7.0.3 problem
rescs
7.0.3 problem
Post by rescs »
i've a big problem since 7.0.3 update. i lost many transition, files, automation ??? i remake all, save all, but he don't remenber all new change ?? with the same computer (win 10 pro) with 7.0.1 or 7.0.2 it's ok, but sometimes crash.
Also, i've a system with 2 resolume, when i open resolume, he send many osc command and make trouble in the second resolume.
Thanks for your reply
rescs
Re: 7.0.3 problem
Post by rescs »
after hours of test, i've make a windows update, i'm in 1809. this computer work only for this show and when it work i don't make update. Now i think all is ok but i've many problem with autopilot sometimes diseapear ?
Re: 7.0.3 problem
rescs wrote: Sat Sep 28, 2019 17:40 Now i think all is ok but i've many problem with autopilot sometimes diseapear ?
Is this with another machine sending OSC to this one?
If so, try disabling OSC input in the Resolume OSC preferences.
rescs
Re: 7.0.3 problem
Post by rescs »
hi, thanks, Yes this is another computer send. But i need some osc for the show. But why arena same lot of osc message at startup? For the moment i cut the osc before quit and active after, but....a small parts:
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/transporttype) INT32(0)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/autopilotloopcount) FLOAT(0)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/cliptriggerstyle) INT32(0)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/cliptarget) INT32(0)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/beatsnap) INT32(1)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/faderstart) INT32(0)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/audio/volume/in/in) FLOAT(0.000015848931)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/audio/volume/out/out) FLOAT(1)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/audio/pan/in/in) FLOAT(0)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/audio/pan/out/out) FLOAT(1)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/video/transition/mixer/blendmode) INT32(2)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/video/mixer/blendmode) INT32(6)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/solo) INT32(0)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/audio/volume) FLOAT(1)
RECEIVE | ENDPOINT([::ffff:127.0.0.1]:61389) ADDRESS(/video/opacity) FLOAT(1)
WHY?????????
Re: 7.0.3 problem
If you have the Output All OSC messages shortcut preset selected, Resolume will send every changed parameter as OSC message.
If you load an existing composition, after a new one, every property of every item is a change.
If you'd only like to receive specific OSC messages, you can create your own OSC preset: https://resolume.com/support/en/osc#osc-output
