[fixed] not loading the demo footage?
gpvillamil
Post by gpvillamil »
I'd always installed Resolume without the demo footage. Then I installed Resolume 2.3 WITH the demo footage, and now it always loads the demo decks on startup.
How can I keep this from happening?
[Edited on 4-10-2005 by bart]
VjSky
solution
Post by VjSky »
right-click on the active deck name in the deck selection bar and deselect it for load on startup
right click the deck tab (at the bottom of the interface) and select 'on startup' -> [empty]
or even better: load the deck you do want to load on startup and select that with 'on startup'
