resolume 2.0: let us know what you think
lucidhouse_
Post by lucidhouse_ »
sorry!
i think there is a misunderstanding here ... there will be one effect per channel (like now) and 3 global effect slots (where there is only one now)
lucidhouse_
hi Bart,
maybe a terminoligy misunderstanding..
theres one effect per clip now (could be described as a channel) and one global effect.
what some where proposing was one effect per layer as in the 3 clip layers or channels instead of the 3 global effect.
anyways, whatever you guys do for now will no doubt great, we trust you.
a_
Post by a_ »
fps for each layer.. so i can see, whats the real speed of a played clip... anyway, nice work at all.
Diego_
Post by Diego_ »
please, sequence setup for chaos or let us choose random chaos or sequential chaos or something similar. If programable sequence will be best.
Let us choose the overlay effect for individual channels. Some clips need a particualar overlay instead the overlay layer.
docmotion_
Post by docmotion_ »
can i use resolume 2.0 of a ibm laptop
r-serie centrino 1.4....
docmotion_
sorry for the 2 topics, i have a problem
with my browser
stark (ST-V)_
Post by stark (ST-V)_ »
i find the colors nice, and am behind noce's proposal of the posibility to change the default colors to go with the vjs wristbands and t-shirts for the show ;)
great work guys...
levon_
Post by levon_ »
it would be great if there could be a tap tempo function, like you would have to set up each clip before hand, set teh beat points of teh video clip, but then once thats all done it would sync the beats of the clips to the tap tempo
thanks for all the great work on this fine piece of software, i will surely purchase resolume 2 when it comes out (no money at this point in time, though will be saving up to buy it)
levon (aka VJ headless chicken)_
Post by levon (aka VJ headless chicken)_ »
oh though of another thing, rather then needing to set up the effects tabs/ groups inside resolume, if you could have them set up into directories. i think that it would help in the management of the pysical files and when trying new plugins you can just create a new foldier and have it all set up in resolume, rather then needing to look through and find new ones (paticualy a problem if you dont know the names of the plugins :P)
and also what some people have been saying about using midi files to control it, and recording from resolume into a midi file, i think is another great idea, it would help new people to resolume, if you make some amazing visuals, you can watch them back to yourself later :)
