Have a MacBook Pro (2016) and trying to feed my Datapath FX4 4K (3840x2160) and out to 4 x 1920x1080 LCD in a 2x2 config.. the output side is fine but I cant for the life of me get the FX4 to show as allowing 4k input.. I can feed a 4k screen direct its fine.. is it an EDID issue? I have switchres but before I go crazy with that I am not sure as the setting for the custom resolution I would make with it and dont want to blow anything up
Any tips would be great..
Thanks!!
Scott.
