Timecode Questions
NKNick
Timecode Questions
Post by NKNick »
Hi There,
I Trigger my Clips with Timecode that works fine.
But when the Clips ends it always fades to black. Is there a Option where I can define a clip to stay in the last Frame from the clip?
Re: Timecode Questions
Holding the last frame of a clip is only available for Timeline and BPM synced clips.
https://resolume.com/support/en/video#playback-options
The Frame displayed by the clip is defined by the SMPTE TC, so theoretically stopping the TC at the last frame's position would leave the clip frame displayed. But that's not something I'd recommend to do ;)
drazkers
Post by drazkers »
NKNick wrote: Tue Apr 23, 2019 10:44 Hi There,
Did we add timecode triggering and i missed it?
drazkers wrote: Sat Apr 27, 2019 00:18 Did we add timecode triggering and i missed it?
No, SMPTE can't trigger (connect) clips currently in Resolume.
