Asus Zephyrus s gx701 - GPU not detected 1 hour before show
Intange
Post by Intange »
Im just posting an incident that happened to me a couple of days ago.
Here is the setup:
Asus Zephyrus s gx701 32 GB, RTX 2070 GPU
About an hour before doors, i noticed my Asus laptop was dropping frames. I decided to reboot to have a fresh start before the show (Corporate gig). Once it was rebooted I had no output either from the HDMI or Displayport. The NVIDIA control center was not active. I tried re-installing the Nvidia driver and it told me my system did not have a GPU installed. Doors opened and ran the show from a Lenovo backup I had going. I started googling what was going on and saw that other people had run into the same "missing GPU" that I had going. It turns out that the Asus Live auto Update had run that day and corrupted the registry key for "Intel(R) PCIe controller(x16) - 1901". This was confirmed in Device Manager. Some people online had just returned the computer others had reset windows wiping out all of their programs to fix the registry. I did the latter, half an hour later my GPU was back and Resolume re-installed.
What have I learned:
Turn off Auto update on Asus laptops, It can mess you up.
Maybe even stay away from Asus...
Always run a backup.
Im going to pickup a new Macbook Pro with the 8 Gb AMD Radeon Pro 5500M. If anyone has any experience with this Id love to hear from you.
I actually have proper main/backup 4 U graphic servers, client did not have budget on this one for them and onsite decided to run resolume anyways on my laptops instead of Playback Pro and almost had a major issue
Re: Asus Zephyrus s gx701 - GPU not detected 1 hour before show
Wow, that sucks! :o
