I have a PC laptop which has 1 HDMI output (no other video out socket).
If i upgrade to Arena i know i will want to be able to experiment with multiple projections/displays.
It looks like the best way to do that is with a Matrox Triplehead 2Go.
However, they don't do one which has HDMI connection.
On the Matrox website it looks like they're saying for HDMI you should use the Digital version and use an adapter to convert the HDMI to DVI.
The outputs on the Matrox are also DVI so i imagine i'd also need to convert to HDMI or VGA to take the signal from the Matrox to the projectors?
Is the Matrox Triplehead 2Go the best option to use for an HDMI signal or is there something else more suitable?
Thanks for your advice!
Suzybee
