successfully initialized renderer.
[2025-01-06T08:39:29.871Z]   INFO:     Initializing GPUMonitor
[2025-01-06T08:39:29.871Z]   INFO:     Successfully initialized GPUMonitor, using NVX strategy.
[2025-01-06T08:39:29.872Z]   INFO:     Determining AutoDetect setting
[2025-01-06T08:39:29.872Z]   INFO:     Autodetected inline transfers, ati drivers often bug out and crash the app.
[2025-01-06T08:39:29.872Z]   INFO:     Initializing TextureUploader
[2025-01-06T08:39:29.872Z]   INFO:     Successfully initialized TextureUploader
[2025-01-06T08:39:29.874Z]   INFO: Successfully initialized Resapi graphics.
[2025-01-06T08:39:29.874Z]   INFO: Install default PathParser
[2025-01-06T08:39:29.874Z]   INFO: Enumerate fonts
[2025-01-06T08:39:30.000Z]   INFO: Find default fonts
[2025-01-06T08:39:30.001Z]   INFO: Create Application Object
[2025-01-06T08:39:30.002Z]   INFO: Setting up default composition settings.
[2025-01-06T08:39:30.003Z]   INFO: Resapi: setCurrentApplication
[2025-01-06T08:39:30.003Z]   INFO: Print version info
[2025-01-06T08:39:30.003Z]   INFO: Major Version: 7
[2025-01-06T08:39:30.003Z]   INFO: Minor Version: 22
[2025-01-06T08:39:30.003Z]   INFO: Micro Version: 2
[2025-01-06T08:39:30.004Z]   INFO: Revision: 42470
[2025-01-06T08:39:30.004Z]   INFO: Revision string: rev42470
[2025-01-06T08:39:30.004Z]   INFO: Version string with revision: 7.22.2 42470
[2025-01-06T08:39:30.004Z]   INFO: Version string without revision: 7.22.2
[2025-01-06T08:39:30.004Z]   INFO: Print application paths
[2025-01-06T08:39:30.004Z]   INFO: Executable Path: C:\Program Files\Resolume Arena
[2025-01-06T08:39:30.004Z]   INFO: User Documents Path: C:\Users\#####\Documents\Resolume Arena
[2025-01-06T08:39:30.004Z]   INFO: Default Data Path: C:\Program Files\Resolume Arena\default
[2025-01-06T08:39:30.004Z]   INFO: Common Data Path: C:\ProgramData\Resolume Arena
[2025-01-06T08:39:30.005Z]   INFO: Preferences Path: C:\Users\#####\Documents\Resolume Arena\Preferences
[2025-01-06T08:39:30.005Z]   INFO: Media Path: C:\Program Files\Resolume Arena\media
[2025-01-06T08:39:30.005Z]   INFO: Compositions Path: C:\Users\#####\Documents\Resolume Arena\Compositions
[2025-01-06T08:39:30.005Z]   INFO: Default Presets Path:
[2025-01-06T08:39:30.006Z]   INFO: User Presets Path: C:\Users\#####\Documents\Resolume Arena\Presets
[2025-01-06T08:39:30.006Z]   INFO: Video Effects Presets Path: C:\Users\#####\Documents\Resolume Arena\Presets\Video Effects
[2025-01-06T08:39:30.006Z]   INFO: Audio Effects Presets Path: C:\Users\#####\Documents\Resolume Arena\Presets\Audio Effects
[2025-01-06T08:39:30.006Z]   INFO: Video Sources Presets Path: C:\Users\#####\Documents\Resolume Arena\Presets\Sources
[2025-01-06T08:39:30.006Z]   INFO: Video Mixers Presets Path: C:\Users\#####\Documents\Resolume Arena\Presets\Mixers
[2025-01-06T08:39:30.007Z]   INFO: Audio Plugins Path: C:\Program Files\Resolume Arena\plugins\afx
[2025-01-06T08:39:30.007Z]   INFO: Video Plugins Path:
[2025-01-06T08:39:30.007Z]   INFO: Previews Path: C:\Users\#####\AppData\Local\Resolume Arena\previews
[2025-01-06T08:39:30.007Z]   INFO: Print system info
[2025-01-06T08:39:30.007Z]   INFO: Operating system: Windows 10
[2025-01-06T08:39:30.008Z]   INFO: VersionInfo (unreliable): 10.0.17763
[2025-01-06T08:39:30.008Z]   INFO: OS 64 bit: Yes
[2025-01-06T08:39:30.008Z]   INFO: CPU vendor: GenuineIntel
[2025-01-06T08:39:30.088Z]   INFO: CPU speed: 2866MHz
[2025-01-06T08:39:30.088Z]   INFO: Number of CPUs: 16
[2025-01-06T08:39:30.088Z]   INFO: Memory size: 16285MB
[2025-01-06T08:39:30.088Z]   INFO: System language is: en
[2025-01-06T08:39:30.089Z]   INFO: Locate preferences directory
[2025-01-06T08:39:30.090Z]   INFO: Locate settings file
[2025-01-06T08:39:30.090Z]   INFO: Copy Default Effect, Source, Envelope, Color Palette, Layout, Advanced Screensetup Presets if needed
[2025-01-06T08:39:30.130Z]   INFO: No Default Presets copied!
[2025-01-06T08:39:30.130Z]   INFO: Copy Default Shortcut Presets
[2025-01-06T08:39:30.131Z]   INFO: No Default Shortcuts found!
[2025-01-06T08:39:30.131Z]   INFO: Copying Default fixtures
[2025-01-06T08:39:30.132Z]   INFO: No Default Fixtures found!
[2025-01-06T08:39:30.132Z]   INFO: Load Application settings
[2025-01-06T08:39:30.133Z]   INFO: Install languages
[2025-01-06T08:39:30.143Z]   INFO: Get Typeface specified by language and set for LookAndFeel
[2025-01-06T08:39:30.144Z]   INFO: NotoSansRegular_ttf resource size in bytes : 313144
[2025-01-06T08:39:30.144Z]   INFO: NotoSansBold_ttf resource size in bytes : 313792
[2025-01-06T08:39:30.144Z]   INFO: NotoMonoRegular_ttf resource size in bytes : 107848
[2025-01-06T08:39:30.146Z]   INFO: createSystemTypefaceFor for typeFaceData.regular succesful : Noto Sans Regular
[2025-01-06T08:39:30.147Z]   INFO: createSystemTypefaceFor for typeFaceData.bold succesful : Noto Sans Bold
[2025-01-06T08:39:30.147Z]   INFO: createSystemTypefaceFor for typeFaceData.mono succesful : Noto Mono
[2025-01-06T08:39:30.148Z]   INFO: Init Colour scheme for user interface
[2025-01-06T08:39:30.148Z]   INFO: Create LookAndFeel
[2025-01-06T08:39:30.149Z]   INFO: Set LookAndFeel
[2025-01-06T08:39:30.158Z]   INFO: Create InputReceiver
[2025-01-06T08:39:30.178Z]   INFO: Create ApplicationController
[2025-01-06T08:39:30.181Z]   INFO: Creating NDIVideoServerManager
[2025-01-06T08:39:30.181Z]   INFO:     Initializing NDI library
[2025-01-06T08:39:30.952Z]   INFO:     Successfully initialized NDI library
[2025-01-06T08:39:30.956Z]   INFO: Created NDIVideoServerManager
[2025-01-06T08:39:30.961Z]   INFO: Load HelpController file
[2025-01-06T08:39:30.973Z]   INFO: Create AudioEngine
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Bitcrusher.dll
Creating VST instance: Bitcrusher
Initialising VST: Bitcrusher (1.0.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Distortion.dll
Creating VST instance: Distortion
Initialising VST: Distortion (1.0.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\EQ-3.dll
Creating VST instance: EQ-3
Initialising VST: EQ-3 (1.0.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Flanger.dll
Creating VST instance: Flanger
Initialising VST: Flanger (1.1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\HighPass.dll
Creating VST instance: HighPass
Initialising VST: HighPass (1.0.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\LowPass.dll
Creating VST instance: LowPass
Initialising VST: LowPass (1.0.0.0)
[2025-01-06T08:39:31.363Z]   INFO: Install Audio Effect Preset preprocessor
[2025-01-06T08:39:31.364Z]   INFO: Update Composition List
[2025-01-06T08:39:31.364Z]   INFO: Enumerating Compositions took: 0.00008 seconds
[2025-01-06T08:39:31.364Z]   INFO: Initializing OSC
[2025-01-06T08:39:31.390Z]   INFO: Create MidiController
[2025-01-06T08:39:31.390Z]   INFO: Wire documents patches not found in location: C:\Users\#####\Documents\Resolume Wire\Patches
[2025-01-06T08:39:31.390Z]   INFO: User compiled patches not found in location: C:\Users\Public\Documents\Resolume Wire\Patches
[2025-01-06T08:39:31.527Z]   INFO: Libwire API version: 8
[2025-01-06T08:39:31.528Z]   INFO: Expected API version: 8
[2025-01-06T08:39:31.833Z]   INFO: Install Video Source Preset preprocessor
[2025-01-06T08:39:31.833Z]   INFO: Install Video Effect Preset preprocessor
[2025-01-06T08:39:31.833Z]   INFO: Install Animation Preset preprocessor
[2025-01-06T08:39:31.833Z]   INFO: Loading Animation presets
[2025-01-06T08:39:31.942Z]   INFO: Loading Render and Recording presets
[2025-01-06T08:39:31.943Z]   INFO: Loading Render presets
[2025-01-06T08:39:32.013Z]   INFO: Load AudioEngine settings and initialise audio engine
[2025-01-06T08:39:32.014Z]   INFO: No Audio Sevice Dettings found, openening default audio setup.
[2025-01-06T08:39:32.370Z]   INFO: Changing audio setup to:
[2025-01-06T08:39:32.370Z]   INFO:  Device Type:     Windows Audio
[2025-01-06T08:39:32.371Z]   INFO:  Output Device:   XB273 P (NVIDIA High Definition Audio)
[2025-01-06T08:39:32.371Z]   INFO:  Input  Device:   None
[2025-01-06T08:39:32.371Z]   INFO:  Samplerate:      48000
[2025-01-06T08:39:32.371Z]   INFO:  BlockSize:       480
[2025-01-06T08:39:32.371Z]   INFO:  Output Channels: 11
[2025-01-06T08:39:32.372Z]   INFO: Load SMPTE settings
[2025-01-06T08:39:32.372Z]   INFO: Load TCNet network settings
[2025-01-06T08:39:32.382Z]   INFO: Setup Generator presets directory
[2025-01-06T08:39:32.382Z]   INFO: Setup Effect presets directory
[2025-01-06T08:39:32.382Z]   INFO: Setup Mixer presets directory
[2025-01-06T08:39:32.393Z]   INFO: Enabling NDI support
[2025-01-06T08:39:32.393Z]   INFO: Setup Source presets directory
[2025-01-06T08:39:32.393Z]   INFO: Creating VideoSourceManager
[2025-01-06T08:39:32.394Z]   INFO: Created VideoSourceManager
[2025-01-06T08:39:32.394Z]   INFO: Register internal renderpasses
[2025-01-06T08:39:33.366Z]   INFO: Register application specific renderpasses and sources
[2025-01-06T08:39:33.367Z]   INFO: Get Primary Context
[2025-01-06T08:39:33.367Z]   INFO: ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Users\#####\Documents\Resolume Arena\Extra Effects'
[2025-01-06T08:39:33.367Z]   INFO: Done scanning directory, loaded 0 plugin(s) from it.
[2025-01-06T08:39:33.377Z]   INFO: Create VideoEngine
[2025-01-06T08:39:33.398Z]   INFO: Pass Application name to spout
[2025-01-06T08:39:33.409Z]   INFO: Set thumbnail for capture device sources
[2025-01-06T08:39:33.430Z]   INFO: Initialize video engine
[2025-01-06T08:39:33.441Z]   INFO: Init Wire Runtime
[2025-01-06T08:39:33.856Z]   INFO: Create ShortcutPresetManager
[2025-01-06T08:39:33.856Z]   INFO: Install Shortcut Preset preprocessor
[2025-01-06T08:39:33.917Z]   INFO: Create param view factory
[2025-01-06T08:39:33.936Z]   INFO: Create ScreenSetupDriver
[2025-01-06T08:39:33.936Z]   INFO: Create DmxController And Load Settings
[2025-01-06T08:39:33.942Z]   INFO: Initializing ArtNet on adapter ethernet_32772.
[2025-01-06T08:39:33.943Z]   INFO: ArtNet initialization succeeded.
[2025-01-06T08:39:33.943Z]   INFO: Load Fixture Presets
[2025-01-06T08:39:33.948Z]   INFO: Create ScreenSetupDriver
[2025-01-06T08:39:33.951Z]   INFO: Install Screen Setup Preset preprocessor
[2025-01-06T08:39:33.951Z]   INFO: Set ScreenSetup Presets Directory: C:\Users\#####\Documents\Resolume Arena\Presets\Advanced Output
[2025-01-06T08:39:33.951Z]   INFO: Load ScreenSetup Presets
[2025-01-06T08:39:33.954Z]   INFO: Create AdvancedScreenSetupWindow
[2025-01-06T08:39:33.970Z]   INFO: Set ScreenSetup Advanced Preferences file: C:\Users\#####\Documents\Resolume Arena\Preferences\AdvancedOutput.xml
[2025-01-06T08:39:33.970Z]   INFO: Enumerate displays and position MainWindow on primary device
[2025-01-06T08:39:33.971Z]   INFO: Init Screen Setup
[2025-01-06T08:39:33.972Z]   INFO: Load Last Screen Setup
[2025-01-06T08:39:33.982Z]   INFO: Create Composition
[2025-01-06T08:39:34.019Z]   INFO: Init TextureDatabase
[2025-01-06T08:39:34.019Z]   INFO: Register Composition as ExternalTextureProvider to the ScreenSetup
[2025-01-06T08:39:34.019Z]   INFO: Register Composition with controllers
[2025-01-06T08:39:34.029Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\WarpSpeed.wired
[2025-01-06T08:39:34.039Z]   INFO: Wire patch is registered as Effect WarpSpeed
[2025-01-06T08:39:34.040Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Tunnelines.wired
[2025-01-06T08:39:34.054Z]   INFO: Wire patch is registered as Source Tunnelines
[2025-01-06T08:39:34.094Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Tilt Shift.wired
[2025-01-06T08:39:34.101Z]   INFO: Wire patch is registered as Effect Tilt Shift
[2025-01-06T08:39:34.102Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Strokes.wired
[2025-01-06T08:39:34.202Z]   INFO: Wire patch is registered as Effect Strokes
[2025-01-06T08:39:34.204Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Slice Outline.wired
[2025-01-06T08:39:34.212Z]   INFO: Wire patch is registered as Source Slice Outline
[2025-01-06T08:39:34.213Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Slice Delay.wired
[2025-01-06T08:39:34.231Z]   INFO: Wire patch is registered as Effect Slice Delay
[2025-01-06T08:39:34.232Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Shape Mask.wired
[2025-01-06T08:39:34.240Z]   INFO: Wire patch is registered as Effect Shape Mask
[2025-01-06T08:39:34.241Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\SearchLight.wired
[2025-01-06T08:39:34.252Z]   INFO: Wire patch is registered as Effect SearchLight
[2025-01-06T08:39:34.253Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\PiP.wired
[2025-01-06T08:39:34.262Z]   INFO: Wire patch is registered as Mixer PiP
[2025-01-06T08:39:34.263Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\LUT.wired
[2025-01-06T08:39:34.269Z]   INFO: Wire patch is registered as Effect LUT
[2025-01-06T08:39:34.270Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Grid Cloner.wired
[2025-01-06T08:39:34.282Z]   INFO: Wire patch is registered as Effect Grid Cloner
[2025-01-06T08:39:34.283Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Bumper.wired
[2025-01-06T08:39:34.292Z]   INFO: Wire patch is registered as Mixer Video Bumper
[2025-01-06T08:39:34.293Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Acuarela.wired
[2025-01-06T08:39:34.301Z]   INFO: Wire patch is registered as Effect Acuarela
[2025-01-06T08:39:34.302Z]   INFO: Register Wire Patch C:\Program Files\Resolume Arena\plugins\wire\Abstract Field.wired
[2025-01-06T08:39:34.314Z]   INFO: Wire patch is registered as Source Abstract Field
[2025-01-06T08:39:34.369Z]   INFO: Load audio effect presets
[2025-01-06T08:39:34.369Z]   INFO: Load Application Settings
[2025-01-06T08:39:34.369Z]   INFO: Load Composition List settings
[2025-01-06T08:39:34.369Z]   INFO: Load Extension List settings
[2025-01-06T08:39:34.370Z]   INFO: Load Extensions Manager settings
[2025-01-06T08:39:34.370Z]   INFO: Load Mixers Manager settings
[2025-01-06T08:39:34.370Z]   INFO: Load Recording Queue Manager settings
[2025-01-06T08:39:34.380Z]   INFO: Create Layer Properties Panel
[2025-01-06T08:39:34.381Z]   INFO: Create Clip Properties Panel
[2025-01-06T08:39:34.381Z]   INFO: Create Column Properties Panel
[2025-01-06T08:39:34.381Z]   INFO: Create Composition Properties Panel
[2025-01-06T08:39:34.382Z]   INFO: Create Toolbar Panel
[2025-01-06T08:39:34.383Z]   INFO: Create Shortcuts Panel
[2025-01-06T08:39:34.386Z]   INFO: Create File Browser Panel
[2025-01-06T08:39:34.391Z]   INFO: Create Compositions Panel
[2025-01-06T08:39:34.391Z]   INFO: Create Effects Panel
[2025-01-06T08:39:34.392Z]   INFO: Create Sources Panel
[2025-01-06T08:39:34.392Z]   INFO: Create Help Panel
[2025-01-06T08:39:34.392Z]   INFO: Create Clip Time Panel
[2025-01-06T08:39:34.393Z]   INFO: Create Layer Group Panel
[2025-01-06T08:39:34.393Z]   INFO: Create Slices Panel
[2025-01-06T08:39:34.393Z]   INFO: Create SMPTE Panel
[2025-01-06T08:39:34.394Z]   INFO: Create Render Queue Panel
[2025-01-06T08:39:34.394Z]   INFO: Create Notes Panel
[2025-01-06T08:39:34.394Z]   INFO: Create Recording Panel
[2025-01-06T08:39:34.396Z]   INFO: Create UI manager
[2025-01-06T08:39:34.397Z]   INFO: Install Layout Preset preprocessor
[2025-01-06T08:39:34.397Z]   INFO: Set sparkle update accepted callback
[2025-01-06T08:39:34.397Z]   INFO: Attach Extension List inspectors
[2025-01-06T08:39:34.408Z]   INFO: Attach screen setup inspector
[2025-01-06T08:39:34.408Z]   INFO: Attach SMPTE Panel inspector
[2025-01-06T08:39:34.408Z]   INFO: Attach Undo Stack inspector
[2025-01-06T08:39:34.408Z]   INFO: Attach Render Queue inspector
[2025-01-06T08:39:34.408Z]   INFO: Attach Recording inspector
[2025-01-06T08:39:34.409Z]   INFO: Attach Clip Time Panel inspector
[2025-01-06T08:39:34.409Z]   INFO: Attach Notes Panel inspector
[2025-01-06T08:39:34.409Z]   INFO: Load auto-saved layout
[2025-01-06T08:39:34.417Z]   INFO: Attach StatusBar inspector to MainWindow
[2025-01-06T08:39:34.523Z]   INFO: Initializing OpenGLComponent
[2025-01-06T08:39:34.541Z]   INFO:     OpenGLCanvas: New context is created
[2025-01-06T08:39:34.542Z]   INFO:     Initializing renderer.
[2025-01-06T08:39:34.542Z]   INFO:         Initializing TextureManager.
[2025-01-06T08:39:34.542Z]   INFO:         Successfully initialized texture manager.
[2025-01-06T08:39:34.542Z]   INFO:         Loading shaders...
[2025-01-06T08:39:34.545Z]   INFO:         Successfully loaded shaders.
[2025-01-06T08:39:34.553Z]   INFO:     Successfully initialized renderer.
[2025-01-06T08:39:34.554Z]   INFO: OpenGLComponent initialized successfully.
[2025-01-06T08:39:34.555Z]   INFO: Initializing OpenGLComponent
[2025-01-06T08:39:34.571Z]   INFO:     OpenGLCanvas: New context is created
[2025-01-06T08:39:34.572Z]   INFO:     Initializing renderer.
[2025-01-06T08:39:34.572Z]   INFO:         Initializing TextureManager.
[2025-01-06T08:39:34.572Z]   INFO:         Successfully initialized texture manager.
[2025-01-06T08:39:34.572Z]   INFO:         Loading shaders...
[2025-01-06T08:39:34.575Z]   INFO:         Successfully loaded shaders.
[2025-01-06T08:39:34.584Z]   INFO:     Successfully initialized renderer.
[2025-01-06T08:39:34.585Z]   INFO: OpenGLComponent initialized successfully.
[2025-01-06T08:39:34.598Z]   INFO: Refresh MidiController
[2025-01-06T08:39:34.599Z]   INFO: Load MidiController settings
[2025-01-06T08:39:34.599Z]   INFO: Start MidiController
[2025-01-06T08:39:34.608Z]   INFO: Load Compositon Server settings
[2025-01-06T08:39:34.627Z]   INFO: Create renderer
[2025-01-06T08:39:34.628Z]   INFO: Start renderer
[2025-01-06T08:39:34.777Z]   INFO: Application successfully initialized
[2025-01-06T08:39:34.797Z]   INFO: Main::CompositionLoader::loadStartupComposition: Loading startup composition
[2025-01-06T08:39:34.798Z]   INFO:     No composition was loaded from the command line, opening last opened: "C:\Program Files\Resolume Arena\default\Example.avc"
[2025-01-06T08:39:35.599Z]   INFO:     resolume::CompositionManager::loadComposition: Loading composition from content. File: "C:\Program Files\Resolume Arena\default\Example.avc"
[2025-01-06T08:39:35.602Z]   INFO:         Reading composition xml data
[2025-01-06T08:39:35.602Z]   INFO:             Forking composition reading
[2025-01-06T08:39:35.676Z]   INFO:             Composition clearing is done
[2025-01-06T08:39:35.677Z]   INFO:             Done reading params, reading shortcut presets next
[2025-01-06T08:39:35.698Z]   INFO:             Done reading sync data, cleaning up
[2025-01-06T08:39:35.719Z]   INFO:         Successfully read composition xml
[2025-01-06T08:39:35.719Z]   INFO:         Reading composition state took: 0.11685 seconds
[2025-01-06T08:39:35.719Z]   INFO:         Setting composition high quality to: false
RPWILLIAM
Post by RPWILLIAM »
So I ran analysis on windows processes as resolume starts up and could see there were several threads stuck on waiting. I sent the dump file into chatGPT to make sense of it and it gave me this:
Code: Select all
đź›  Resolume Arena Crash/Hang Analysis Summary
Based on the dump analysis, the hang seems to originate from the NVIDIA OpenGL Driver (nvoglv64.dll). This driver is involved in handling OpenGL rendering tasks, and the hang is happening during a GPU-related operation, likely involving window or buffer initialization.
đź§  Key Findings:
Faulting Module:
nvoglv64.dll (NVIDIA OpenGL driver)
Exception Code:
0x80000003 (Breakpoint Exception)
This indicates the application hit an intentional breakpoint, often used for debugging or when the driver encounters an unrecoverable state.
Thread Activity:
Main Thread: Stuck in a wait state inside nvoglv64.dll during an OpenGL operation.
ResAPI Task Threads (Multiple Threads): Many threads are sleeping or waiting for synchronization objects, suggesting a potential deadlock.
Suspicious Stack Calls:
nvoglv64!DrvValidateVersion
nvoglv64!DrvPresentBuffers
nvoglv64!DrvValidateVersion+0xcf7a
These suggest that the hang occurs during buffer presentation or version validation of the driver.
RPWILLIAM
Post by RPWILLIAM »
Update,
I've now reinstalled the system and fully updated Windows. Ensured latest Nvidia and Intel drivers are updated.
I've installed the latest version of Resolume.
I've adjusted these settings in the nvidia control panel:
OpenGL GDI Compatibility: Prefer Compatible
OpenGL Rendering GPU: NVIDIA Geforce RTX 2080 SUPER
Power management mode: Prefer maximum performance
Threaded Optimisation: On
Veritcal Sync: On
This is the most stable I've managed to get it, with probably a 50% success rate of Resolume opening successfully. The failed launches hang at the first initialiation, the wire runtime or when the UI boots up prior to loading a composition. There doesn't appear to be any pattern to how far it gets.
The logs are too big to post in here but I have them saved down.
edit: I've noticed on the times that it does launch successfully, it crashes a few minutes later..
Sounds like a driver issue.
Try an older nvidia Studio driver, from mid 2024.
EBMCreative
Post by EBMCreative »
RPWILLIAM wrote: Tue Jan 07, 2025 15:30 Update,
Veritcal Sync: On
I can't remember and I'm not in front of the computer at the moment to check..... But I remember having an issue with vertical sync. I think it was when it was on that caused my system to have problems.
Edit. Yes my vertical sync is off.
RPWILLIAM
Post by RPWILLIAM »
I've isolated the issue to the 'nlddmkm' file on the Nvidia driver.
This crash has happened repeatedly on two servers now.
When I update the systems to the latest nvidia drivers, resolume hangs and won't start.
When I update the systems to an old driver 531.68 (april 2023) resolume works but we get intermittent crashing. Windows system logs point to that file on each occasion.
Do you see consistent memory or VRAM usage increase?
Might be a hardware issue also if multiple driver versions crash.
Try enabling debug mode in the nvidia control panel, that should disable all overclocking and set drivers back to base performance.
Képernyőfotó 2025-04-25 - 9.03.41.png (17.73 KiB) Viewed 12181 times
