The feedback is overwhelming us a bit so sorry for not being able to reply to all of you. SUPER THANX! for all your feedback&bugs ... we are taking notes and working on bugfixes allready. This thread is our todo list so please do keep reporting all bugs!
We hope to release a new version in a couple of weeks when enough bugs are fixed.
THANX! ;-D
resolume 2.0 beta: post your bugs here
mortischa_
bowser_
bowser_
kloo_
Furionic_
Reolume doesn´t show me all my files into the file browser.
I couldn´t figure out, in wich way they are sorted. Some files are listed some are not. They are all encoded the same way...but when i go down in my folder structure there are only a few folder where the files are listed.
But when i load some of my old 1.51 decks, resolume loads these files and even play them.
DinkyToys_
metaprofessor_
i just bought an upgrade license, and now i'm testing 2.0 some more:
interestingly, before i bought the license, when i would click on one of the the layer effects that has a menu i could only see "timeswitcher" but had no idea that there was another "lumakey" and one called "mixer".
also, that particular menu looks different than the other layer effect menus. the font is bold and slightly bigger.
at this moment, when i right click on the "push down" layer effect, it doesn't display the drop-down menu with the other options.
metaprofessor_
when i right-click on "record" the record button gets really big (including the font), and the window that opens isn't big enough to show all of the options (i can't see the option to select the record folder).
furthermore, after closing that menu, when i go to right-click on any one of the channels, the record options menu appears again without warning.
this is what has just happened when i took that screenshot. i'm going to post this in the bugs section as well.
- Attachments
- p_48937_1.jpg (41.88 KiB) Viewed 8919 times
metaprofessor_
