[fixed] resolume 2.0 slower
levon
Post by levon »
i was just screwing around with resolume 2.0 final, and i noticed that freeframe effects run alot slower then 1.51.
i was using the glow effect in R1.51, i set the res to 16bit, 640x480 and it runs at a decent rate. but in R2 with the screen res at 16bit process and display at 640x480 and the glow effect on its bloody slow, maybe 6 or 7 frames a second.
i was using flash files that are only 20-100k big.
[Edited on 11-1-2005 by bart]
edwin
Post by edwin »
hi levon,
does this occur with all freeframe effects or only with the glow effect.
maybe it's an error in the glow effect, because we did a lot of speed improvements on the freeframe system. So it should run faster than ever.
cheers
edwin
yes i,ve tested and the glow-in-the-dark effect is not running correctly in 16 bit. we,ll have this fixed for the next release.
all other plugins run fine though ...
levon
Post by levon »
THANKYOU :D
any idea when it will be out??? :D
[Edited on 12-1-2005 by levon]
