Advanced Output Savefile
LedKim
Post by LedKim »
Hi!
I recently started using your software and I really like it so far!
However there is one problem.
I've made a composition with serveral outputs/virtual outputs and slices etc. Works great, but when I saved the composition and move on to another project and make a new Advanced Output I somehow overwrite the old old setup with the new.
And I cant find the preset for the old Composition even tho I pressed "save and close" before closing the window.
In other words: Does the compostition save file include the Advanced Output setup? If not, were do I find it?
Regards Kim
Re: Advanced Output Savefile
Do you save your Advanced output preset under a new name?
https://resolume.com/support/en/advance ... ng-presets
