A couple of things about audio analysis and linking to effects parameters:
It would be great if parameters could be inversly linked to frequency bands as well as positively linked.
It would be great if each parameter could have min/max settings (implemented like the inpoint/outpoint markers) to constrain the settings they take from audio (or the range they loop/bounce between)
Dan.
resolume 2.0: let us know what you think
lucidhouse_
noce_
a good thing is about the fact that v 2 will not need new harware. i hope it will be really like that. so the speed and efficiency, stability of the software is the most important thing.
what about if i do not have a 16/9 screen? i won't be able to see the 3 windows on left...right?
about layout colors: i like grey and pink (pink a bit less, maybe could be nice to can change it in orange, red, or other brilliant colors..)
respect
noce
i like vdmx layout: http://www.vidvox.net/products/vdmx/img/traditional.jpg
respect
noce
bl0m5t3r_
what i was really hoping for was a beat counter with a tap button (and a key mapping for easy tapping), to sync to the music (so you can manually set it) and be able to drive playspeed between looppoint or a whole movie and also be able to drive the parameters for effects with it aswell as transparency levels for the 3 channels.
beat sync is the only thing i've been missing so far with resolume. but i don't think the audio interpetation as i can see it in the sneak preview is gonna cut it for me (i like to tap).
thanx anyhow for this great program! it's da bomb
Kusmus_
Does the audio response can control the speed of a clip ?
Link to the loop control, a high frequence like a roll of snare can increase the speed of the assigned clip.
Or as an other example, On a 4x4 kick pattern.. the clip when it reach the max play at a normal speed... and decelarate until it reach the min... is it possible?
Exeris_
nfms_
lucidhouse_
