Resolume Arena 7.2.1
sharapov_f
Post by sharapov_f »
Hi!
I found a problem: when switching columns in the program, the image freezes for a moment. Version 6 does not have this problem ...
Re: Resolume Arena 7.2.1
Try disabling DMA textures in the preferences - video tab.
sharapov_f
No result....
sharapov_f
That problem only on Mac os..
On same computer and windows everything ok
sharapov_f
When i switching from clip to clip, i don't have any problem..
Only when i switch column tigger
Which mac are you using?
vj_anthos
Post by vj_anthos »
I have the same problem, noticed it a few weeks ago, looking to resolve it before ma next gig Sat. When first booting Arena up, it's fine if I flick through columns, then within a couple of minutes and waiting for a column to play for at least 10ish seconds it'll 'pause' between column shifts. It's really noticeable. And uncool. ;-)
Machine specs:
macOS Catalina v 10.15.5
MacBook Pro (15-inch 2019)
Processor 2.4 GHz 8-Core Intel Core i9
Memory 32 GB 2400 MHz DDR4
Graphics Radeon Pro 560X 4 GB
Intel UHD Graphics 630 1536 MB
Arena 7.2.1 rev70674 July 2020
Are you using DXV clips with uncompressed audio?
vj_anthos
Post by vj_anthos »
I'm using DXV 3 normal quality with Alpha (latest comp uses my fresh artwork that's using a lot of alpha and that's the one that's really playing up), size same as source 1920 x 1080, no audio. All clips have been converted through Alley. I also notice similar effect in STV's Expanse pack but it's only minor, still there though.
vj_anthos
Post by vj_anthos »
Running tests right now and firing columns within seconds of each other, no delay, wait a good few seconds and firing a column generates a delay. Hope that helps.
